SecretSquirrel's 2005 Tacoma w/ All-Pro Bumper, Satoshi Grille, Cooper 305 STTs & more...
Need some HELP/ADVICE about my fox coilovers
Old 11-04-2009, 10:02 PM   #1
jrodrigo621 is on a distinguished road
jrodrigo621's Avatar
jrodrigo621's Tacoma Gallery
Hey there guys, last weekend i gave the 3inch lift with the fox coilovers (camburg arms) and i put on the limited straps of 16inch, but i feel very hard the ride/suspension, when i pass a speedbump or a hole (the streets here in Mexico are in very bad shape) what can do i do about it, lower it down to 2inches? or what other choice do i have?
I Really apreciate your help guys ...
jRod!!!
Old 11-04-2009, 10:11 PM   #2
wheeler
RelentlessTaco has a reputation beyond reputeRelentlessTaco has a reputation beyond reputeRelentlessTaco has a reputation beyond reputeRelentlessTaco has a reputation beyond reputeRelentlessTaco has a reputation beyond reputeRelentlessTaco has a reputation beyond reputeRelentlessTaco has a reputation beyond reputeRelentlessTaco has a reputation beyond reputeRelentlessTaco has a reputation beyond reputeRelentlessTaco has a reputation beyond reputeRelentlessTaco has a reputation beyond repute
RelentlessTaco's Avatar
Name: The STIG! j/k... Eric
Send a message via MSN to RelentlessTaco
if you dont mind a little more body roll under hard cornering, then removing the sway bar will smoothen things up a bunch. I pulled mine off and havent looked back. It still handles fine IMO and the increased front articulation off road cant be beat. Keep in mind removing it will make the truck less stable in an emergency maneuver and increases the chance of a rollover though.
Old 11-04-2009, 10:18 PM   #3
Robtrd is just really niceRobtrd is just really niceRobtrd is just really niceRobtrd is just really niceRobtrd is just really nice
Robtrd's Avatar
Robtrd's Tacoma Gallery
jRod!!!
Post pics I wanna see
Old 11-05-2009, 12:15 PM   #4
see my other threads, there i have the pictures of the truck ...
Old 11-05-2009, 02:38 PM   #5
CHICKEN FUKR
bajamoon has a reputation beyond reputebajamoon has a reputation beyond reputebajamoon has a reputation beyond reputebajamoon has a reputation beyond reputebajamoon has a reputation beyond reputebajamoon has a reputation beyond reputebajamoon has a reputation beyond reputebajamoon has a reputation beyond reputebajamoon has a reputation beyond reputebajamoon has a reputation beyond reputebajamoon has a reputation beyond repute
bajamoon's Avatar
bajamoon's Tacoma Gallery
lower a little will help as well as the sway bar. the higher you go the harder the ride. are the coilovers new or did you buy them used, maybe need a rebuild, what is the spring rate if you know
__________________
Old 11-05-2009, 05:46 PM   #6
same guy as other nelson18matt
nelson18matt2 is on a distinguished road
nelson18matt2's Avatar
Air Force: EX-CONE
nelson18matt2's Tacoma Gallery
i'd take some preload off the spring. if you got them cranked down to give you 3" lift then the ride is gonna be very very stiff.
Old 11-06-2009, 09:24 AM   #7
Yeah im going to lower it 1inch and maybe with the limited straps, take 0.5inch of travel.
The coilovers are new and i dont know the spring rate, regarding the sway bar im thinkin about it, I still have my doubts.
Old 11-06-2009, 09:45 AM   #8
CHICKEN FUKR
bajamoon's Avatar
it will handle fine without the sway bar, the coilovers are better than the stock shocks and body roll is not bad. i have tested mine on the freeway with emergency swerve and some body roll but nothing scary. try it and you will like it
__________________
Old 11-06-2009, 10:18 AM   #9
time travel exists
Keason1* has a reputation beyond reputeKeason1* has a reputation beyond reputeKeason1* has a reputation beyond reputeKeason1* has a reputation beyond reputeKeason1* has a reputation beyond reputeKeason1* has a reputation beyond reputeKeason1* has a reputation beyond reputeKeason1* has a reputation beyond reputeKeason1* has a reputation beyond reputeKeason1* has a reputation beyond reputeKeason1* has a reputation beyond repute
Keason1*'s Avatar
Keason1*'s Tacoma Gallery
I had mine at 3" at first and it was unbearable! I dropped it down to around 2 - 2.5" and its wayyyy smoother!
and check to see what setting you are on on your resi. 1 being the softest and 8 being the roughest
Old 11-06-2009, 01:53 PM   #10
"resi"? meaning what? i didnt understand, the reservoir?
Old 11-06-2009, 02:05 PM   #11
06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of
06Bluez's Avatar
06Bluez's Tacoma Gallery
U can take the sway bar off and be just fine.
The coils on the Fox's are much bigger then stock (assuming you have the 2.5's) and the body roll wont be to bad. stock shocks and no sway bar can be more dangerous.
I have my sway bar off and Fox 2.5's and I love it.
__________________
Old 11-06-2009, 02:05 PM   #12
06Bluez's Avatar
exactly.
__________________
Old 11-06-2009, 03:57 PM   #13
So how many inches from the ground to the fender is your truck lifted? 39? 39.5?
Old 11-06-2009, 04:34 PM   #14
CHICKEN FUKR
bajamoon's Avatar
the height will vary because of wheel/tire size
__________________
Old 11-06-2009, 06:43 PM   #15
MEAN STREAK
pataco is a jewel in the roughpataco is a jewel in the roughpataco is a jewel in the roughpataco is a jewel in the rough
pataco's Avatar
pataco's Tacoma Gallery
bajamoon,that is one bad ass truck.wish i could do that around here.local police would have a field day with it for sure.love the way it looks.
__________________
Old 11-06-2009, 08:19 PM   #16
i got the 285-70-r17 and its 40inches from the ground to the fender
Old 11-06-2009, 10:48 PM   #17
CHICKEN FUKR
bajamoon's Avatar
sounds about right, i think mine was about 39 before i went long travel
__________________
Old 11-07-2009, 11:00 PM   #18
well i took off 5/8 off an inch, and the height is still 40 inches from the ground to the fender (weird huu?), but it felt so much smoother and the limited straps are now doing the right job.
Later on the week im gonna have a good camera and im gonna take some pictures of the whole truck ...
Old 11-13-2009, 08:08 AM   #19
Heres some pics of the truck with the 40inches front
Old 11-13-2009, 08:15 AM   #20
CHICKEN FUKR
bajamoon's Avatar
looks goodm why are you running limit straps, i have only seen that on long travel trucks like mine.
__________________
Home > Tacoma Garage > Suspension
Display Modes
Icon coilovers or the King RR coilovers? Bearskill Suspension 108 11-16-2009 06:37 PM
FS: 05+ Fox 2.5 RR coilovers, Camburg UCA, SS Brake lines all.on.black Buy / Sell / Trade 29 08-04-2009 03:13 PM
Adjusting Fox 2.5 Coilovers FoxRacR17 Suspension 34 07-23-2009 07:03 AM
Black Fox Coilovers Seagrave 2nd Gen. Tacomas 6 04-22-2009 08:15 PM
Fox RR coilovers at Allpro? Bearskill Suspension 11 01-06-2009 07:44 PM
Copyright © 2009 Tacoma Forum
