Quick question on your opinion on lift//tires
Discussion in 'Suspension' started by JohnMatrix, Dec 23, 2010.
  1. Dec 23, 2010 at 2:33 PM
    JohnMatrix
    JohnMatrix [OP] New Member
    Westminster, CA
    05 Tacoma Regular Cab w/Shell
    I have a stock 2005 Tacoma, regular cab, base model. Quite frankly I am tired of looking at it. Gotta have it look like a pre-runner. I don't need it off-road capable, im simply going for visual effect.
    Basically what I want from you veterans is a good estimated guess on what you think a 3" lift kit // rims tires will cost. I am not asking for a researched answer, or you to look into it, (I will search the forums and the web myself for specifics) but your guesstimate for a simple affordable lift that is of some quality. Nothing half-assed.
    Lay it on me~
  2. Dec 23, 2010 at 2:38 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    lift > 500-700 for parts, 400ish more if you have someone install it
    tires > 800
    rims > 400-500
  3. Dec 23, 2010 at 2:57 PM
    JohnMatrix
    Westminster, CA
    I should have mentioned, does a 3" lift allow for my wheel wells to fit 17" rims//tires (265/65 R17 tires) ?
  4. Dec 24, 2010 at 8:40 AM
    CopDoctor
    08 335i
    easy. you could fit 285/75 with a bit of trimming but 265 will have no problem at all
  5. Dec 24, 2010 at 8:44 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    Tires and rims right on, but you could go with billies in front or a spacer for real cheap, throw and aal in back worst case 300.
    Although are you a 5 lug? Do the billies fit on 5 luggers? If not spacers I think should.
