Bed Noise??
Discussion in 'Suspension' started by r0ckymountain, Nov 17, 2010.
  1. Nov 17, 2010 at 3:20 PM
    r0ckymountain
    r0ckymountain [OP] Active Member
    Bruce
    Colorado Springs, CO
    08 Tacoma TRD
    K & N Air filter, Bug deflector, Roll-up tonneau cover, CB
    Ok, I had a loud clunk when going over minor bumps etc. and at first contributed it to the tailpipe and I installed a new gasket. Well it seemed to help some but now after checking the tailpipe it is tight there still loud clunk sounds when going over potholes bumps etc. Is it the leaf springs? The springs are my thought as when I hook my trailer on I don't hear them anymore. Is there something to do or it it the nature of the beast? Thanks
  2. Nov 17, 2010 at 3:21 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    You might be bottoming out. Check the strike pads for marks from the bump stops.
  3. Nov 17, 2010 at 3:23 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    this thread sounds derty:p.could be the leafs or shocks,have you checked all the bolts to make sure there tight?
  4. Nov 17, 2010 at 4:19 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    This might be totally unrelated, but do you have a trailer receiver hitch on your hitch mount? This will cause a clanking noise going over bumps since they are by nature a little bit loose. If this is the case, a cedar shim will fix your noise. Seems like a possiblity also considering the noise disappears when you trailer...
  5. Nov 18, 2010 at 7:16 AM
    r0ckymountain
    Bruce
    08 Tacoma TRD
    Thanks for the thoughts, Might pull the hitch out and check for noise then hadn't thought of that one.
  6. Nov 18, 2010 at 7:24 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    i bet its your hitch then
  7. Nov 18, 2010 at 10:25 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    99% sure it's your ball hitch. Mine clunks like a motherf***er.
  8. Nov 18, 2010 at 6:52 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 4 Cree LED lamps Bilstein 5100s Ride Rite Air Bags
    On my '05, one of the 4 bed bolts was a bit loose... tightened up, and the rattle was gone... Try it (need a special socket fitting)!
