Need some advice
Old 03-13-2010, 08:14 AM   #1
ZonKs [OP] ZonKs is offline
Can speak french in Russian.
ZonKs is a splendid one to beholdZonKs is a splendid one to beholdZonKs is a splendid one to beholdZonKs is a splendid one to beholdZonKs is a splendid one to beholdZonKs is a splendid one to beholdZonKs is a splendid one to beholdZonKs is a splendid one to behold
ZonKs's Avatar
ZonKs's Tacoma Gallery
Need some advice
Hey everyone,
Recently i changed the differential oil in my truck. Its a prerunner so it only has a rear differential (no LSD). I used 80w90 Lucas oil, used the correct amount, etc. etc. Right after, i took it for a test drive and it was rough as hell. It kind of felt like i was driving on gravel. Very jerky (for lack of a better word ). The ride continued to be EXTREMELY rough. I recently had the suspension TSB completed, but this was prior to the problem. Actually after I had the TSB completed i loved the ride quality. It was only after the differential oil replacement, that the ride quality went to shit (Imagine riding over a road that is nothing but 1 inch high speed bumps placed 1 ft. apart).
I needed to have my 5100's and BFG AT's installed. So I did thinking this would somewhat improve the situation. It did, but only to a certain degree. The extremely rough ride is still present. Some times on a rough section of the freeway, it feels like i could literally bounce out of the lane into the next one. Its horrible and i either need to get it corrected or sell the truck. This SUCKS.
Also wondering why there are no numbers for caster, SAI or Included Angle on my sheet...
Old 03-13-2010, 08:26 AM   #3
DDD DDD is offline
Shine bright like a hymen
DDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shed
DDD's Avatar
DDD's Tacoma Gallery
If you have the e-locker then you should not need to add the LSD additive.
Not sure how changing the diff fluid would cause your truck to bounce out of the lane...
Old 03-13-2010, 08:56 AM   #4
ZonKs's Avatar
You and me both...
Old 03-13-2010, 10:12 AM   #5
pataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud ofpataco has much to be proud of
pataco's Tacoma Gallery
x2,something else is going on there.im stumped other than are your wheels tight to the truck if you had them off(dont know why)to do the rear diff.?
Old 03-13-2010, 11:16 AM   #6
Tim A has a brilliant futureTim A has a brilliant futureTim A has a brilliant futureTim A has a brilliant futureTim A has a brilliant futureTim A has a brilliant futureTim A has a brilliant futureTim A has a brilliant futureTim A has a brilliant futureTim A has a brilliant futureTim A has a brilliant future
Tim A's Avatar
Air Force: TSgt
Tim A's Tacoma Gallery
Give your rear suspension a once over to make sure nothing is loose? Weird that it happened after the diff oil change though...
Old 03-14-2010, 08:59 AM   #7
ZonKs's Avatar
Anyone have any more ideas? I'm really stuck here.
Thanks again.
Old 03-14-2010, 09:25 PM   #8
ZonKs's Avatar
awesome thanks
need help/ advice!!! thebaker Suspension 3 11-15-2011 04:47 PM
Need some advice or help Casey05Taco Audio & Video 2 09-21-2011 11:54 PM
Advice TACOMA TRD 2nd Gen. Tacomas 12 04-27-2011 04:10 PM
XM Unit advice (General electrical advice actually....)HELP! 11BSSG 2nd Gen. Tacomas 1 11-27-2010 05:50 AM
so advice? travis9287 Audio & Video 4 08-19-2010 09:54 AM
