moderate lift questions
Old 10-16-2009, 01:26 PM   #1
pokeng [OP] pokeng is offline
Married With Children
pokeng will become famous soon enoughpokeng will become famous soon enough
pokeng's Avatar
pokeng's Tacoma Gallery
Question moderate lift questions
Considering options for a moderate lift (< 3", more like 2" to hopefully keep stock UCA's within alignment specs) without using 5100's to get better quality ride for my daily driver. Goal is simply to fix the rake (after TSB) and get a better stance. I've abused the TW search feature, but keep coming back to some questions that I can't find a straight answer. Hopefully someone can answer (I'm sure chris4x4 and jdkeller are all over this one )...
1. OME 884 are "not recommended" to be used with double cabs (mine) due to "sag" issues. I'm ok with an initial sag due to the extra cab weight (not looking for full 3" lift). Does this sag continue over time (i.e. creep) or does it settle in at say, 2" of lift and stay permanently? I've read older OME springs like the 881 seem to sag forever, thus the concern. If they don't continually creep, what final lift could one expect on a DC?
2. Can the Eibach 1.6" springs be used with the small spacers to fix the taco lean? For that matter, can they be used with slightly bigger spacers to get closer to a 2" lift, like 3/8" on passenger and 5/8" on driver side? I do light off-roading, so small spacers may not be a big deal for me.
Thanks in advance.
Old 10-16-2009, 01:33 PM   #2
mjp2's Avatar
mjp2's Tacoma Gallery
Just curious here, but what's your bias against the 5100's?
Old 10-16-2009, 01:43 PM   #3
Power Top
MonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shed
MonkeyProof's Avatar
Army: K9 Handler
Gender: Tranny
MonkeyProof's Tacoma Gallery
Send a message via MSN to MonkeyProof Send a message via Skype™ to MonkeyProof
my 5100's on stock springs served me well up to my current setup with the All Pro LT kit..i had them set to the max lift in the front, performance and feel was greatly improved over the stock setup. plus, they are a great value!! Sonny from DownSouthMotorSports.com can prolly hook you up on a great deal..and his customer service is highly praised as outstanding
on 5100's in the front and TSB leafs in the rear in this pic...
Old 10-16-2009, 01:44 PM   #4
pokeng's Avatar
No bias. Just have read some concerns/complaints about ride quality at the 1.75 and 2.5 settings. Thought it would be worthwhile to spend a few bucks more for new coils. If I end up with Eibach's, prolly will still get the 5100's.
Old 10-16-2009, 01:48 PM   #5
mjp2's Avatar
Cool. Just wanted to see if it was a budget thing. Didn't want to see you overlook an option that could be had for $100 used if you time it right.
I'm sure someone will jump in with suggestions soon.
Old 10-16-2009, 01:59 PM   #6
Alaska Dude
akwagon is just really niceakwagon is just really niceakwagon is just really niceakwagon is just really nice
akwagon's Avatar
akwagon's Tacoma Gallery
Send a message via AIM to akwagon
I have the Eibach, Nice ride. happy with them. If I could do over would go with 5100's
Old 10-16-2009, 03:22 PM   #7
pokeng's Avatar
Interesting. Why do you now favor the Billy's?
Old 10-18-2009, 05:58 PM   #8
pokeng's Avatar
Self-serving bump.
Old 10-18-2009, 07:16 PM   #9
Happy Camper
SamSter0077 is one of the sharper tools in the shedSamSter0077 is one of the sharper tools in the shedSamSter0077 is one of the sharper tools in the shedSamSter0077 is one of the sharper tools in the shedSamSter0077 is one of the sharper tools in the shedSamSter0077 is one of the sharper tools in the shedSamSter0077 is one of the sharper tools in the shedSamSter0077 is one of the sharper tools in the shedSamSter0077 is one of the sharper tools in the shedSamSter0077 is one of the sharper tools in the shedSamSter0077 is one of the sharper tools in the shed
SamSter0077's Avatar
SamSter0077's Tacoma Gallery
Originally Posted by pokeng View Post
Self-serving bump.
I just made a move for the same reason, except.. I over shot it by 1 inch. Now, I will have to add the TSB AAL from Toytec to fix it. I put the 886 coils up front with the spacers.. that being said, measure the height of the front fender and rear fender.. I had three inches of difference before starting on mine. if you have 3 inches of difference, buy the 885 coils with no spacer, install and align.. your done.
Firestone got mine aligned after a 3+" lift on the front with a TSB back.. Stock UCAs. Don't do the 884s, just go 885 with NO Spacers.. My 2 Cents. Look at my photo's if you want to see the end result.
Edit: I glanced at what you have, sounds like you have the same thing I do.. 4x4 DC TRD OR, after the TSB back end the "plow" effect was too much.
Old 10-18-2009, 08:17 PM   #10
pokeng's Avatar
Based on what I've read on TW, 885's w/o spacers usually gives 2.5"-2.75" of lift. I've got 1-5/8" rake now w/o the TSB, and am thinking that should increase to about 2-5/8" after getting the TSB. I was hoping to get closer to 2" in the front to have a little rake when all done, so that's why I'm considering the 884's and Eibachs. I prolly just need to suck it up and get the Toytec adjustable coils and remove all doubt.
Old 10-19-2009, 05:33 AM   #11
Happy Camper
Do it right the first time, if you have doubt now.............. if it isn't right, it will annoy you. 5100's at 1.75 is another good option.
Old 10-19-2009, 05:38 AM   #12
chris4x4's Avatar
chris4x4's Tacoma Gallery
If your looking for 2" lift, and no more, the 884's will serve you well.
Old 10-19-2009, 05:53 AM   #13
Happy Camper
Listen to Chris, he knows! He might smash his hand in the process of giving you one.. but... he knows!
Old 10-19-2009, 05:54 AM   #14
chris4x4's Avatar
LOL!!
Old 10-19-2009, 06:13 AM   #15
pokeng's Avatar
No worries with losing that 2" over time?
Old 10-19-2009, 06:14 AM   #16
chris4x4's Avatar
No. Should be fine. Get the springs from Wheelers.
Old 10-19-2009, 06:21 AM   #17
XXXXXXXXXXXXXXXXXXXX
T@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shed
T@co_Pr3runn3r's Avatar
T@co_Pr3runn3r's Tacoma Gallery
I don't see what the issue is with just going 2.5 on 5100s with the TRD coils. I have this setup with the Toytec spacer to cure the lean on driver side. This is my daily driver & it rides great, no harsh bouncing nothing. Out back still got the 3 leaf crap pack with Toytec 1.5 AAL. Sits just shy of level, little over inch higher in back. No load issues, no vibration, no alignment issues & no crappy ride for daily driving.
Old 10-19-2009, 06:24 AM   #18
chris4x4's Avatar
The 884's will ride better than the preloaded OEM springs on the 5100 shocks.
Old 10-19-2009, 06:27 AM   #19
Damn, if it rode any better than it does now I'd be ridin in a buick or caddy or some other cushy floaty land yacht type thing. Si, es muy chinanigantastico! Off road I could see it being better not being preloaded tho.
Old 10-19-2009, 08:11 AM   #20
Happy Camper
source: http://www.tacoma-upgrade.com/2009/0...ight.html#more
Here are the specs from ARB, including length, spring rate and expected lift.
The 884 and 885 run the same rate at 590lbs/in with the 886 coils bumped to 660 lbs/in. Length is as follows:
OME884 390mm, 590lbs/in, 1 inch of lift
OME885 395mm, 590lb/in, 1.5 to 2 inches of lift
OME886 402mm, 660lbs/in, 2.5-3+ inches of lift
Factor TRD Tacoma springs, 14 inches long, 540lbs/in, 0 lift
These springs should only be run with the OME N140S shock; the factory Tokico and Bilstein units will not last with these springs due to their increased spring rate and length. The 886 springs are only recommended for trucks with heavy front bumpers and armor (skid plates).
moderate trails in flagstaff? hamNswiss on rye Arizona 20 11-09-2011 11:05 PM
best moderate lift for 2nd gen reg cabs xwillx93 2nd Gen. Tacomas 20 07-02-2011 06:02 PM
JW's moderate Build jwhelan 2nd Gen. Builds 21 04-10-2010 07:52 PM
Best gen for 'moderate' build up? randombob Off-Roading & Trails 40 12-09-2009 08:16 AM
Oshky's moderate build... oshky 2nd Gen. Builds 11 06-28-2009 05:11 PM
