Rear shocks up OR down
Discussion in 'Suspension' started by Carone, Mar 8, 2010.
  1. Mar 8, 2010 at 10:00 PM
    Carone
    Carone [OP] Well-Known Member
    NOR CAL
    LOOK HERE!!! 02 TRD xtra cab v6 4x4 white
    Look at my Build
    I just finished putting in my lift and i installed the Billys 5125s in the rear and i put them Boot up to keep them out of the water but the stockers are boot down and say on them TOP, on the top side.
    so does it matter?
  2. Mar 8, 2010 at 10:26 PM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    doesnt matter, either way is fine :)
  3. Mar 8, 2010 at 10:30 PM
    Carone
    NOR CAL
    Look at my Build
    i was reading and it said gas charged doesn't matter but fluid charged does
  4. Mar 9, 2010 at 8:55 AM
    BUZZ5
    BUZZ5 Well-Known Member
    S.Carolina
    07 Prerunner DC TRD Sport
    Many
    I have my 5125's the other way, with boots down. They sent them to me with the adapters already on the top end.
  5. Mar 9, 2010 at 8:58 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    x2, but I have already torn a couple boots offroading..
  6. Mar 9, 2010 at 9:02 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    my 5125s are boot up.
  7. Mar 9, 2010 at 9:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It does matter. The rebound, and compression dampening rates are different. With the Billies, they are mounted correctly when the words are correctly oriented.
  8. Mar 9, 2010 at 9:28 AM
    Carone
    NOR CAL
    Look at my Build
    OK i just got off the phone with Bilstein, and the answer i got was a little unclear.
    He said "a good rule of thumb is if you can read our name there are installed correctly, so if that means the boot is down although it might look a little funny that correct."
    Me: so is that a good rule of thumb or will it effect the ride and shock,, even gas filled.
    him "normally they are designed so our name can be read."
    Jut called All-pro
    Me: i had a question about the rear shocks for the 3" lift kit do they mount boot up or boot down?
    All-pro: boot down (with an immediate answer so questions asked!)
    So i looks like i found something to do today.
  9. Mar 9, 2010 at 9:44 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    X2
  10. Mar 9, 2010 at 9:46 AM
    dylandercole
    Dylan
    crap. I gota flip mine around then
  11. Mar 9, 2010 at 10:06 AM
    Carone
    NOR CAL
    Look at my Build
    its all good it took about 15min on my back in the driveway.
