6" lift and rear leaf under?
Old 06-05-2010, 07:11 PM   #2
nelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shed
nelson18matt's Avatar
Air Force: Ex-Cone
nelson18matt's Tacoma Gallery
are you talking about a spring under axle set up w/ a 6" DB lift in front?
Old 06-06-2010, 08:54 AM   #4
allrsdup has much to be proud ofallrsdup has much to be proud ofallrsdup has much to be proud ofallrsdup has much to be proud ofallrsdup has much to be proud ofallrsdup has much to be proud ofallrsdup has much to be proud ofallrsdup has much to be proud ofallrsdup has much to be proud of
allrsdup's Tacoma Gallery
spring under axle will lower the truck just get a new leaf pack.
Old 06-06-2010, 10:31 AM   #6
Screw your MPG's
jacob_wood is one of the sharper tools in the shedjacob_wood is one of the sharper tools in the shedjacob_wood is one of the sharper tools in the shedjacob_wood is one of the sharper tools in the shedjacob_wood is one of the sharper tools in the shedjacob_wood is one of the sharper tools in the shedjacob_wood is one of the sharper tools in the shedjacob_wood is one of the sharper tools in the shedjacob_wood is one of the sharper tools in the shedjacob_wood is one of the sharper tools in the shedjacob_wood is one of the sharper tools in the shed
jacob_wood's Avatar
jacob_wood's Tacoma Gallery
Send a message via AIM to jacob_wood
subbed.
Old 06-07-2010, 08:51 AM   #7
Air Force: Ex-Cone
w/ a 6" front DB lift and rear SUA (long travel) the truck will not sit level or perform well.
you'll have a performance rear susp and just a lift kit up front. the front DB lift will not be able to hang w/ the rear at all and it'll break when you try to hit some whoops, plus that way to high of a center of gravity for high speed stuff.
if you looking to use the truck offroad, it's not the route you want to go. a rear SUA set up will only give you about 3" rear lift, maybe a little more but not enough to level the front w/ a 6" DB.
FS: ’98-’04 Rear Leaf Springs 2"-3" Lift Digiratus 1st Gen Tacoma Marketplace 30 04-09-2011 06:24 PM
1 1/2" Lift rear add-a-leaf for Tacoma with rear TSB springs TRICOMA 2nd Gen Tacoma Marketplace 8 04-06-2011 07:14 AM
Rear leaf springs 3-4" lift? pyro13g 5 Lug 6 02-01-2011 12:09 PM
Who here has a 6" lift and new rear leaf springs 07tacoswb 2nd Gen. Tacomas 0 09-10-2010 11:56 AM
Do I want the Rear Leaf TSB if I'm going to install a 3" lift with an AAL rear? Bighit Suspension 12 10-12-2008 08:33 PM
