3" suspension lift
Old 06-08-2008, 07:11 PM   #1
jwp164 [OP] jwp164 is offline
jwp164 is on a distinguished road
jwp164's Tacoma Gallery
3" suspension lift
I am getting a 2008 Tacoma here shortly and already have on order a 3" lift kit that has add-a-leafs for the back and a 3" strut spacer for the front, the truck stock I think has 265/70R17 tires/wheels, will I be able to fit a 285/75R16 with any problems after the lift? I think that conversion comes out to like a 33"X11" right? I do not wish to do any trimming since the truck will be brand new, and with the add-a-leaf in the back, will the stock Bilstein shocks in the rear be sufficient or will I need to upgrade to a longer shock? The kit also comes with a differential drop so I will not change the angle of the front axles.
Old 06-08-2008, 07:18 PM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
Even with the diff drop, it will change the angle of the axel. The OEM Bilstiens are not made for a lift, and you may have an issue with the shocks "topping out". A simple switch to some 5100's should fix the problem. AS for the tire size, you will have some rubbing, but to what degree depends on the wheel back space, and such.
Old 06-08-2008, 07:20 PM   #3
Thank you, the wheels I think I am going to get are moto metal 16X8 that have a 4.5" inch backspacing, the 5100's are those made by Bilstein?
Old 06-08-2008, 07:21 PM   #4
chris4x4's Avatar
Yep. And they are a VERY good shock.
Old 06-08-2008, 10:23 PM   #5
skierpunk is on a distinguished road
skierpunk's Tacoma Gallery
I'm also about to get a lift on my o8. Are most people swithing out for the 5100 or remaining stock?
Old 06-09-2008, 04:14 AM   #6
Khaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shed
Khaos's Avatar
Khaos's Tacoma Gallery
You will rub with a 285/75 no matter what wheels you are. Trimming is going to be necessary. Its not that much. You could go untrimmed and see where you have a problem area and then just trim there. That way you don't do anything that you don't have to.
Poll "Spacer lift vs. Suspension Lift" JoeyTacoma Suspension 81 03-19-2012 03:03 PM
Can I add a 2" body lift to my 3" suspension lift and not have problems with the VSC blue86gt 2nd Gen. Tacomas 17 08-10-2011 10:14 PM
35"s or 33"s on 6" Suspension Lift Chasetyler19 Suspension 3 05-13-2010 04:00 PM
Toytec 3" Spacer Lift w/ AAL or the Pro Comp 3" Suspension Lift hawaiian_fantasy Suspension 1 04-12-2010 03:30 PM
Is this a good lift. Pro comp 3" suspension lift/top gun customz MikeyD Suspension 23 10-21-2009 07:49 PM
