Leveling Kit?
Discussion in 'Suspension' started by only49ersfan, Dec 13, 2010.
  1. Dec 13, 2010 at 8:56 PM
    only49ersfan
    only49ersfan [OP] Well-Known Member
    Myrtle Beach, SC
    09 Tacoma 4X4
    Not much. Step bars, K&N air filter
    So im considering doing a leveling kit on my 09 TRD Sport 4x4 Ac. Cab. Im not sure what the difference is in a "lift" and a Leveling Kit is. Also, if it would void any warranties through Toyota then Im not going to do it. I was looking at the Revtek kit which gives me 3" in the front and 1.25" in the rear. As always I try to do my research on this site before I buy anything. Maybe its the Miller Lites Ive been drinkinng since noon or Ive overlooked some stuff but Ive tried searching before asking and my questions have not been answered. I saw something about my front CV joints wearing early due to some suspension mods. Can someone either direct me to a previous thread or clarify my questions for me? Thanks guys
  2. Dec 13, 2010 at 9:14 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Don't go with a spacer lift, they mess with your suspension geometry bad and will cause your truck to have a bad ride. Just go with the generic, Bilstein 5100s Struts and adjust them to 1.75 it will level out your truck. No you don't need to get a diff drop for your CVs and if you needed one they are cheap.. Check out www.downsouthmotorsports.com
    Also the biggest size tire you will only be able to fit is 265/70/R17s (if you are running your stock wheels.) Just putting it out there if you plan on leveling out your truck out. It's a FAQ.
  3. Dec 13, 2010 at 9:19 PM
    kcrob1
    kcrob1 Choot It!
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    Adjustable Billies, Debadged, Painted emblem on grille Kenwood Double din, polk components, co-ax, polk 8" sub & polk amp, TSB springs, 6000K hids, FJ Wheels
    ^^^What he said... I just installed mine yesterday. Real easy to install and ride hasn't changed at all from what I can tell.
  4. Dec 14, 2010 at 8:16 PM
    only49ersfan
    Myrtle Beach, SC
    09 Tacoma 4X4
    OK thanks for the info. Couple more questions. If I purchased these shocks can i reuse my oem springs or do i need to buy new springs? Are these the Bilstein shocks you were talking about? http://downsouthmotorsports.com/i-1...acoma-pre-runner-4wd-pre-load-adjustable.html. Thanks again for everybodys imput.
  5. Dec 14, 2010 at 8:19 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
  6. Dec 14, 2010 at 8:22 PM
    bobfm10350
    bobfm10350 Well-Known Member
    Deric
    Austin Texas
    06 PreRunner TRD Off Road
    Access Limited Tonneau, Hawk LTS Brake Pads, SP Performance Slotted Rotors, Goodrich G-Stop Brake Lines, Thule Roof Rack, Bilstein 5100s Front and Rear, Eibach Coil Springs, Cabela's Floor Mats, 265-75-16 Duratracs, Fog Light Anytime Mod, D-Rings Mod, USA Spec PA15 TOY Ipod Adapter, Gorilla Lock Nuts, K&N Drop-In Air Filter, Wet Okole Seat Covers Front & Rear, Toytec 1.5" AAL, Viper 5901 Car Alarm
    You can reuse the oem springs and set the billys to 1.5 or replace the oem springs with eibach springs and set the billys to 0
  7. Dec 14, 2010 at 8:26 PM
    only49ersfan
    Myrtle Beach, SC
    09 Tacoma 4X4
    ok. can someone post a link to the eibach springs i would need. Im tryin to get out as cheap as possible but i plan on keeping this truck for another 7-10 years so i dont want to half-ass this.
  8. Dec 14, 2010 at 8:31 PM
    bobfm10350
    Deric
    Austin Texas
    Well the eibachs would end up being more expensive because you would have to buy both springs and shocks. The cheapest way to do it would most likely be to get the bilstein 5100s from dsm and set them to 1.5
    The eibach springs are from toyteclifts.com if your still wondering
  9. Dec 14, 2010 at 8:32 PM
    kcrob1
    kcrob1 Choot It!
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    Just use the stock springs and set it at 1.75", rides great and will save you some money. Here is mine set at 1.75 with the stock springs
  10. Dec 14, 2010 at 8:36 PM
    only49ersfan
    Myrtle Beach, SC
    09 Tacoma 4X4
    just curious how much the eibach springs would cost.
  11. Dec 14, 2010 at 10:11 PM
    only49ersfan
    Myrtle Beach, SC
    09 Tacoma 4X4
    Thanks guys. im glad i asked before buying the leveling kit. those bilstein shocks are what ill end up doing instead. P265/70R17 BFG A/Ts, those Bilstein shocks, wheel alignment and ill be set. Any additional info is always welcomed. Thanks again
  12. Dec 18, 2010 at 10:07 AM
    pollock21
    pollock21 Well-Known Member
    Brian
    Cornelius, NC
    '11 Tacoma DC, TRD Sport 4x4
    To summarize, best way to level is 5100's, no diff drop needed, alignment, done and done? Yes, that's a question, I'm looking to level too.
  13. Dec 18, 2010 at 10:24 AM
    Andy2010
    Andy2010 Well-Known Member
    Andy
    Bucks County, Pa
    2010 TRD Sport Mag Grey 4x4
    EGR inline vent visors, Trimmed front mud flaps, Hose clamp mod, AFE Pro-Dry S air filter, Bed mat off my '97, 5100's up front @1.75, Rear TSB, Tow package, Black TRD center caps, Weathertech Digitals, Wet Okole's in front
    You will need an alignment.
  14. Dec 18, 2010 at 10:35 AM
    CristianTRD
    CristianTRD Well-Known Member
    Cristian
    San Antonio, Texas
    '08 Silver Tacoma Off Road TRD
    These are the Eibach springs.
    Like said before.. You don't need to buy the springs the Bilsteins are good with your stock springs. You can always buy them later and put them on with the 5100's if you like.
  15. Dec 18, 2010 at 11:01 AM
    Reepur
    Reepur Well-Known Member
    Brevard, NC
    '10 RC Black 4x4 2.7L
    265/75/16 BFG KM2 's on XD Hoss's 2.5" lift/4xBillies, OME 885's, Firestone Ride-Rites Desert Specialties UCA Volant CAI Grillcraft Grill Kobalt Slim Line Box Weathertech mats and Ventvisors. DTRL mod. 4 Lo -Trac Mod. Int. Wiper Mod. rcbs204 4x4 LEDS URD Short Shifter Plate Front bumper with Smittybilt XRC8000 winch Body Armor rear bumper with swing out tire carrier. ATO Front Skid Ultragauge BHLM
    Recently ordered my setup..
    2 front , 2 rear Bilstiens
    Downsouth UCA's
    1/4 " top plate spacer
    Toytec 1.5" add-a-leafs
    for under $1000 (actually cheaper than I was expecting)
    Haven't received yet but should have it installed in a couple of weeks.
  16. Dec 18, 2010 at 4:06 PM
    only49ersfan
    Myrtle Beach, SC
    09 Tacoma 4X4
    thanks for all the info guys. Billy 5100's, 265/70R17 BFG A/T's, and an alignment and Ill be set. now does anyone like to donate for these upgrades? :D
