If I use 5100's and a 265/75/16 tire, will I get rub?
Discussion in 'Suspension' started by ERdept, Feb 27, 2008.
  1. Feb 27, 2008 at 12:26 AM
    ERdept
    ERdept [OP] Well-Known Member
    I'm still having suspension debates.
    After I found an actual Toyota dealership that will install the 3 inch Toytec lift, they said they don't guarentee there WON'T be vibration issues.
    But, everyone seem happy with Bilstien 5100's though. So, if I get these all around and set the front to 2.5 and otherwise have a stock Prerunner, will I get tire rub from a 265/75/16 Nitto Terra Grappler?
  2. Feb 27, 2008 at 3:33 AM
    dwb
    dwb Well-Known Member
    Pine Mountain, GA
    05 Double Cab, TRD Sport/4X4, mostly stock with a few mods.
    Bilstein 5100's all around, 265/70/R17 BFG AT's, TRD seat covers, True Flow XDI Intake System. Fog light mod. More to come.
    No, you will not have rubbing issues with 265's. But my question is this: Is your truck a reg cab, xtra cab or dbl cab (4 door)? The reason I ask is for the vibration concerns. If the truck is a dbl cab, it has a 2 piece shaft with a carrier bearing. There's where the problem is in the rear. Some guys get it, and some don't.....I had it, and it sucked. The thing up front is the CV angle. So you would think that adding a diff drop would help, and it did some. Still got the hum from the front CV's. In my experience, the only way to properly lift a Tacoma dbl cab or any truck with IFS and a 2 piece driveshaft is to install a custom 1 piece shaft and a lift kit that includes new crossmembers and spindles. Such as Fabtech or Pro Comp. Then you solve both issues, the CV angles and the rear shaft vibes. So if your truck is a dbl cab or not, the best way to lift is not with spacers. That's just one mans opinion after doing much research. Good Luck......:cool:
  3. Feb 27, 2008 at 4:10 AM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    From what I understand and have read, the BFG's 265/75/16's are a good replacement for the Rugged Trail 265/70/16's. No rub even with stock suspensions.
    Please correct me guys if that is a wrong statement.
  4. Feb 27, 2008 at 5:04 AM
    Viper-2
    Viper-2 Secret Agent
    Keith
    Charleston, SC
    Prerunner with many mods
    I have Bilstein 5100 coilovers in front set at 1.75 and the rears installed (getting a 1 inch Toytec lift for rear should be here tomorrow). I have 4 Michelin LTX M/S 265/75/15.
    No rubbing with anything and awesome ride.
  5. Feb 27, 2008 at 6:14 AM
    dwb
    Pine Mountain, GA
    Yeah 10-4 to 265/70/R17 BFG AT's on stock suspension. I only have a 1 inch spacer in front and no rubbing at all. Tried the 3 inch and had too many issues with vibes and hums. If I lift my truck in the future it will be done right with a full 6" suspension lift and solid one piece driveshaft in the rear. But hey, I like the way my truck drives now. But I sure love looking at the ones that are lifted the right way.
  6. Feb 27, 2008 at 7:52 AM
    AZ074x4x4
    AZ074x4x4 Member
    07 Radiant Red dbl cab 4x4
    5100's all around, Cooper Discover 265/16/LT tires, Cat Back, Front tint, Gentex Mirror, MB V-Drive Mags, Front Mud Flap trim, Billet Grill, K&N CAI
    I have the 5100's set at 1.75", LT265/75R16 tires, No rubbing and no vibe problems.
  7. Feb 27, 2008 at 8:17 AM
    dwb
    Pine Mountain, GA
    Yeah AZO, as long as you don't go up to 3" you shouldn't have any vibes. The dbl cab like mine and yours has the 2 pc driveshaft with carrier bearing, and that's where the vibe comes from. Just keep your eye on those front CV's to make sure they are not rubbing. Your truck looks good by the way...........:thumbsup:
  8. Feb 27, 2008 at 8:48 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    i have a set of 5100's in the mail now. i have the rear spring TSB done and i'm hoping i can set the 5100's to 2.5" and it will be level. i dont want the front end to be higher than the back. did you settle on 1.75 because the front was too high? do you have the TSB done?
  9. Feb 27, 2008 at 8:54 AM
    mrbjr
    mrbjr Active Member
    Central CA
    '08 DC V6 4x4 TRD Sport
    TRD Exhaust,TRD Sport seat covers, Tube steps,Access Limited Bed Cover,WeatherTech floor mats, Billet Grill,AFE CAI,8"Shorty Antenna,ScanGaugeII.,5100s f/set @ .85, Console Safe.., Pirelli ATR's..,RoadMaster active suspension
    I had the TSB done and have my 5100s set at .85 front, and after about three good loads it is setting maybe a 1/4" higher in back.. Actually looks level...
  10. Feb 27, 2008 at 9:03 AM
    dwb
    Pine Mountain, GA
    Would you mind telling me what TSB is?:confused: Guess I've been living under a rock too long but I don't know the lingo. And I only have 1" in front now because the 3" made the CV's hum. This truck is my daily driver and I don't want to screw it up. So, like I said before, if I lift it more, it will be with a 6" suspension w/crossmembers, spindles, 5100's and a custom 1 pc driveshaft in the rear. But that would call for larger tires, and there goes my fuel mileage.....oh what to do.
  11. Feb 27, 2008 at 9:23 AM
    ERdept
    Mine's the access cab or xtra cab. So, don't know if I have the double cab issues.
  12. Feb 27, 2008 at 9:27 AM
    dwb
    Pine Mountain, GA
    Look under the truck and see if your rear driveshaft is one or two pc. If it's a 2 pc w/carrier bearing, then be mindful as you lift.
  13. Feb 27, 2008 at 10:58 AM
    ERdept
    So my drive shaft goes from the engine, then in the middle of the truck under the access cab, the shaft is divided with U-joint and a shackle, then it goes on to the rear diff.
    But after that connection, it doens't break up again.
  14. Feb 27, 2008 at 11:30 AM
    dwb
    Pine Mountain, GA
    Sounds to me like you do have a 2 pc shaft with carrier bearing. Go to the link below and scroll down until you see the photos of the two shafts. It's obvious which is the one you have. If you are going to raise your truck much over 2-3 inches, you need the 1 pc custom driveshaft.
    http://www.cardomain.com/ride/832238 This dudes truck is done so right in every way.
  15. Feb 28, 2008 at 3:27 AM
    Viper-2
    Keith
    Charleston, SC
    Yo, brother ND. I'm skeptical about a lot of people on the TN board and this one who did the 2.5 setting on those 5100's and said they were level. Perhaps my truck was built on the moon but myself and others have it set at 1.75 and STILL the front is 1/2" higher than the rear.
    I waited for months now to see about suspension settling and still the same. I ordered the Toytec 1" lift block for the rear and will install that this weekend. This should give me a 1/2" rake toward the front which is how I like it.
    If I were you bro I would NOT go over 1.75...in fact if I would do it again I would lower it to the third setting at 0.85.
    So, the major issue (besides irritating me whenever I look at at and it seems only I can notice it) is my headlights. I BLIND people (which gets me to thinking...anyone know how to adjust the headlights on our trucks? I can't find an adjustment screw anywhere). I get headlights flicked on in the opposite direction dozens of times a night and when behind some people they get really pissed off. They think my high beams are on until I nail them with my real high beams and my fogs (which are Xenons). This is all because I have a slight rake upwards toward the front.
    Yeah, yeah part of me enjoys it. :rolleyes:
  16. Feb 28, 2008 at 7:58 AM
    nd
    Nate
    Greenville, SC
    Hey Viper, do you have any recent pics of your truck from the side so i can see what it looks like with the tsb and the 5100's at 1.75? i measured the center of each rim to the fender. Technically there is exactly a 2.5 in difference between my front and rear. so the shocks shoudl "level'' it but with teh design of our bodies it may look like the front is higher. i dunno
  17. Feb 28, 2008 at 10:59 AM
    AZ074x4x4
    AZ074x4x4 Member
    I don't have the rear TSB and even when pulling by tent trailer, I have plenty of rear travel left, so I went with what would give me a level stance. Before I picked 1.75", I jacked the front up to 2.5" and it didn't look right.
  18. Feb 28, 2008 at 1:09 PM
    nd
    Nate
    Greenville, SC
    Ok, well do i have any options for lifting the back other than blocks? I cant use an AAL since i already have the TSB
  19. Feb 29, 2008 at 3:55 AM
    Viper-2
    Keith
    Charleston, SC
    I measured mine too and the front was definitely a 1/2" higher. Perhaps the springs are different? I thought the 4 leaf pack was all the same. Here is the picture from the side, it's not horrible but enough to bother me. If I'm on a rear incline it looks horrible because it makes it stand out! I just got the 1" Toytec yesterday.
    Not terrible but noiticeable to me...1"2 higher in front.
    Here is another. I am on an incline but it never looked THAT strange before in this parking spot. The front looks WAY higher...this is why I got the lift. Overall tires included it will be 3" higher than stock when I'm through
  20. Feb 29, 2008 at 4:01 AM
    Viper-2
    Keith
    Charleston, SC
    No one I've heard of is having any problems with the Toytec blocks. Check here:
