Suspension Help 5100 tonight!
Old 12-07-2009, 08:47 PM   #1
hwork50 [OP] hwork50 is offline
hwork50 has a brilliant futurehwork50 has a brilliant futurehwork50 has a brilliant futurehwork50 has a brilliant futurehwork50 has a brilliant futurehwork50 has a brilliant futurehwork50 has a brilliant futurehwork50 has a brilliant futurehwork50 has a brilliant futurehwork50 has a brilliant futurehwork50 has a brilliant future
hwork50's Tacoma Gallery
So I bought the 5100 from Toyotec, package 4. I had a friend install it
and he did not do the AAL in the back. Tomorrow it gets an alignment done and adjust anything day.
1. When my friend installed the suspension he put the front shocks in so that they were the same length as the stock shocks. Is that the .85 or 0 setting?
2. Will the AAL solve my soft back end issues? I cannot go over a speed bump without the backend hitting the bump stops.
3. What is the difference between the front and the back height, stock? I want the same rake and do not want it level.
Anything else would be appreciated.
Brent
Old 12-07-2009, 08:50 PM   #2
Almost there
08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed
08pretaco's Avatar
08pretaco's Tacoma Gallery
1. 0
2. maybe, most likely
3. like 2" or 2.5" i think.. maybe even 1.5"
Old 12-07-2009, 08:50 PM   #3
CJH9980 is a splendid one to beholdCJH9980 is a splendid one to beholdCJH9980 is a splendid one to beholdCJH9980 is a splendid one to beholdCJH9980 is a splendid one to beholdCJH9980 is a splendid one to beholdCJH9980 is a splendid one to behold
Army: RN-Army Reserve 66H
CJH9980's Tacoma Gallery
If you want to maintain the factory rake then you'll have to raise the back at least as much as you raised the front. Look at the shocks and see what notch the circlip is on to tell if you're at 0 or .85 or 1.75 etc
Old 12-07-2009, 09:05 PM   #4
How will I know what each notch means? I am assuming that there are 3 notches, which one should it be at. I also have Eibach springs in case people are wondering.
Brent
Old 12-07-2009, 09:18 PM   #5
Almost there
08pretaco's Avatar
i edited my post and it didnt show up. with the eibachs you have 1.6" front lift without worrying about the c clip. if its not at 0 then you have that much more added lift.
so for level at zero do a 1.5" aal then youll still have a little front rake
Old 12-07-2009, 09:29 PM   #6
I have the Toyotec AAL which means I will get the lift it gives me. I do not think I can control the amount of lift with the AAL?
Old 12-07-2009, 09:31 PM   #7
Almost there
08pretaco's Avatar
isnt the toytec 1.5" or is it 2"? i think mine back in the day was a 1.5"
Old 12-07-2009, 09:35 PM   #8
Almost there
08pretaco's Avatar
looking at their site i think its a 2" aal therefor the 1.6" eibach lift with the zero setting on the 5100's will still give you the factory front rake
if you cant tell the setting post up a pic of the lower section of the strut assembly maybe it will be visable
Old 12-07-2009, 09:48 PM   #9
Where do I take the picture so I know what I am looking for?
Sorry I had the guy install them right out of the box.
Brent
Old 12-07-2009, 10:04 PM   #10
Almost there
08pretaco's Avatar
thats cool no worried. take a picture of where the spring sits on the bottom (forgot the name of the thing). pretty much just where the coil stop at the bottom
Old 12-07-2009, 10:29 PM   #11
Almost there
08pretaco's Avatar
nevermind about the picture. go to the truck and stick your finger just where the spring ends on the bottom. run it up along the shock, if you feel 3 grooves your at the lowest setting, 2 grooves your at the .85 setting
Old 12-07-2009, 10:35 PM   #12
I am at 2 grooves. I can see 2 grooves and barely touch the bottom of the second one. I guess that is a good thing. So I am good to go and the leaf springs will go in tomorrow.
I did have a question on the rear shocks as they just seem so soft and do not seem to sit right on the rear end. The shock covers are all scrunched up more so than anything I have seen. Maybe the AAL will fix that.
Brent
Old 12-07-2009, 10:38 PM   #13
TRDMEDIC is one of the sharper tools in the shedTRDMEDIC is one of the sharper tools in the shedTRDMEDIC is one of the sharper tools in the shedTRDMEDIC is one of the sharper tools in the shedTRDMEDIC is one of the sharper tools in the shedTRDMEDIC is one of the sharper tools in the shedTRDMEDIC is one of the sharper tools in the shedTRDMEDIC is one of the sharper tools in the shedTRDMEDIC is one of the sharper tools in the shedTRDMEDIC is one of the sharper tools in the shedTRDMEDIC is one of the sharper tools in the shed
TRDMEDIC's Avatar
TRDMEDIC's Tacoma Gallery
hwork50
This is prob kinda late but here's my truck with a little bit of rake. The front billies are set at .85 and the rear has tsb done and 1" block. Your aal should make the rear a little higher.
Old 12-07-2009, 10:42 PM   #14
That is a sweet looking truck. I think I will be good to go on my rake as I am adding the AAL toyotec and I already have about a 2.5" lift in the front.
My tires look so stupid with the lift. They are the stock tires and I need to do something about that. What size and make are your tires?
Brent
Old 12-07-2009, 10:43 PM   #15
Almost there
08pretaco's Avatar
^ doesnt that rear tsb add over an 1". so with the block your at least 2" rear. with only 1" up front shouldnt that increase the front rake?
from that angle it looks like (or theres just alot of weight added to the back with the camper and all) that there should be more than 1" lift up front. but its not my truck so im just making an observation
did you add a top plate spacer to the front?
then to the op: if you can touch 2 grooves your set at .85 which means your close to 2.5" up front. was there any top plate spacer added with that package 4? if so and they are installed your closer to 3" up front. also with the rear idk if the package came with 5100's for the rear but that would be a good idea to upgrade to those for rear shocks with the 2" leaf.
Old 12-07-2009, 10:46 PM   #16
Yes, right now I am totally even with no AAL. The AAL goes in tomorrow so there should be a big difference of like an inch or a little more.
Brent
Old 12-07-2009, 10:51 PM   #17
Almost there
08pretaco's Avatar
so it doesnt sound like a top plate was with that. if your even now then when you do the aal, after it settles, you will be about an 1.5-2" higher in the back.
then if you happen to get vibrations after the leaf tomorrow get shims from toytec, it will help
Old 12-07-2009, 10:51 PM   #18
Thanks everyone for your comments. I gotta go to bed, work at 6:00 am.
Brent
Old 12-07-2009, 10:54 PM   #19
m_yota will become famous soon enough
m_yota's Avatar
m_yota's Tacoma Gallery
Originally Posted by 08pretaco View Post
1. 0
x2
Old 12-07-2009, 11:34 PM   #20
TRDMEDIC's Avatar
My tires are stock size 265 75 16
Does bilstien 5100 improve suspension? avengedkevinfold Suspension 6 02-11-2011 10:37 AM
Squeaking Noise From RF Suspension After 5100 Install TRDKenE 2nd Gen. Tacomas 5 08-21-2010 11:55 AM
5100 suspension question hwork50 Suspension 10 12-02-2009 03:34 AM
Need opinions. Need new Rear suspension..OME or 5100's ryanf 2nd Gen. Tacomas 3 11-16-2009 09:43 PM
bilstein 5100"s and stock prerunner suspension??? tacomaman06 Suspension 41 05-15-2008 06:08 PM
