Bumpstops???
Discussion in 'Suspension' started by sandman427, Feb 26, 2010.
  1. Feb 26, 2010 at 10:51 AM
    sandman427
    sandman427 [OP] KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    ay fellas and ladies.... my boy Jon (JDKeller) and I were talking about bump stops and was wondering the difference between Timbern and King/Fox bumpstops... the Timbren from our understanding uses the stock place from the original Bumpstops correct..??? But about the King/Fox ones do u have to do some custom fabing in order it to work..??? and does it work with a "midtravel" setup...??? thanks
  2. Feb 26, 2010 at 10:57 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Timbrens are rubber and are bolt-on.
    The Fox & King bumps are pressurized canisters that are adjustable. The hit is softened by a piston moving against the pressurized nitrogen. Fabrication is definitely needed for mounting.
    Light Racing offers a bolt-on solution for a mid-travel setup that work incredibly well but will require you to cut up the stock bumpstop mounts.
  3. Feb 26, 2010 at 11:00 AM
    sandman427
    Amir
    BAMF TACO!!
    thanks bud... which one would be better for the desert..??? cuz it sounds like the timbren is good for not bottoming out when having a load in the truck..??? correct me if i am wrong...??? and where would the kings mount to if there were any fab done..??
  4. Feb 26, 2010 at 11:06 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    Get some real bumps and cans Amir. The timbrens are bouncy bc its just a rubber piece with a particular pressure. The fox and king bumps are like a short shock with pressurized nitrogen so it does a much better job of dampening a compression and Im sure the rebound profits as well
  5. Feb 26, 2010 at 11:09 AM
    mjp2
    NJ
    You'll definitely want the air bumps in the desert. You'll remove your stop bumpstops and grind the bumpstop brackets off the frame. Take a flap disc on your angle grinder to smooth the frame itself and you'll have a clear spot to start welding the new bracket. :thumbsup:
  6. Feb 26, 2010 at 11:10 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  7. Feb 26, 2010 at 11:10 AM
    sandman427
    Amir
    BAMF TACO!!
    yea kinda was thinking that... cuz the timbrens are cool and all but not for desert IMO... but u dont need a long travel setup to use em right...???
  8. Feb 26, 2010 at 11:12 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    listen to MJp2. whatever he says goes. LOL. But no you dont need a LT setup to run them. Your gonna have to get custom mounting brackets made and added to the frame for them to work with your setup though.
  9. Feb 26, 2010 at 11:12 AM
    sandman427
    Amir
    BAMF TACO!!
    i like those.... but does that red bracket come with the setup...???
  10. Feb 26, 2010 at 11:13 AM
    sandman427
    Amir
    BAMF TACO!!
    right on.... MJp2 is the man lol... and u too manny....
  11. Feb 26, 2010 at 11:14 AM
    mjp2
    NJ
    Yep. Here's how it looked on my truck when I was mid-travel:
    They're amazing and I would have kept them but needed the space to clear a secondary bypass shock on my truck.
  12. Feb 26, 2010 at 11:14 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    no, people have run them on stock lower arms
  13. Feb 26, 2010 at 11:14 AM
    mjp2
    NJ
    :humble:
    :laugh:
  14. Feb 26, 2010 at 11:15 AM
    sandman427
    Amir
    BAMF TACO!!
    right on... ay do u have a pic of the rear im kinda curious on were they mount at...??
  15. Feb 26, 2010 at 11:16 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
  16. Feb 26, 2010 at 11:18 AM
    sandman427
    Amir
    BAMF TACO!!
    this might be a dumn question but will the front bumps damage your LCA... if compressed to much..???
  17. Feb 26, 2010 at 11:18 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
  18. Feb 26, 2010 at 11:19 AM
    mjp2
    NJ
    This:
    Changes to this:
    Note that they DO NOT work with the u-bolt flip kit. Ignore that part of the picture.
  19. Feb 26, 2010 at 11:20 AM
    mjp2
    NJ
    Less than the stock bumpstops would. Run your truck hard enough and you can break pretty much anything. ;)
  20. Feb 26, 2010 at 11:20 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
