| Register | Search For Products | Site Information | Glossary | Calendar | Search | Today's Posts | Mark Forums Read |
#1 |
Timbren's Installed
questions have been posted about them and no one seems to have them?
so i started off by doing a lot of googeling and think they will work great for me i have a 5 lugger and no TBS available for springs, but i love the "gentleman's ride" think of them as a air bag spring helper but not the trouble of airbags several of the camping/trailer towing sites had post about how they work great no tail end drag, helps prevent towing wobble, improves cornering. with airbags you need to have access to a compressor to inflate and deflate when needed,and worry about a leak or torn bag. these just replace the rear "bump stops" think of them as a "longer extended variable resistance bump stop helper springs" . i have mine set for 1 inch clearance BUT the nice thing about them is not the classic "one size fits all" if you have a work truck you might need better help, using a snow blade, well if the standard settings don't work for you , you can install a shim, or contact the company and they can replace the rubbers with different types !they offer good tech support and want to make you satisfied with your suspension. i had no troubles but i did call the timbren help number and they said they will work with you to get the ride right and should be under warranty ! ( and it is a "life of the installed truck so with a tacoma that could be a long time) i ordered mine from http://www.truckspring.com/timbren_285.html was quite happy with the service and got free shipping and no taxes in 5 business days ;-D this is part of the install and you can see it is pretty easy to do, just remove rear bump stops and bolt up the timbren's and check the clearance ![]() they say jack up the body for spring clearance and remove the wheel, BUT i had room so didn't have to do either ! and the original check is without the truck loaded. this is a pic of the factory bump stop ( hard rubber, 4 inches from the bottom of the rubber to the top of the axle) ![]() this is a pic of the timbren's installed and you can see they are going to help a lot sooner than the bump stop on a load. but not interfere with normal driving there is no clearance trouble on the brake lines, just the camera angle and yes they are hollow ![]() it has not affected my normal driving ! still the good ride! and in a few days it will get a workout when i haul 90 ft of wooden fence material for a friend so after that load i will add to this post and talk about the ride and amount of sag and sway if any ok? NOTE: they do make front bump stops also, and most of the people with snow blades use them , so might be a answer for heavy front bumpers and such? |
#2 |
I do
I have had my rear Timbrens installed for about 4 or 5 months. I wasn't too keen on doing the suspension TSB because I love the way my truck rides. I think they work wonderfully.
__________________
(Mark) Silver 06 TSS Dbl cab long bed. Prerunner 4.0L V6, tow. http://www.wormhole7.com/taco.html |
#3 | |
ok a bit over 100 of the fencing material 6 ft and all green wood ( wet) and 24 2x4 x8 and the guy at lowels said it was too much ! ![]() no problems, no bottom out at all ! and the last few miles are on a wiggely up hill downhill road that is paved! the only thing i noted was stopping distance was just a bit longer! (load weight) now i measured the rear bumper loaded and unloaded and there was a 2 inch difference ! remember there is a 1 inch space before the timbren's even make contact with the axle. and even with that load it was still a "gentleman's ride" so for a lot of folks like me that do occasional hauling and don't want a harsh ride i would say this is a winner ! this is a shot from his driveway i backed in and slight downhill on the front !
#4 |
Like my shive haircut?
Great writeup. Thanks.
__________________
Tacoma World: One big happily dysfunctional family. |
#5 |
Pull my finger; never gets old.
You got me thinking. Thanks.
#6 |
www.wheelersoffroad.com has the timbrens also. I think like 150 for front or rear.
#7 |
My other ride has sails
That could come in handy if I pick up the trailer sailer I've had an eye on. Thanks Phantom!
__________________
"Life's journeys End is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...holy shit what a ride!" |
#8 |
Northern Alliance: padawan
I have them, It's a a must, I would never consider taking them off.
#9 | |
#10 | |
__________________
#11 |
Yeah i noticed that lol.
#12 |
THanks Phantom!
Just got a new five lugger and was concerned about just that problem. Super find. Will defintely get that done. Great writeup. THanks again! |
#13 |
tacoma man
think you will really like them, i used locktit when i installed. and it even helps out on body roll. i am a big fan of these and think they should be stock on the tacoma to begin with ! now i have a truck that can haul like a truck but still have a softer ride. NOTE for you 6 luggers the bump stops are different (on the rear axle)but the idea is the same with the 1 inch space ! and if you find you can't make that measurement or need a bit more travel, just call them and they will send shorter rubbers or hard rubber spacers for free. you can call them up and if you are lifted talk to them and get what you need the first time |
#14 |
Will these affect your ride in any way positively if I never carry any load in the back?
I just haul very light, but bulky items, gun cases, ocean kayak, model airplane stuff, camera equipment. So all of it is light, perhaps under 200 lbs. So, they won't tax the vehicle suspension and I will NEVER carry or tow anything. So, are these worth getting in my case? |
#15 |
I'd only get them if you had issues with bottoming out. 200 lbs should not be doing that.
#16 |
for all the friends north of the border i found out that
http://www.vanandtruckworld.com/ carries them ! ( and seems to be a bit cheaper than us price?) timbren does not sell direct ! |
| Display Modes | |
| Just installed my new cd player | surfsupl | 2nd Gen. Tacomas | 5 | 03-15-2008 06:50 PM |
| AVIC-Z2 installed | Manofs | Audio & Video | 20 | 02-12-2008 03:34 PM |
| Another amp installed | tigerdongal | Audio & Video | 0 | 11-01-2007 08:43 PM |
| Just Installed Hi Lift | CornDog | 2nd Gen. Tacomas | 1 | 10-29-2007 10:46 AM |
| NEW XR ROTORS Installed | TheArkansas"X" | 2nd Gen. Tacomas | 4 | 09-07-2007 05:55 AM |
