OME What's the real number?
Discussion in 'Suspension' started by Valley Viking, Jan 19, 2011.
  1. Jan 19, 2011 at 2:11 PM
    Valley Viking
    Valley Viking [OP] Well-Known Member
    Menlo, WA
    05 4x4 DC LB SR5
    OME 885 Coils, OME Dakar Rear Leafs, OME NitroCharger Shocks, LR UCA's, AFE ProDry Air Filter, Scanguage, Wet Okole Seat Covers
    I am looking to get an OME lift for a 05 DCLB 4x4 and have been reading about lifts on here for about a month now. I am a 80% Hwy and 20% logging road / fire trail kinda guy. I would like to add about 2.5" in the front and more or less the same in the back. I don't care if the truck has a little less rake than stock but don't want more than stock and definately don't want the Bro look. Pretty sure I have settled on 885's for the front w/ trim packer, Dakar leafs on the back, OME shocks all around and will go ahead with the LR UCA's. I have gained a ton of info from what I have read but there are couple of things that you never quite get a clear answer on. How much lift will I get front and back from the OME lift without any added spacers and are extended brake lines required? Everyone seems to have a different answer, OME calls it a 2" lift, wheelers says the front coils will give 1.75", Chris4X4 says 3", Toytec says to add a spacer to get 3", and no one really says what the Dakars will give. Please help me out so I can pull the trigger and get the kit coming.
  2. Jan 19, 2011 at 2:13 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    subscribed
  3. Jan 19, 2011 at 2:14 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    chris4x4 is hardly ever wrong..just when cooking. you'll get 3in. and extended brake lines aren't required, but suggested.
  4. Jan 19, 2011 at 2:16 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    first off welcome to tw. It sounds to me like that set up will net you around 2.5 all around, but I know more about first gen ome suspension stuff than second gen stuff. I would say chris4x4 knows his stuff though
  5. Jan 19, 2011 at 10:17 PM
    Valley Viking
    Menlo, WA
    05 4x4 DC LB SR5
  6. Jan 21, 2011 at 3:00 PM
    Valley Viking
    Menlo, WA
    05 4x4 DC LB SR5
    Is there a difference in the height you will get out of the same OME kit mounted say on a DCLB vs. a DCSB.
  7. Jan 21, 2011 at 3:02 PM
    CopDoctor
    08 335i
    maybe 1/4in
  8. Feb 20, 2011 at 9:20 PM
    Valley Viking
    Menlo, WA
    05 4x4 DC LB SR5
    OK I went ahead with the OME lift so now I guess I can answer some of my own questions. Hopefully that will help someone else who may have the same concerns.
    First let me say that how much lift you get depends on where you start from. My truck is an 05 4x4 with 120,000 miles on it and I don't know if the original front and rear springs have sagged from their original ride height or not. Maybe if you are lifting a brand new truck that has not had any sag at all your before measurements would start out as higher than mine did with my well worn stock springs. My truck is also a DC LB SR5, not a TRD, so my original ride height may vary from a TRD. That being said if you install the OME complete lift like I did your final lift numbers should be pretty damn close to mine as we would both have the same suspension after the lift is installed.
    After a bunch of hand wringing I choose the OME complete lift and added the 10mm lift enhancer spacers (about 5/16" thick, should give 5/8" to 3/4" +/- of lift) from Wheelers. I was hoping to level the truck somewhat front to back. My before measurements center of hub to bottom of wheel arch were 20-1/4" in the front and 22" in the back. A difference of 1-3/4" higher in back. With the lift installed I am now 23-3/4" in the front and 24-3/4" in the back, a difference of 1" front to back. The roads have been icy and I do have about 150 LBS of sand back in the back of the truck with these "after" numbers, I did not have the sand bags on the before numbers. The Dakar springs are stiff enough that I don't think the sand bags are causing any sag.
    So I gained about 3-1/2" in the front (with the 10mm spacers) and 2-3/4" in the back from my "before" measurements with a 120,000 miles on the stock springs. I think if I had eliminated the 10mm spacer I would have gained 2-3/4" front and back and the truck would have maintained the stock rake front to back. In my opinion you should assume you will have roughly the same "after" measurements +/- as I have and should measure your actual "before" height to determine what amount of lift you will gain. Keep in mind I just installed the lift (80 miles ago) and the springs have not had a chance to settled as everyone seems to think they will. I have no idea how much settlement, if any, there will be.
    I am very happy with the ride. It is definately firmer and more truck like but very well dampened and not harsh at all. I have been on a couple of washboard roads since the lift and the supension soaked those up much better than the stock suspension did. I also think my load carrying capacity will be much improved though I haven't had a chance to try that yet.
    The look is great with the front more level than before thanks to the 10mm spacers. I am a little nervous about my CV angles though and if there are any problems I would consider removing the spacers to drop the front a bit and go back to a more stock rake front to back.
  9. Feb 20, 2011 at 9:43 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Did I miss your measurements ?
  10. Feb 20, 2011 at 10:07 PM
    Valley Viking
    Menlo, WA
    05 4x4 DC LB SR5
    I was editing my mistakes, they are there now.
  11. Feb 20, 2011 at 10:15 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    here's an OME 885 with 15mm spacer. You will definitely be high enough. Im gettimg my aftermarket bumper and winch put on tomorrow so that should bring down the front a little.
  12. Feb 20, 2011 at 10:26 PM
    Valley Viking
    Menlo, WA
    05 4x4 DC LB SR5
    What were your final measurements?
  13. Feb 20, 2011 at 11:13 PM
    plee33
    plee33 Well-Known Member
    Peter
    Sacramento, CA.
    SWB TRD Sport Long Bed 4x4
    SnugTop SuperSport Shell, BedRug, OME Heavy Duty Lift Kit, Weathertech Liners, more to come....
    Nice little write up about your OME lift numbers. I guess you and I are in the same boat after all. I've been researching myself and always come to a dead end. I have a 05 Tacoma DC LB also, but equipped with TRD package and have always wanted to know the real numbers behind the OME lift. I ordered myself the OME heavy duty lift kit just the other day. Hopefully all goes well.
  14. Feb 20, 2011 at 11:31 PM
    OZ-T
    Peter North
    British Columbia
    Good write up , thanks for the info Viking . My OME lift with the 885's and Dakars is sitting on my shop floor waiting to go in .
  15. Feb 21, 2011 at 6:45 AM
    Valley Viking
    Menlo, WA
    05 4x4 DC LB SR5
    885's are what I have with the standard Dakar's in the back. I will see if I can get a picture up tonight.
  16. Feb 21, 2011 at 8:40 AM
    especk
    Erik
    Redding, CA
    ill get all the measurements later today after my winch and bumpers are installed.
  17. Feb 21, 2011 at 8:42 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    heck with measurements:D
    pics!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:cool:
  18. Feb 22, 2011 at 10:31 PM
    Valley Viking
    Menlo, WA
    05 4x4 DC LB SR5
    Got a few pics with my phone right before dark. Now I need wheels and tires.
  19. Feb 22, 2011 at 10:38 PM
    plee33
    Peter
    Sacramento, CA.
    Looks leveled to me. Wheels+tires and you're set. Any driveline vibes?
  20. Feb 22, 2011 at 10:47 PM
    Valley Viking
    Menlo, WA
    05 4x4 DC LB SR5
    I do think there is a bit more hum to the drive train now than before. Might be all in my head. I've been running around with the radio down straining to hear something. I guess if I can't say for sure it can't be that bad. I did install the CB drop but not the Diff drop.
