Tacoma World Forums tigerfan00's 2002 red Xtra Cab Toyota Tacoma off-roading
Register Site Information Glossary Calendar Search Today's Posts Mark Forums Read
Lift for 06 Access cab 4x4
Old 06-01-2008, 05:18 PM   #1
Bmedic50 is on a distinguished road
Air Force: Medic, 22 Special Tactics Squadron
Bmedic50's Tacoma Gallery
I'm planning on lifting my truck to add some bigger tires and gain some ground clearance. Most likely will go with some 17" XD wheels and 285/70 BFG's. The original method I was going to go with was a 2" "puck?" Im not sure if that is the spacer everyone is talking about but Im curious how/where it is installed. Also, is this the same as the leveling kit? Once I actually went to a 4x4 shop to price the whole thing, they recommended going with a coil kit with AAL's for the rear. Im just curious what is the best method for durability and ride. I also want to keep the angles on my drive train to a minimum but still be able to fit the wheels.
Old 06-01-2008, 05:20 PM   #2
silver07taco will become famous soon enoughsilver07taco will become famous soon enough
silver07taco's Avatar
silver07taco's Tacoma Gallery Send a message via AIM to silver07taco
I have a 3'' tuffcounty lift with a space up front its alright if your not goin to wheel your truck i am cheaging it out for coils i also have the AAL in there rear thats workin just fine, Asfar as tires go i have 265/75/16 no rubbing there
Old 06-01-2008, 05:24 PM   #3
Western Alliance: no longer dead.
chris4x4 has a brilliant futurechris4x4 has a brilliant futurechris4x4 has a brilliant futurechris4x4 has a brilliant futurechris4x4 has a brilliant futurechris4x4 has a brilliant futurechris4x4 has a brilliant futurechris4x4 has a brilliant futurechris4x4 has a brilliant futurechris4x4 has a brilliant futurechris4x4 has a brilliant future
chris4x4's Avatar
chris4x4's Tacoma Gallery
The coils wil give a better ride. If you lift, you are going to change your angles. If you end up with vibrations, there are a few things you can do to fix them.
__________________
The simplest solutions are often the most clever..............they are also usually wrong.
Old 06-01-2008, 05:28 PM   #4
Silver,I saw there were 2 types of AAL's. One came with a block and the other did not. Which do u have and do u know which is better? Also, I'm looking to go with 17's for my wheels. How much clearance do u have?
Old 06-01-2008, 05:29 PM   #5
Chris,Yeah I dont need vibrations! Are they common and how do u fix them. Also, do u recommend a front diff lowering kit to minimize the angles?
Old 06-01-2008, 05:38 PM   #6
chris4x4's Avatar
I lifted the rear almost 2" and have no vibrations. Just a hint on take-off, but nothing you really notice. And its from my carier bearing. The diff drop cant hurt. Vibes seem to be hit or miss on the Tacomas. SOme people get them, some dont. I have never had any vibrations, personally, on any of my trucks that I have lifted. BUt, back to your question, yes, they are an easy fix. There are shims for the axel to fix the pinion angle, carier bearing drops, etc. Also, for the block vs. AAL, I use AAL's. Blocks can break (aluminum), and/or cause premature wear on your leaf pack. A good spring shop can custom make an AAL for you for about the same price that you would pay for one online. Thats the route I took, and the ride is much better than it was when stock. And it takes BIG hits OOoohhhhh SSooooooo smooooth.
__________________
Old 06-01-2008, 06:13 PM   #7
I have the leaf i dont like blocks for offroad. I have plenty of clearance.
Old 06-01-2008, 06:39 PM   #8
Alright...so if I just go with the 2" puck/spacer up front and AAL on the rear. What size tires can I go with? 17's?
Old 06-01-2008, 06:44 PM   #9
chris4x4's Avatar
That would be a wheel size. Stick with a 32" tall 10.5 inch wide for no rubbing issues. Or you can push it a little and get some 33X 11.5's and trim accordingly.
__________________
Old 06-02-2008, 01:19 AM   #10
my tire sizes it about 32 youll be good with that without trimming.
Old 06-03-2008, 08:20 PM   #11
Last Question...So Ive been looking around and noticed a few different lifts. My plan is to go with the 3" basic kit from either toyec or revtec. I actually seem to like the revtec better. I'll go with the AAL option. I went to a shop and saw a few they were doing. After the lift they had 275/70 18's on there with only minor trimming. What do u guys think. Does this sound ok?
Old 06-03-2008, 08:46 PM   #12
chris4x4's Avatar
Sounds good, but can you spend a bit more and get the coil springs? Better ride than the spacers.
__________________
Old 06-03-2008, 09:19 PM   #13
chris...I have the same truck as you. How big (what brand too) is your lift and what size tires/wheels did that allow for? Did you have to trimming?
Old 06-03-2008, 09:25 PM   #14
chris4x4's Avatar
Front = OME shocks, OME 885 springs, Total Chaos UCA's
Back = TSB leaves, custom made 1" AAL, Bilstien 5100 shocks.
Wheels are Helo Maxx 6 18x9
Tires are Nitto Terra Grapplers 285/60/18 (roughly 32")
No rubbing unless compressed and turning. I havent trimmed as I want to see if I can grind it away with the tires.
__________________
Old 06-21-2008, 08:40 PM   #15
Chris, do u have any close up pics of your tires/wheels. I would like to check the clearance.
Old 06-21-2008, 08:53 PM   #16
chris4x4's Avatar
Is this what your looking for?
__________________
Old 07-22-2008, 04:56 PM   #17
mcdufws is on a distinguished road
mcdufws's Tacoma Gallery
So is this correct? you have 5 leaf springs? TSB and AAL added to that.
Old 07-22-2008, 05:35 PM   #18
chris4x4's Avatar
Yep.
3 main leafs + AAL + Overload leaf = 5
__________________
Display Modes
4-Cyl Access Cab 4x4 w/ SR #2 pkg & Fog lights khfactor 4 Cylinder 2 08-12-2008 08:27 AM
2008 Tacoma Access Cab 4x4 4-cyl khfactor 2nd Gen. Tacomas 44 11-12-2007 10:44 AM
1993 Access Cab 4X4 Hand Shaker V6 TruckPro Buy / Sell / Trade 2 10-29-2007 08:19 AM
06 Red Tacoma Access Cab TRD 4x4 For Sale Slvr_DblTaco Buy / Sell / Trade 5 10-26-2007 02:25 PM
2005 Tacoma 4x4 Access Cab-Indiana ludlow Buy / Sell / Trade 0 08-23-2007 05:20 PM
Copyright © 2008 Tacoma Forum
