Lift problems
Discussion in 'Suspension' started by sdtacoma2002, Dec 25, 2010.
  1. Dec 25, 2010 at 9:40 AM
    sdtacoma2002
    sdtacoma2002 [OP] Member
    Orange County, CA
    10 PreRunner TRD Sport
    3" Procomp lift
    I just got a Procomp 3" lift and 33's from 4 wheel parts and the ABS goes off when coner above 40mph (on/off ramps) and the alignment seems off. They were supposed to do an alignment with the lift. Has anyone experienced anything like this. I'm taking it in on monday but wanted to see what might be up.
  2. Dec 25, 2010 at 9:48 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    search I remember something on this site about the sensor needs to be adjusted
  3. Dec 25, 2010 at 9:54 AM
    OffroadToy
    search "yaw sensor"
  4. Dec 25, 2010 at 9:58 AM
    cluck024
    cluck024 -cluck
    Robert
    Greenwood, Arkansas
    09 Prerunner TRD-OR DC Barcelona Red
    Blacked out badges, Anytime Fog Light Mod, Sockmonkey Decals and Third Brake Light Cover, Yellow fog lights, custom homelink install, Radflo 2.0 coilovers, LR UCA's, AAL, Moto Metal 957 matte black with Nitto Terra Grappler 285/70/17 shoes, more to come...
    See the second post here:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/92474-recalibrating-vsc-why-how.html
    Click on the link to the pdf. This can be done with a short peice of copper wire (SST Method). No need for the dealer to rape your wallet here.
    Note: Step 4 on page 3 says using the intelligent tester. This is a typo, should say SST Method.
    If you think you messed it up just turn the ignition off and wait a minute or two. Will automatically reset back to previous settings and no harm will be done.
  5. Dec 25, 2010 at 10:21 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Unlike Procomps claim that you do not need to run uca's. Youll need to get them to correct alignment.
  6. Dec 26, 2010 at 2:06 PM
    sdtacoma2002
    Orange County, CA
    3" Procomp lift
    Thanks, it looks like that did it!
  7. Dec 27, 2010 at 6:22 PM
    cluck024
    cluck024 -cluck
    Robert
    Greenwood, Arkansas
    Good to hear. I take no credit for that, just had to do it myself and found it on here. All credit to OP of above info. Just FYI, that may not completely fix it so be cautious with high speed corners. :D
  8. Jan 23, 2011 at 5:15 PM
    gogosons
    gogosons 671 islander
    05 taco lifted blacked out
    3" procomp lift, halo projector headlamps, led JDM taillamp, interior 12" sub fockfords, SPL 4 tweeters
    you do need to get UCA's for your lift. i also have the same problem
  9. Jan 23, 2011 at 5:20 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    How Is the pro comp lift ? Any vibes?ride good
  10. Jan 24, 2011 at 3:21 PM
    sdtacoma2002
    Orange County, CA
    3" Procomp lift
    With the exception of the alignment problem, that should be taken care of with new UCA's, it rides great.
