-   -   Caster Pro Comp 6 inch (http://www.tacomaworld.com/forum/suspension/109235-caster-pro-comp-6-inch.html)
scottj 08-20-2010 12:20 PM
So I took my truck to get realigned after reading some alignment threads. They could only get the caster up to around 2. Is this common? Truck has Pro Comp 6 inch basic. The steering seems to bounce all around with every bump so I thought getting the caster up might help. I also dropped the Nitto Trail Grapplers down to 32psi. The guy at the local 4WD shop says the Tacoma is sensitive to M/T's and there will be steering wheel shake no matter what. Any ideas?
