Is this rear stock and non tsb?
Discussion in 'Suspension' started by jimmyzshack, Dec 29, 2010.
  1. Dec 29, 2010 at 9:40 AM
    jimmyzshack
    jimmyzshack [OP] Well-Known Member
    Houma, LA
    06 PreRunner
    leveled
    The rear seems high to me for it to be stock and there are spacers on the front. I have 5100's coming in today for the front and the rear. I plan to do the rear myself and take it in for the front. I don't plan on doing aal so trying to figure out where to set the 5100's. right now the front is about 1/2" higher than the rear from the ground to the top of the finder with the spacers I don't know what the lift is on the spacers. I don't want the front to be higher if anything a little lower than rear.
    this is how it sits
  2. Dec 29, 2010 at 9:43 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Jason
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    it looks like only 3 leaf springs to me, so i would say its stock but its hard to see
  3. Dec 29, 2010 at 9:48 AM
    jimmyzshack
    Houma, LA
    06 PreRunner
    leveled
  4. Dec 29, 2010 at 9:49 AM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    Stock it is
  5. Dec 29, 2010 at 10:18 AM
    TexasTacoma37
    Looks like 4 to me? Stock with an AAL?
    Or is that just a pad between the leafs and the overload?
  6. Dec 29, 2010 at 10:19 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    looks like upside down aal lol
  7. Dec 29, 2010 at 10:20 AM
    TexasTacoma37
    Agreed.
  8. Dec 29, 2010 at 11:40 AM
    jimmyzshack
    Houma, LA
    06 PreRunner
    leveled
    figures, This is one down fall to buying used. getting frustrated with what is suppose to be my new truck. lol so now what? flip the small pad thing over following the instructions like i was going to be installing a AAL.
  9. Dec 29, 2010 at 11:43 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    in the first pick, i looks like it might only be 5-7in or so, looks like just a pad..no aal is that short...is it metal?
  10. Dec 29, 2010 at 11:49 AM
    OffroadToy
    Looks to me from top to bottom...
    2 leaf's, a rubber pad, then overload spring?
    edit: If that's not a rubber pad and is in fact a aal it looks upsidedown like mentioned earlier.
  11. Dec 29, 2010 at 11:53 AM
    jimmyzshack
    Houma, LA
    06 PreRunner
    leveled
    Just went and check, it's rubber.
  12. Dec 29, 2010 at 11:55 AM
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    +2, looks like 3 leaf crap pack that is sagging with some kind of pad crammed in there. Mine looked similar to this minus the pad before adding the AALs. No TSB for me either since it was used and past 36k. Just get some AALs. Mine has been fine with AALs. Much more like it should have been.......except they all should have had the 4 leaf packs to begin with.
  13. Dec 29, 2010 at 11:59 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    ..........and you might wanna ditch the base model black Tokicos for some bilsteins. The yellow/blue ones can be had cheap in FS pretty often or just go 5100s.
  14. Dec 29, 2010 at 12:00 PM
    jimmyzshack
    Houma, LA
    06 PreRunner
    leveled
    5100's come in today. taking the spacer crap off the front and putting them on. I was trying to figure out if the back was raised are not to see how high to set the 5100's to lvl or nose slightly lower.
  15. Dec 29, 2010 at 12:09 PM
    OffroadToy
    Yep...the front is higher due to the rear sagging. I got a 2" aal in back and raised the front 2" and have a 1" rake (the back sits higher than the front with the weight of a canopy.)
