spacers+ome coils?
Discussion in 'Suspension' started by blakelundy, Jul 16, 2010.
  1. Jul 16, 2010 at 2:54 PM
    blakelundy
    blakelundy [OP] Member
    is it possible to put 3" spacers AND put the ome coils on the front of a 2007 tacoma? so i think it would be around 4" of lift in the front?
  2. Jul 16, 2010 at 2:57 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    OME coils themselves are supposed to provide about 2.5"s of lift. And no, do not combine the two!!
  3. Jul 16, 2010 at 3:05 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    You can only combine the ome with the top plate spacers to give 3 of lift. If you want 4 and have a prerunner get spindles or a db kit rcd kit for 4.5 iirc
  4. Jul 16, 2010 at 9:16 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    if you stack lifts you die
  5. Jul 16, 2010 at 9:17 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    not physically possible... think about it for a few minutes (ie. shock length, cv boots (if 4wd))
  6. Jul 25, 2010 at 8:00 PM
    wtbthree
    wtbthree Give 'er
    Will
    Colorado Springs, CO
    SC'ed 2010 DC
    3" Revtek lift, 17" FJ rims, 285 BFG KO's, sunroof, TRD piping, Wickedflow muffler, Avid step rails TRD supercharger,
    I'm thinking about pulling out my 3" Revtek spacers due to the rough ride they have. Could i throw in some OME coils and keep my same ride height, but end up with a softer ride?
  7. Jul 25, 2010 at 8:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes.
  8. Jul 25, 2010 at 8:03 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    OME coils still have a stiff ride, but softer than coil spacers.
  9. Jul 28, 2010 at 11:26 PM
    Beeson
    Beeson Well-Known Member
    Seattle
    '96 Tacoma SR5 4x4
    33" Goodyear Wrangler Duratracs, 15" Unique Steelie rims, Allpro wheel spacers, Heavy Old Man Emu coils, struts, shocks, leaf springs, Daystar 1" spacer, Camburg UCAs, 1" diff drop, NO sway bar, Allpro sliders, Allpro Rear bumper, Bushwacker fender flares, Tire Gate with spare, ARB Deluxe bumper with Hella 700s and 100w bulbs, 100w lights under frame pointed at tires, 50w lights on bumper for reverse, K&N Drycharger with cover, Flowmaster cat-back with custom 2-out exhast, DeeZee tool box, Huskey Liners, 5% window tint, JVC iPhone/CB compatable deck, Bazooka sub, sony speakers, Uniden CB w/4 ft. anntenna, Dixie Horn.
    I literally just went from a 3 in. Revtech to OME all around two weeks ago, and I love it!! My 33 in. tires still work great with it, no problems. Still it would be nice to have a bit more lift. I will probobly throw on the spacers it came with (which add a tiny bit more lift in the front). OMEs run a little higher in the back than in the front, and yes, it is harder (I got the HD coils) and not so loosy goosy as the Revtech. Handling is insane. I've never been in a lifted truck with such good handling.
