ProComp 3" Suspension lift
Discussion in 'Suspension' started by rsxftw, Dec 5, 2010.
  1. Dec 5, 2010 at 2:42 PM
    rsxftw
    rsxftw [OP] Well-Known Member
    Tyler
    Santa Cruz
    09 DCSB TRD Off-Road
  2. Dec 5, 2010 at 2:52 PM
    mwells32
    mwells32 Well-Known Member
    Nolanville, TX
    '09 PreRunner DC
    5100 on all four corners, fronts set to "0", OME 885 coils, Toytec 2 in AAL
    Sub'd. Same question here.
  3. Dec 5, 2010 at 3:33 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    It's horrible. When I had it on my truck I couldn't stand it. Now I'm not saying that Pro Comp is running the original set-up from when they first put it out onto the market. They may have changed a few things. I would call them and ask what the spring rate is on those coils. When I had it, it was super stiff and I felt like I had no travel. I talked to Pro Comp and they said that there was a 718lb spring rate on their coils. Definitely made for after market bumpers and not for guys who are running stock bumpers. I didn't like it, but thats just my opinion. There are other people out here on this forum that do not have as many complaints as I did. So hopefully some of those other guys will chime in.
  4. Dec 5, 2010 at 3:34 PM
    rsxftw
    Tyler
    Santa Cruz
    Thanks for the input.
    Also, know of any place i can buy JUST the front shocks?
  5. Dec 5, 2010 at 3:35 PM
    jr114
    Jon
    SoCal
    Truck
    If you want to go with front shocks, I would advise going against the Pro Comps and using the 5100's.
    EDIT- I say that because of the adjustability of the 5100's and I believe that they also provide a little more travel. Which may help prevent a rough and bumpy ride.
  6. Dec 5, 2010 at 3:40 PM
    rsxftw
    Tyler
    Santa Cruz
    Yeah i hear ya, from my understanding they dont lift the front a full 3" though, only 2.75" correct?
  7. Dec 5, 2010 at 3:42 PM
    jr114
    Jon
    SoCal
    Truck
    Thats when used with the stock coil spring. Now say you set the 5100's at .85" and use the Eibach 1.6" coil spring youll get roughly 2.84". You could also use one of the OME springs say the 884 and leave the 5100s at 0 and achieve roughly 3"
  8. Dec 5, 2010 at 3:45 PM
    rsxftw
    Tyler
    Santa Cruz
    I see i see. Thanks for the info man
