-   -   for the experts (http://www.tacomaworld.com/forum/suspension/122777-experts.html)
bgbdwlf 11-10-2010 10:28 AM
for the experts
I have gathered my lift components and would like the experts to take a gander and see if I am covered and if I am missing anything that aren't on the list.
I have a pre-runner so didn't get a diff drop, so here is the list of parts I have put together so far.
5100's front and back.
Eibach springs.
.25 spacer.
2" AAL.
SPC/LR UCA's.
This is the plan, front 5100's @ .85 w/ eibachs, .25 spacer for the lean and UCA's. I know I may not need the UCA's but since I will have the front all apart, I figured do it know instead of having to tear it apart later.
Out back 5100's w/2" AAL.
I have all the tools and other need wrenching items so I am covered there.
bgbdwlf 11-10-2010 11:13 AM
got the longer bolts for the spacer.
good point i didn't even think about checking the u-bolts.
are you talking about the center pins in the leaf packs, if so i got those also plus 2 extra.
bgbdwlf 11-10-2010 12:15 PM
i see what you are saying now, i am only doing the single AAL it looks like you did 3 leaf pack, but i am still going to check the u-bolts and the keepers just to make sure. i only have a 2wd pre-runner and don't offroad much made some trail riding and thats pretty much it.
for the front 5100's i am working on getting some stock billies that someone as swapped out already. then i can disassemble them to pre-assemble the 5100's and then just swap the sets out and same some time.
ToyTec Lifts 11-10-2010 01:00 PM
Longer top plate bolts are not required for the 1/4 inch spacer. They are for the 1/2 spacer.
Longer U bolts are not required for the single AAL
:thumbsup:
-Dylan
bgbdwlf 11-10-2010 01:07 PM
:thumbsup:
-Dylan
sounds good, Thank you everyone for your input. :cheers:
I have some longer top plate bolts laying around so if do i am covered there. i didn't think i would need the u-bolts but i am going to check just in case.
X2 for Toytec they hooked me up on my stuff also, except the UCA's (sorry Dylan).
