Lift w/ Rake or Lift & Level?
Discussion in 'Suspension' started by All Beef Taco, Apr 21, 2010.
  1. I lifted and maintained rake
    264 vote(s)
    50.7%
  2. I lifted and levelled
    258 vote(s)
    49.5%
  1. Apr 21, 2010 at 3:57 PM
    All Beef Taco
    All Beef Taco [OP] Well-Known Member
    Joe
    Thornton, CO
    2010 TRD Off-Road DC 4x4
    Rattle canned wheels, Weathertech Floormats, Undercover Tonneau, DIY Hi-Lift jack bed mount, Demello Sliders, ARB Bumper w/ ARB Fogs + anytime fogs mod, IPF 968's, Warn M8000 w/ Amsteel Blue & Billet 4x4 Hawse Fairlead, Rear Leaf TSB, Toytec Adjustable Coilovers and AALs, Rear Bilstein 5100's, BFG MT KM2's, Safari Snorkel, Rear Diff Breather Mod
    I'm curious to see what most folks have done with their given lifts setups. Did you lift and level, or did you lift and maintain a rake? Please chime in with your setup specs and height measurements if possible.
  2. Apr 21, 2010 at 4:04 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    I installed 5100's at 1.75" in the front and 1.5" aal's and 5100's in the back. I was hoping to have just a slight rake like the factory stance and it came out pretty close. I often carry loads and do not want to sag and bottom out.
  3. Apr 21, 2010 at 4:38 PM
    jandrews
    '09 FourDubDee TRD OR
    Rake for load carrying.
  4. Apr 21, 2010 at 4:47 PM
    All Beef Taco
    Joe
    Thornton, CO
    Guess I should also have asked: if you lifted and kept a rake, what is your height difference front and back, post-lift?
  5. Apr 21, 2010 at 4:52 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    i got 5100s all around with OME 883 lifting springs which raised the front about 1 1/2"-2".....so it still has a rake but the rake is only about an inch rather than the almost 3" rake it had stock
  6. Apr 21, 2010 at 5:31 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I have rake, I dont want it but its there.
    OME 9000s with 885s
    Toytec 1.5 aal
    This was a few months ago, its almost gone now just on the drivers side there is still the rake, but i just picked up the .25 spacer so it will be gone soon
  7. Apr 21, 2010 at 5:34 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    I have 3'' of lift in the front and 2.5'' in the rear. Its about an inch higher in the rear. I love how the rake on mine looks
  8. Apr 21, 2010 at 5:57 PM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    I really wish I had a rake but my truck is pretty level (rake measures 1/4"). I am sure it is due to my fiberglass topper weighing a couple hundred pounds. I have actually been thinking of going to some dakar rear leafs to get the rear up a little higher than my 1.5" AAL. I really liked the way the truck sat with rear suspension tsb, no top, and stock suspension.
  9. Apr 21, 2010 at 6:07 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    y would u wanna lift n not level it? mite as well not lift at all
  10. Apr 21, 2010 at 6:08 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    I maitained a rake. I have billy all around set 2.5 in the front and a toytec AAL. My rear is about 1 inch higher at the most.
  11. Apr 21, 2010 at 11:27 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Mine has leveled out pretty well.
  12. Apr 22, 2010 at 12:35 AM
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Sierra Vista, AZ
    looks to me like your 885's sagged.
  13. Apr 22, 2010 at 11:20 AM
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    At first I had mine level cause I left out one of the leafs to keep it level. Then I was having bottoming out problems when I was off road and having a heavy load in the bed. So I installed the other leaf and now I have the rake. Similiar to stock. I like it and truck rides better to me. Just my 2 cents.
    AutSux likes this.
  14. Apr 25, 2010 at 7:27 AM
    StandingCow
    StandingCow Well-Known Member
    John
    NJ
    09 SR5 4x4 V6 access cab
    Slight rake.
  15. Apr 25, 2010 at 8:06 AM
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    I have been noticing that almost all of the lifted domestics I see around town have a negative rake. I don't get it.
  16. Apr 25, 2010 at 10:07 AM
    kilgoja
    Alabama
    :mudding:
    cuz when you haul something in the back the front will be alot higher than the rear if it's perfectly level when nothing is in the back....the rake is there so when you haul something the truck will still sit pretty level...plus it just looks better to have a rake...the problem is the factory rake is just too much...mine was 3"...now it is 1" and when i put my atv in the back it's pretty much level.....and it gives you more room under the front wheel well to fit bigger tires in there too
  17. Apr 25, 2010 at 10:10 AM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    mine has leveled out quite nicely
  18. Apr 25, 2010 at 11:42 AM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    I don't like trucks that sit ass high. Level or reverse raked is my fave. I prefer a little ass low, but just a little.
  19. Apr 25, 2010 at 2:33 PM
    DARK TRD
    DARK TRD Well-Known Member
    Bartlett,IL
    All Black TRD Sport
    ez lift 3inch plus 1 inch block custom flat black trd black stickers same style as stock black badges from toyota black headlights tinted windows satoshi grille with grillcraft grill vinyl tinted tail lights
    i did the the three inch leveling kit it came with 3 in for front and 2 in aal for back i had my wife drive it and i looked at it driving it looked like it was going to start flying like 747 it looked fine parked but not cool driving so i added a 1 in block looks perfect just like stock but threee in higher
  20. Apr 25, 2010 at 3:26 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    When measuring mine, the back actually sits 1/2" higher than the front, though it doesn't look like that:
    AutSux, jafrisi and Wakecoach like this.
