Thinking of Pro Comp Stage II
Old 01-13-2010, 03:41 PM   #1
Motoxerc0 [OP] Motoxerc0 is offline
Motoxerc0 is one of the sharper tools in the shedMotoxerc0 is one of the sharper tools in the shedMotoxerc0 is one of the sharper tools in the shedMotoxerc0 is one of the sharper tools in the shedMotoxerc0 is one of the sharper tools in the shedMotoxerc0 is one of the sharper tools in the shedMotoxerc0 is one of the sharper tools in the shedMotoxerc0 is one of the sharper tools in the shedMotoxerc0 is one of the sharper tools in the shedMotoxerc0 is one of the sharper tools in the shedMotoxerc0 is one of the sharper tools in the shed
Motoxerc0's Avatar
Motoxerc0's Tacoma Gallery
So here is my dilemma. Right now I have a Toytec 3 inch spacer lift with an aal, stock 16" alloys with spidertrax and 33s. I knew before starting the lift it was not the best way to do it but it was all I could afford at the time. That being said, I want to fix my mistake by getting a pro comp stage II. My next problem is what to do about wheels and tires. I just put out around $700 for A/ts for my 16 inch rims about 2 months ago but understand you must run at least 17" rims or larger for the lift. My question is, if I can find someone to trade their stock 17in alloys and 33s (and maybe some cash) for my 16in alloys and 33s (I know it's a long shot) would they work with the procomp lift? I have searched but have been unable to find an answer. I have an 06 btw. Any help would be appreciated.
Thanks,
Colin
Old 01-13-2010, 10:53 PM   #2
ktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shed
ktmrider's Avatar
ktmrider's Tacoma Gallery
Im pretty sure that its not necessary to use 17 inch with the procomp because the spindle isn't any bigger then the stock one. let me check tho
Old 01-13-2010, 10:54 PM   #3
ktmrider's Avatar
oooh
Note: (1) OE wheels will not fit. 2005-08 models must use 17” or larger diameter wheels.
my bad
Old 01-13-2010, 11:07 PM   #4
THE RED DRAGON!!
TexasIslandBoy is one of the sharper tools in the shedTexasIslandBoy is one of the sharper tools in the shedTexasIslandBoy is one of the sharper tools in the shedTexasIslandBoy is one of the sharper tools in the shedTexasIslandBoy is one of the sharper tools in the shedTexasIslandBoy is one of the sharper tools in the shedTexasIslandBoy is one of the sharper tools in the shedTexasIslandBoy is one of the sharper tools in the shedTexasIslandBoy is one of the sharper tools in the shedTexasIslandBoy is one of the sharper tools in the shedTexasIslandBoy is one of the sharper tools in the shed
TexasIslandBoy's Avatar
TexasIslandBoy's Tacoma Gallery
you need at least a 17 inch rim and 4.5 inch of back spacing to fit on the front the spindle that comes with the kit is beefy
Old 01-13-2010, 11:13 PM   #5
GEARAHOLIC is one of the sharper tools in the shedGEARAHOLIC is one of the sharper tools in the shedGEARAHOLIC is one of the sharper tools in the shedGEARAHOLIC is one of the sharper tools in the shedGEARAHOLIC is one of the sharper tools in the shedGEARAHOLIC is one of the sharper tools in the shedGEARAHOLIC is one of the sharper tools in the shedGEARAHOLIC is one of the sharper tools in the shedGEARAHOLIC is one of the sharper tools in the shedGEARAHOLIC is one of the sharper tools in the shedGEARAHOLIC is one of the sharper tools in the shed
GEARAHOLIC's Avatar
GEARAHOLIC's Tacoma Gallery
yeah you need to run 17" rims... are you sure you dont want to save for LT??? if you go with the stage 2 pro comp kit, upgrade to the MX6-R remote resivor shocks...they are much better than the mx-6 shocks that come with the kit...they are only about $100 more each.
Old 01-14-2010, 11:24 AM   #6
Motoxerc0's Avatar
Alright thanks alot everyone for all your help. Next question...since i can't justify spending thousands of dollars on wheels and tires would these Cragar Soft 8's work (link provided below)and also one of those hub centric rings?
http://www.summitracing.com/parts/CRR-3978860/
WTB: Pro Comp 6" Stage II Coilovers Jay238 2nd Gen Tacoma Marketplace 10 03-28-2012 02:24 PM
pro comp stage II v fabtec dirt logic w/ coilovers JRSYJAY Suspension 2 10-09-2011 03:15 PM
Pro Comp Stage I or Stage II which is better in the long run!! beans20 Suspension 1 12-15-2010 11:50 AM
Pro Comp stage II Stillfly199 Suspension 2 05-06-2009 03:20 PM
Best price for Pro Comp 6" Stage II SuperD Suspension 0 01-30-2009 05:45 PM
