3" Lift after TSB.
Old 01-26-2008, 03:38 AM   #1
mikenredding is on a distinguished road
mikenredding's Tacoma Gallery
Smile 3" Lift after TSB.
Hi, I have a question. I'm getting the Toyota TSB done soon and then I plan on installing a 3"lift kit. My question is what size tires can I run with my stock rim which is 16" from my 2005 tacoma 4x4? I'm thinking of running 275/70/16 but am not sure how big of a tire that is in inches high.
thanks
Old 01-26-2008, 07:14 AM   #2
surfponto is on a distinguished road
surfponto's Tacoma Gallery
thanks
What kind of lift are oyu going with? I just got the green light to lift our Tacoma also.
Old 01-26-2008, 02:38 PM   #3
It's a Pro comp lift kit on ebay for about $169. The guy makes them for pro comp. It uses a 3inch aluminum spacer on the front and leaf springs on the back. The front spacer doesn't require a shock compressor to install.
Old 01-26-2008, 07:04 PM   #4
Any dog under 50# is a cat and cats are useless...
jhodge83's Tacoma Gallery
the leaf spring for the back will completely negate the springs that just got put on ur truck w/ the tsb
Old 01-27-2008, 01:28 AM   #5
Smile
won't adding a lift kit leaf after the TSB just raise the rear end 1.5 to 2 inches?
Old 01-27-2008, 06:41 AM   #6
Old & Forgetful
Janster's Avatar
Gender: Female
Janster's Tacoma Gallery
Wow.... anybody have this lift?
Does their knuckles come in contact with the coils?
If I rememer correctly, having a spacer that big above your coil assembly causes your knuckles to be too close to the coils and possibly cause contact.
Old 01-27-2008, 09:28 AM   #7
Thumbs up
I was told, when I called and was asking if I needed a spring compressor and was told no by the manufacturer. I was also told that you still have to take the front spring assembly off and the 3" spacer bolts to the top plate of the spring and does'nt preload the spring like most other kits due thereby not having as stiff a ride in the front end. Now as far as binding with something I'm not sure as I have'nt installed the kit yet.. I am having the TSB done 1st so I don't run into any warranty issues like them not wanting to install the TSB cause of having a lift in.......
Old 01-27-2008, 07:44 PM   #8
everything i've seen online about lifting the rear after the tsb says to use blocks if u need any extra
Suspension TSB + 3" Lift Justin626 Suspension 9 07-11-2011 02:41 PM
3" Lift w/TSB: 1.5" or 2" AAL? BGrutter Suspension 6 10-26-2010 04:26 PM
Rear lift, 1.5" aal and 1" block....no tsb Outgolfing Suspension 1 04-28-2010 11:23 PM
Suspension TSB After revtek 3" lift??? Johnson8537 2nd Gen. Tacomas 4 05-26-2008 09:22 PM
TSB AFTER 3" Toytec lift Motorkopf Suspension 10 01-09-2008 11:17 PM
