-   -   NEED ADVICE ON NOSIE IN FRONT END AFTER 3" LIFT (http://www.tacomaworld.com/forum/suspension/133661-need-advice-nosie-front-end-after-3-lift.html)
jigger1976 01-13-2011 05:39 PM
HELLO EVERYONE NEW HERE!!! I NEED ADVISE?? I JUST INSTALLED A 3" LIFT IN MY 06 TACOMA AND RIGHT AWAY NOTICED NOSIE IN THE FRONT END. I HAVE READ SOME OF THE THREADS AND NOW ARE CONFUESSED BADLY. SOME SAY FRONT DIFF. DRIVE SHALFT. HAS ANYONE GOT A SOLUTION FOR THIS AS I READ THAT EVERYONE PRETTY MUCH HAS HAD THE SAME PROBLEM AFTER LIFTING THE TRUCK...AND YES THE KIT WAS CHECKED ALL BOLT AND ALINGMENT WAS DONE. OH YA ADDED THE DIFF DROP SPACER TOO.:mad: RIGHT NOW I'M AT THE POINT OF TAKING IT OUT PLS HELP
KPT 01-15-2011 08:00 AM
1. Please stop yelling
2. The diff drop is probably the cause of the vibes. Remove it and see if they go away.
jigger1976 01-16-2011 01:52 PM
Thanks will try that.:) also ordered a set of shims from toytec for the rear just to try that.Thats a cheap fix to try. Has anybody narrowed it down to specific model of truck. Because not all people are haveing the same problem. ???
jigger1976 01-18-2011 09:01 AM
took the diff drop out today, didn't make a difference still nosie and vibra in the foot area. hopefully its the drive shaft just waiting on shims now.
moulin6801 01-18-2011 09:14 AM
Please keep us posted! I want to lift my truck, but things like that is what is keeping me...
Did you notice changes in MPG??
thanks
Reepur 01-18-2011 09:16 AM
I have the same issue and I have a 2010 with 15k miles on it. Pretty sure it is the diff driverside CV bearing. Gonna try some stuff to confirm it. There is a thread on this already...
http://www.tacomaworld.com/forum/sus...e-lifting.html
and
jigger1976 01-18-2011 12:34 PM
i dont think it the bearing? why because it happen right after the lift.. i noticed it with in the first mile . took the diff drop out but still nosie maybe a little less but still there. i read in another thread someone said it the drive shaft angle. i'm kinda think that it is. does anyone know the angles or what the angle tolerance are. I hope this is it and the shims will fix it.
TheHansen 01-18-2011 12:49 PM
Check to see if the vib goes away if you switch to 4x4 while driving... it could be the bearing because after the lift there is more pressure against the bearing due to the new angle of the cv's
ETaco23 01-18-2011 03:45 PM
Its def. the bearing man! My Truck is at the dealer (has been for 2 weeks) right now getting fixed.
Im hoping it will be fixed and done Thursday. If not Im ganna demand a new front diff. there trying to just re-build it and its bull!
If it goes away in 4wd then its the Needle bearing.
Sorry, but alot of Tacomas have this issue.
Bumponapickle 01-18-2011 03:46 PM
What kind of lift did you install? I have an old man emu with 855 springs and spacers...09 dclb...never had any vibes from it.
ETaco23 01-18-2011 03:54 PM
Its more of a growning/growling noise and a grinding slight vibe in the floor board that most people feel.
jigger1976 01-19-2011 06:38 AM
how long did you have the lift in for? before the bearing went? and how much for the needle bearing,it is hard to get to.
Alby9999 01-19-2011 06:44 AM
:popcorn:
jigger1976 01-19-2011 09:06 AM
Hey bump where u for in ontario??. again does anyone know the poper angles for drive lines front and shaft. the nosie is getting worse but the temp has dropped to -23
ETaco23 01-19-2011 11:37 AM
as long as your fins arent touching, you should be fine. Check out this thread for info about the bearing.....
http://www.tacomaworld.com/forum/2nd...iff-now-4.html
jigger1976 01-19-2011 07:08 PM
how long did you bearing last? since you put the lift in. and how much was it to replace
ETaco23 01-19-2011 07:59 PM
The Lift doesnt cause the bearing to go bad, it just makes the bad bearing present. I drove it for maybe 30miles after the lift, then took it to the dealer. I have the ext. warrenty so there covering it. there just being stupid and trying to rebuild it, instead of just replacing it. My truck wouldve been done a week ago if they just gave me a new diff.
theyre ganna take my diff apart again to replace another part, bc the thing they replaced the first time didnt work.... Im just heated!! sorry for the rant!
its been about 2.5 weeks without my baby!
jigger1976 01-19-2011 09:15 PM
call me stupid but i can't get my head around this. so your saying eveyones bearing is bad then.????? because everyone who is hearing this growling means the bearing is bad or is the lift affect it some how. if you take the lift out you don't hear it growling. SORRY for the rant!! but this nosie is driving me crazy!! but i LOVE the look of the truck
ETaco23 01-19-2011 09:52 PM
Its all good, I was pissed when I heard it the first time also.
But no, it seems to be hit and miss. some people have it and some dont. When lifting, your cv axles put more load on the bearing there for you can hear and feel the bad bearing. but when your truck is stock and the cv's are in there neutral position you cant hear/feel it. hope that makes sence.
How most people find out if its the Diff bearing is by seeing if the noise goes away in 4wd. but if its still there then its most likely a wheel bearing or something else.
jigger1976 01-19-2011 11:19 PM
thx that makes sense now. and ya it goes away in 4wd. thx again
