Tacoma World Forums mjp2's 2006 Tacoma
Register Site Information Glossary Calendar Search Today's Posts Mark Forums Read
5 Lug Lift Revisited...Idea on Options
Old 02-28-2008, 08:43 PM   #1
alextreme76 is on a distinguished road
alextreme76's Avatar
alextreme76's Tacoma Gallery
So I was looking at the service manual for the 5 lug and 6 lug front suspensions, everyone keeps saying they are TOTALLY different setups, but they look like the same basic coilover with different lengths (which dictates different control arms). I cant find anyone that has seriously looked at the spacer leveling kits for the 5 lug from a 6 lug. So has anyone looked at the dimensions and is there a difference so a 6 lug spacer wont fit?
Can someone with a 6 lug get me some dimension info on the upper bolts so I can compare it to our 5 lug.
5 lug left 6 lug right
__________________
Old 02-29-2008, 06:01 AM   #2
My other ride has sails
Roland has a reputation beyond reputeRoland has a reputation beyond reputeRoland has a reputation beyond reputeRoland has a reputation beyond reputeRoland has a reputation beyond reputeRoland has a reputation beyond reputeRoland has a reputation beyond reputeRoland has a reputation beyond reputeRoland has a reputation beyond reputeRoland has a reputation beyond reputeRoland has a reputation beyond repute
Roland's Avatar
Army: Combat Arms Instructor, HQ Detachment, RING
Roland's Tacoma Gallery
I'm a draftsman so maybe I'm picking up differences faster than the average mortal but I see several differences in that picture.
Looking at the size of the bolts on the bottom I'd say the scale of the parts is different so the right one is much longer. and probably wider.
The mounting surfaces at the top are completely different.
The number of coils is about double so a spacer designed for that long coil would probably reduce the amount of travel to something less than acceptible.
But those are potential problems which isn't what you asked for. If you're just going for looks you can probably get away with a lot. If you're planning on off roading I'd be careful using parts not designed for your suspension.
Good luck with your research!
__________________
"Life's journeys End is not to arrive at the grave safely in a well preserved body,
but rather to skid in sideways, totally worn out, shouting "...holy shit what a ride!"
Old 02-29-2008, 12:49 PM   #3
i see what you are are talking about, but length of bolts and there location on top of the coilover is the only real factor for most spacers. a coilover spacer usually sits atop the coil over, not inside, so the shock still has the factory amount of travel, its has just been relocated to a lower hanging position. i wouldnt stick like a daystar kit inside the coilover, most of the spacer kits i have seen for 6 lugs look to be a top mount spacer anyway.
the only real problems with a spacer on top of the coilover would be the grade of the mounting bolts on the coilover, but sheer force shouldnt be anymore or little less than a prerunner, with a 31.
__________________
Old 03-21-2008, 08:11 PM   #4
Western Alliance: ESO
gm3bow is on a distinguished road
gm3bow's Avatar
gm3bow's Tacoma Gallery
ReadyLIft Spacer and Add-a-leaf kit for 2nd gen 5lug tacos coming very very soon. $330
http://truck.hownd.com/product-4227-...ug-trucks.html
__________________
07 Taco, 2.7L, Access Cab, silver, afe drop-in, Flowmaster 40 n' chrome tip, Westin chrome nerfs, 2 12" cheapy Insignia subs in a sealed box, Audiobahn A400 2T amp, cheapy 200watt amp, 16" rims, 235/70/16 Pathfinders, Lund bug shield n' rain guards, "secondary" filter removed, l.e.d. turn signals, turn signal/side marker mod, eDead sound deadner, 4" fogs, Magellan 3100 gps
Old 03-21-2008, 08:32 PM   #5
lawnrevenge will become famous soon enough
lawnrevenge's Avatar
lawnrevenge's Tacoma Gallery
That makes me so happy. I'm willing to bet that the 6 lug coils would bolt onto the 5 lug suspension and just might provide the added lift. It all depends on if the bolts line up and if the oal is not too much longer.
Old 03-22-2008, 03:06 AM   #6
tacomanub08 is on a distinguished road
tacomanub08's Avatar
tacomanub08's Tacoma Gallery Send a message via AIM to tacomanub08
wow, that's awesome... thanks gm3bow
Display Modes
Buy/Sell section Idea corywilson13 New Members 3 02-08-2008 03:55 PM
Tacoma Horn revisited. This is why stock can't be loud. ERdept 2nd Gen. Tacomas 10 01-29-2008 07:34 PM
3 inch lift options? sslongmuir 1st Gen. Tacomas 6 01-13-2008 11:59 PM
Mythbusters Revisited socko3161 2nd Gen. Tacomas 15 10-04-2007 08:20 AM
Now I have no idea what is going on! Banshee Off-Topic Discussion 3 02-24-2007 09:06 AM
Copyright © 2008 Tacoma Forum
