Toytec lift
Discussion in 'Suspension' started by tacoma92, Sep 6, 2010.
  1. Sep 6, 2010 at 7:15 PM
    tacoma92
    tacoma92 [OP] Black Hole Sun
    Forrest
    Gulf Shores, Alabama
    09 SR5 Toyota Tacoma
    While my truck is in the shop ive been looking at suspension lift kits and found one that looks pretty good. The 3" lift with spacers, rear options, and rear shocks from toytecfor $319.99. Wat do yall think? Is this a good enough lift or are there better ones around the same price?
  2. Sep 6, 2010 at 7:16 PM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    dont do a spacer lift....
  3. Sep 6, 2010 at 7:21 PM
    tacoma92
    Forrest
    Wats the deal with a spacer lift?
  4. Sep 6, 2010 at 7:29 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    well I might be wrong but what about this option 5100 bilstein shocks and set them at 2.5'' setting and buy some 2.5'' blocks for the rear? I know nothing about suspension lifts but maybe this will work.
  5. Sep 6, 2010 at 7:36 PM
    quick7r
    quick7r Member
    Randy
    Antioch, Ca.
    06 tacoma TRD offroad
    *toytec 3" OME w/ AAL *Spidertrax 1.25" spacers *Procomp MX-6 Adjustable shocks out back *Pro Comp ES6000 up front *K&N drop in filter *Flowmaster 1 chamber dump *ARB Deluxe Bull Bar; Winch Mount Bumper *Smitty Built XRC8 w/ steel line
    you might as well go w/ the coil kit. not much difference in price.
  6. Sep 6, 2010 at 7:44 PM
    tacoma92
    Forrest
    that says tht its for 05 and up and i have an 01 4x4
  7. Sep 6, 2010 at 7:45 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  8. Sep 6, 2010 at 8:03 PM
    tacoma92
    Forrest
  9. Sep 6, 2010 at 9:00 PM
    tacoma92
    Forrest
  10. Sep 6, 2010 at 10:12 PM
    RideFast
    Jesse
    Tacoma
    Is is possible to use the 5100's on the front and set them up to the highest setting (without changing the UCA's or any other components) and do an AAL or block spacers or even shackles in the rear?
  11. Sep 6, 2010 at 10:20 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    yes on the front without new ucas
    aal yes, spacer yes (i wouldnt), i dont know if anyone has lift shackles
  12. Sep 6, 2010 at 11:14 PM
    RideFast
    Jesse
    Tacoma
    so for a decent lift (about 2.5'') you can do a set of 5100's and an AAL,
    a bigger tire and you have yourself a 3.5'' lift!
    I am pretty sure I am goin for a the 5100's when my oem shocks are worn out! The only thing I am not sure about is the rear lift. I have herd that AAL makes the rear end of your truck really stiff. Not sure if I want that???
    Why do you not recommend a spacer lift in the rear?
  13. Sep 8, 2010 at 3:37 PM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    search through some of the older threads and u will find the pros and cons of the spacer lift and all the other lift kits out there
  14. Oct 11, 2010 at 1:13 PM
    tacoma92
    Forrest
    Wow so wats the minimum height of lift needed to put m/ts on my 01 Tacoma?
  15. Oct 11, 2010 at 1:19 PM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Just FYI, I did a spacer lift on an 01 4X4 taco that I use to own. I was busting cv boots at the rate of about 1 a month. I had nothing but problems. I wish I had found TW back then and it would have saved me alot of aggrivation. IMO if I were you, I would save my money and get the ultimate lift from toytec. Please dont do a spacer lift....you will regret it.
  16. Oct 11, 2010 at 1:24 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    X agagillion billion
    I did the lift from the dealer ( 3" revtek ) just about done with my ultimate, just need to install coilovers and uca.....
  17. Oct 11, 2010 at 1:50 PM
    tacoma92
    Forrest
    Well I live on 20 acres of land and also go huntin in the backwoods so I will def need a reliable lift. still affordable too. And apparently spacer lift is out of the question haha. Will a 2.5 inch lift be big enough to put m/ts on my truck?
  18. Oct 11, 2010 at 2:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What size m/ts?
    If you have the stock 16" alloy wheels you can easily clear 265/75-16s (roughly 32"s) with a 2.5" lift.
  19. Oct 11, 2010 at 2:51 PM
    tacoma92
    Forrest
    Yea the rims that I have are tht size 16s
