5125 or 5100 in rear?
Discussion in 'Suspension' started by headhunter247, Nov 6, 2009.
  1. Nov 6, 2009 at 6:43 AM
    headhunter247
    headhunter247 [OP] Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    Very close to pulling the trigger on 5100s for front and have read a little about the 5125s. I know that they are longer. What could be my benefit of the 5125 vs 5100. Would I need extended brake lines if I got them?
  2. Nov 6, 2009 at 6:50 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    The 5100s and 5125s don't provide lift in the rear. It's the blocks or AAL or new leaf pack that does. Whether you'd need the 5125s over the 5100s or not would depend on the amount of lift you were getting in the rear. The 5100s extend more than the factory billys, and if you are just throwing an AAL in your stock or TSB leaf pack, then the 5100s should be fine. I don't know the exact threshold where the 5125s are beneficial though.
  3. Nov 6, 2009 at 6:53 AM
    headhunter247
    St. Louis, MO area
    Im planning on an AAL, and just using the 5100s in the front, but might end up putting OME springs and UCAs later down the road. I was thinking that the 5125s allowed more flex.
  4. Nov 6, 2009 at 6:54 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    iirc 5125s allow for more "custom" lengths than the 5100s and can be used in no factory spec setups
    i like mine :)
  5. Nov 6, 2009 at 6:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Depending how high you lift the rear. I have about 2" rear lift, and the 5100's are fine. If you get 3" or so in the rear, you should get the 5125's. They are the same shock, just a little longer.
  6. Nov 6, 2009 at 6:56 AM
    headhunter247
    St. Louis, MO area
    Yea, I dont plan on ever going over 3" in the rear, so I will just go with the 5100s.
  7. Nov 6, 2009 at 6:59 AM
    STLTaco09
    Good point about the flex, personally I'm not sure on how 5100s vs 5125s would compare. I'm sure someone else will chime in with more info.
  8. Nov 6, 2009 at 1:09 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    If you're worried about flex can you get 5100's and add shock extenders to them?
  9. Nov 6, 2009 at 5:24 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    I have the 5125s because I have a shackle lift on top of the AAL. I can get a real good amount of flex out of them. I ran the stock billys before I got the shackle and it sucked. 5125s are sweet
