-   -   what is the maximum lift before premature front end damage? (http://www.tacomaworld.com/forum/suspension/111443-what-maximum-lift-before-premature-front-end-damage.html)
millerlight2496 09-02-2010 10:04 AM
i have a 2003 tacoma v6 trd and want a small lift. i was thinking 5100's all around and aal in the rear. will i have to do any more to prevent premature front end damage?
Hillbilly Zombi 09-02-2010 10:09 AM
I would get the Diff. drop. Its cheap and might save your boots. I did the same set up w/o the diif. drop and my boots started leaking grease so I filled them up and put hose clamps from lowes on them and bought a diff drop. No problems since. Also tire size can play on the suspension as well, so I would recommend no bigger than a 32' or 265/75/16 tire.
Matic 09-02-2010 10:11 AM
save your money.
OME 881 coils from toytec in the front. AAL and procomps in the rear. 3 in level/lift.
millerlight2496 09-02-2010 10:17 AM
Originally Posted by Matic (Post 2131329)
save your money.
what model of procomp should i use in the rear?
thanks.
Hillbilly Zombi 09-02-2010 10:27 AM
just a front diff drop. I got 2.5 inches in the front and I added 1.5 fabtech aal in the rear with billies from downsouthmotorsports
Matic 09-02-2010 04:42 PM
thanks.
Not sure. PM the toytec vendor or call them. There extended length.
WATRD 09-02-2010 04:59 PM
It's really the boots that suffer, not so much the CV joints themselves. You are generally good into the 2-2.5" range, or 2.5-3" with higher angle boots. The CV's don't really care, though there is some anecdotal evidence to indicate that they are a bit easier to snap at higher angles, especially if you are spinning them and stopping them hard on the trails.
