Premature Tire Wear
Discussion in 'Suspension' started by bigdog83, Jan 9, 2011.
  1. Jan 9, 2011 at 5:43 PM
    bigdog83
    bigdog83 [OP] Member
    Steve
    Maine
    2002 v6 limited trd
    I just bought an '02 trd xcab v6 with 85,000 original miles which goes straight down the road with no pull or shimmy....the problem is that the inside of the front BFG rugged trails are wearing noticeably...I dont know if this is common for Tacomas or if the tires are just junk. The tires only have about 26,000 on them and they need to be replaced....not sure about the rotation history. I have to put new A/T's on but dont like the wear pattern I'm seeing. Any insight out there?
  2. Jan 10, 2011 at 6:00 AM
    TexasTacoma37
    Sounds like your camber is off. I would get an alignment before its too late and the tires are toast.
  3. Jan 10, 2011 at 9:46 AM
    bigdog83
    Steve
    Maine
    2002 v6 limited trd
    Thanks for the reply....the camber certainly makes sense especially since the bilsteins are solid and there is no other indication of front end issues. I do know that the previous owner had a 4 wheel alignment done when he put the BFG's on 26,000 miles ago. So hard to figure...I was thinking it may be an inherent trait of these trucks and that why i turned to TW for answers. :confused:
  4. Jan 10, 2011 at 9:49 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Did you add the bilsteins and not get an alignment ?
  5. Jan 10, 2011 at 9:56 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    A lot of trucks will wear the inside of the front tires quicker which is why we rotate the tires. If all 4 tires wore evenly, there'd be no need. I'd get an alignment done when you get your new tires but keep on your tire rotations and you'll get a lot more life out of your tires. You can still swap them to the rear to try and even them out a little (depending on how worn they are).
  6. Jan 11, 2011 at 7:39 AM
    bigdog83
    Steve
    Maine
    2002 v6 limited trd
    No. The bilsteins were OE with the TRD. I'm starting to think there is nothing wrong with the truck itself and this is more a case of not enough rotation...or the BFG's are just junk. I haven't heard very good things about the Rugged Trails.
  7. Jan 11, 2011 at 8:08 AM
    bigdog83
    Steve
    Maine
    2002 v6 limited trd
    Thanks Pugga, I'm a big believer in tire rotation...just think the previous ownner was not. Just trying to make sure this is not a trait for these trucks.
