5100 lift problems 08 SR5
Old 10-11-2009, 10:44 PM   #1
Deathprone [OP] Deathprone is offline
Deathprone is on a distinguished road
Deathprone's Tacoma Gallery
After searching this forum for weeks I decided the best lift for how I use my truck and my budget was 5100's at 2.5 and toytecs aal for trucks with the TSB.
First problem, all the pics Ive found of this setup are perfectly level but my truck sits alot lower in the front than all the ones Ive seen. Is this because the SR5 has a lower spring rate and 2.5in of lift is only achived on the TRD?? How do I fix this? Ive heard of top plate spacers on the driver side to correct lean what if I did both sides? Do I need new coils?
Also I have vibes from a stop, has anyone fixed this with anything other than a new drive shaft? I tried a 1/4" drop for the carrier bearing and it did nothing so i took it off.
Old 10-12-2009, 12:31 PM   #2
numbers
I checked aginst my friends SR5 I have 1 1/4in lift in the front over him, and 3in in the rear.
2008 reg cab, 4x4 SR5 problems bjscullysr 2nd Gen. Tacomas 0 09-09-2010 07:55 PM
lift on an 08 2 wd prerunner sr5 awgg08 2nd Gen. Tacomas 4 01-26-2010 09:09 AM
who has 08 dc w/5100 lift? swise 2nd Gen. Tacomas 17 12-12-2009 02:31 PM
Problems with ABS and VSC after 5100 lift, tires robert benner 2nd Gen. Tacomas 10 02-14-2009 04:59 PM
08 tacomas having start problems deadbolt 2nd Gen. Tacomas 26 11-17-2008 07:10 PM
