UBolts
Discussion in 'Suspension' started by dgr540, Jul 12, 2010.
  1. Jul 12, 2010 at 3:59 PM
    dgr540
    dgr540 [OP] I've got the FUNK
    Friendswood, TX
    2013 Wrangler Unlimited
    XDs Trail grappler 35x12.5x18 Winch 8K lbs Front bumper 4in Lift
    I have the TSB done and I am about to order a toytec AAL, my question is if I am going to need new ubolts. I am also installing 5100's all around.
  2. Jul 12, 2010 at 4:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    U bolts are not a re usable bolt, technically. However, if they arent too old, I have re used them in the past.
  3. Jul 12, 2010 at 4:10 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    I think hes asking if they are long enough. With a TSB and an Add-a-leaf you will need longer U-Bolts. Chris will confirm.
  4. Jul 12, 2010 at 4:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Actually, The U bolts used on teh TSB spring pack are long enough to accomodate an AAL.
    OP, Check to make sure you have about 1/2" of thread showing on the U bolts.
  5. Jul 12, 2010 at 4:19 PM
    PreRunnerSeth
    Apex, NC
    Gotcha... I've installed too many. It gets to be a blur on which needs them and which don't. I remember thinking that the TSB also came with slightly longer u-bolts, but I wasn't %100 sure.
  6. Jul 12, 2010 at 5:06 PM
    dgr540
    Friendswood, TX
    Thanks!
