Bilstein 5125 shock install boot up or down?
Discussion in 'Suspension' started by cmf21, May 17, 2010.
  1. May 17, 2010 at 9:09 PM
    cmf21
    cmf21 [OP] Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    Which way should the boot be facing. Up or down? Don't want anything hitting anything and damaging the shock.
  2. May 17, 2010 at 9:11 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    you want the "bilstein" upright and readable. On mine thats boot down. I installed mine boot up and havnt switched it since and I have had no problems
  3. May 25, 2010 at 4:53 AM
    375taco
    375taco controlled pair?
    2010 TRD Sport 4x4 DC SB
    OME lift w/ 1" spacer. Built Right UCA's. Tinted all the way around. De-badged. Trimming up front
    I have heard different you want the boot down...i could be wrong
  4. May 25, 2010 at 4:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    Boot up
  5. May 25, 2010 at 5:22 AM
    375taco
    told you i could be wrong...haha
  6. May 25, 2010 at 12:54 PM
    The Parts Whore
    The Parts Whore Slinging parts since '03
    No, you're right. Ben's wrong. :p
  7. May 25, 2010 at 12:55 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yeah, 5100 is up
    5125 is down..
    :anonymous:
  8. May 25, 2010 at 1:03 PM
    98tacoma27
    Ben
    Not Beech Creek
  9. Apr 2, 2014 at 9:39 PM
    lilcoues
    lilcoues Member
    Tucson, Arizona
    02 Tacoma TRD
    4" lift, 33" tires
    If your Bilstein Shocks in the rear of your Tacoma are 5125's, The boot faces down. I made the mistake of installing them boot up and almost ruined my Bilsteins. If you look at the boot you'll see the only holes in it are at the top of the rod. If you installed your own shocks, you woud have seen the 1/4" indentation on the top of the body of the shock. With the shock in the boot up position, any dirt, dust, water that enters the boot will accumulate in that 1/4" indentation all the way down to where the plastic tie wrap straps the boot to the shock. Causing the shock to rust up to 3" of the body under the boot. Trust me, turn it around so that your boot faces down and save your shocks.
  10. Apr 2, 2014 at 10:18 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    My old receipt from Wheelers on my old setup states to mount the 5125's with the canister up meaning boots down:
