What's Better....?
Old 10-07-2009, 10:00 PM   #1
SLOH [OP] SLOH is offline
SLOH is a jewel in the roughSLOH is a jewel in the roughSLOH is a jewel in the rough
SLOH's Avatar
SLOH's Tacoma Gallery
Question What's Better....?
for a rear shock or shock in general for off road performance
2.0 coilovers with remote reservoir
or
2.5 with remote reservoir (not coil over)
what are the advantages to a coil over?
i know the 2.0 and 2.5 are references to the reservoir or at least thats my understanding of it...some help
Old 10-07-2009, 10:12 PM   #2
dylandercole is one of the sharper tools in the sheddylandercole is one of the sharper tools in the sheddylandercole is one of the sharper tools in the sheddylandercole is one of the sharper tools in the sheddylandercole is one of the sharper tools in the sheddylandercole is one of the sharper tools in the sheddylandercole is one of the sharper tools in the sheddylandercole is one of the sharper tools in the sheddylandercole is one of the sharper tools in the sheddylandercole is one of the sharper tools in the sheddylandercole is one of the sharper tools in the shed
dylandercole's Avatar
EMS: EMT-Santa Clara County
dylandercole's Tacoma Gallery
i didnt think you would get coilovers in the rear i thought they were just for the front.
Old 10-07-2009, 10:19 PM   #3
socal16 is one of the sharper tools in the shedsocal16 is one of the sharper tools in the shedsocal16 is one of the sharper tools in the shedsocal16 is one of the sharper tools in the shedsocal16 is one of the sharper tools in the shedsocal16 is one of the sharper tools in the shedsocal16 is one of the sharper tools in the shedsocal16 is one of the sharper tools in the shedsocal16 is one of the sharper tools in the shedsocal16 is one of the sharper tools in the shedsocal16 is one of the sharper tools in the shed
socal16's Avatar
socal16's Tacoma Gallery
yeaa you cant put coiloverss in the rear
Old 10-07-2009, 10:29 PM   #5
socal16's Avatar
thats a coilover like the ones in the front it just doesnt have the spring on it thats why it has that black sleeve around it for so you can put one on
Old 10-07-2009, 10:33 PM   #6
chris4x4's Avatar
chris4x4's Tacoma Gallery
I havent done any temperature tests on coilovers, but I know the 2.0's are the same size as the bilstien 5100's (or close enough), and can say that you have to work hard to get them to heat up when off raoding. I would guess, that if the temp doesnt get above 100* out...You wouldnt be able to over heat them at all.
Old 10-07-2009, 10:35 PM   #7
RelentlessTaco's Avatar
between the 2" and 2.5, the diference is the diameter of the shock body. The 2.5 is larger and allows more piston surface and oil capacity lending it to have better dampening ability and the extra oil should make it run cooler than the 2.0 also.
Old 10-07-2009, 10:39 PM   #8
I heated my rear 5100s to the point that I couldnt hold my hand on them for more than about a second while out wheelin last week in about 40* weather(once I realized they were so hot I let em cool down a bit). So, i'd say its more than possible to get em hot as I wasnt even trying, granted I was mobbing down some old dirt logging/fire roads at a decent clip for probably 5-10 miles. The front OMEs only got a tad warm though, so I was less than impressed with my Bilsteins when I found them to be cookin hot.
Old 10-07-2009, 10:42 PM   #9
chris4x4's Avatar
Thats pretty interesting...I wonder if the Billies had enough oil in them?? When I ran my heat tests, it was in about 90* weather, and for about 12 miles at 35 mph + on a pretty rough trail. The OME's got to 140*, and the Billies got to about 190*...
Old 10-07-2009, 10:43 PM   #10
SLOH's Avatar
ballsack, alright what about these kings
http://www.allphaseoffroad.com/products.html?id=443
and thanks chris, how do those 5100's compare with my N182s in back, i don't want waste money getting a shock w/ remote reservoir and have it not be worth it
Old 10-07-2009, 10:47 PM   #11
chris4x4's Avatar
The n182's are a better shock. They run cooler, and are a little softer dampened.
Old 10-07-2009, 10:49 PM   #12
My R6 Eats Me
AlexForbesR6 is one of the sharper tools in the shedAlexForbesR6 is one of the sharper tools in the shedAlexForbesR6 is one of the sharper tools in the shedAlexForbesR6 is one of the sharper tools in the shedAlexForbesR6 is one of the sharper tools in the shedAlexForbesR6 is one of the sharper tools in the shedAlexForbesR6 is one of the sharper tools in the shedAlexForbesR6 is one of the sharper tools in the shedAlexForbesR6 is one of the sharper tools in the shedAlexForbesR6 is one of the sharper tools in the shedAlexForbesR6 is one of the sharper tools in the shed
AlexForbesR6's Avatar
AlexForbesR6's Tacoma Gallery
those are weird...i haven't heard of a coilover in the rear either...thats what the leaves are for...hmmm
depending on how much more the 2.5's are i would say go for them... that way you will be less likely to want to upgrade in the future, which would cost you more.
Go big or go home son!!!
haha
that being said the fox 2.0's are GREAT shocks...specially the remote reservoir ones
Old 10-07-2009, 10:50 PM   #13
socal16's Avatar
those kings are nice! but that price is crazy it all depends on the terrain that youll be driving the most on if your driving really fast in the desert then yes do it but if its the road or rockcrawling or something slow then i say no
Old 10-07-2009, 10:55 PM   #14
SLOH's Avatar
the fastest i've ever been on dirt is 100mph...wish i got it on camera but it wasnt set up...spur of the moment type thing
alright so i think i'm gonna go with those and the ome 2.5" leaf pack...i still don't know what to do about the rake from the leaves
Old 10-07-2009, 10:57 PM   #15
socal16's Avatar
im gonna say it once again your crazy haha be sure to take a camera next time!!
Old 10-07-2009, 11:11 PM   #16
SLOH's Avatar
yeah its been a goal of mine for awhile and i finally got it in spring earlier this year....i think it was spring break actually
alright so what am i going to be able to run in back, those kings say 12" and the only other 2.5s are 14"....idk if i'm going to be able to run the 12" w/ a 2.5-3" leaf kit
Old 10-08-2009, 01:35 PM   #17
yosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shed
yosh2000's Avatar
yosh2000's Tacoma Gallery
remove a leaf? its been noted here to drop the rear a little bit?
or RCD drop bracket lift for 4-5" in front?
Old 10-08-2009, 02:05 PM   #18
mjp2's Avatar
mjp2's Tacoma Gallery
Those Kings will not bolt up in the rear. You'll need some custom fab work to fit 'em. Most likely some custom shock hoops. You'll also need to modify the valving to work with your setup.
You're looking at a performance shock designed to be used in custom applications. Set up properly they'll kick serious ass, but it'll take some work to get them set up right.
Old 10-08-2009, 02:07 PM   #19
mjp2's Avatar
For reference, here's the custom shock hoop I ran when I was running 2.5" 12" travel Fox shocks on the rear of my truck:
