Shock Bumps?
Discussion in 'Suspension' started by Tacomanator, Feb 4, 2011.
  1. Feb 4, 2011 at 10:30 AM
    Tacomanator
    Tacomanator [OP] Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
  2. Feb 4, 2011 at 11:11 AM
    TexasTacoma37
    Not sure about those in particular, but some folks on here have Timbrens, and Wheelers superbumps.
    EDIT: Wait, do these actually go on the shock? Never have seen those.
  3. Feb 4, 2011 at 11:14 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    yeah, they go over the shaft. seems like a cool idea to me
    http://www.youtube.com/watch?v=gbnFIcRnjo0
  4. Feb 4, 2011 at 11:17 AM
    TexasTacoma37
    Do they limit up-travel at all, or do they squish down so much that it's negligible?
  5. Feb 4, 2011 at 11:19 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Pretty bullshit that you have to buy the "installation" tool separate....
  6. Feb 4, 2011 at 11:25 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    not sure if they really limit travel, but they increase resistence as the shock begins to bottom.
    taken from their site:
    "As the Jounce Bumper compresses, it increases its resistance, therefore providing a progressive rate as the shock compresses. This prevents the harsh bottoming often felt with many suspension designs."
  7. Feb 4, 2011 at 11:27 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    yeah that does suck
  8. Feb 4, 2011 at 11:31 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  9. Feb 4, 2011 at 11:43 AM
    06RedComa
    06RedComa Well-Known Member
    06 4x4 DC Sport
    Kings, Camburg 1.25" UCAs, Dakar leafs, TRD exhaust, Grillcraft grille, All-Pro APEX Bumper, Kenwood DNX6960, Avid Sliders, SnugTop Rebel, 285/75/16 Hankook Dynapro atm
    Crazy, I was just looking at these on poly performance and I do a search on here to see if anyone was using them and someone already beat me to it so if anyone has info on how these run, it would greatly be appreciated.
  10. Feb 4, 2011 at 2:54 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jason
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Do you have or are you getting u bolt flip?
  11. Feb 4, 2011 at 3:49 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    no, i dont plan to. Sarah from All Pro helped me find correct length shock for my stock rear, but i still think these bumps are a cool idea.
    So anyone have experiance with these?
  12. Feb 5, 2011 at 2:52 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    i've seen these before. i've never ran them though...
    they use this style bump on the front of the raptor (oops, i said the "R" word)
  13. Feb 5, 2011 at 3:17 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    ^ if the Raptor uses them, they must be pretty legit. ill probabbly end up buying a set.
  14. Feb 5, 2011 at 3:45 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    thats what i was thinking too
  15. Feb 5, 2011 at 3:53 PM
    Jason'sLawnCare
    Jason
    I'm sure they are better than nothing but I'm not too sure the shock body is designed to take the load. I'd still keep the stock bumps if they are big enough and if not get something bigger.
  16. Feb 7, 2011 at 11:05 AM
    beatle
    beatle Well-Known Member
    Springfield, VA
    98 3.4l SR5 TRD
    Bump stops essentially raise the spring rate of the suspension where they are installed once it reaches a certain point in its compression. Without knowing the height of the new bumpstop, you have no idea of knowing how much it will limit suspension travel. A bumpstop that's too large would keep you at a higher spring rate almost all the time which may be pretty uncomfortable. Foam bumpstops also have a lifespan, and if you need that much additional cushioning, you're probably better off with longer and/or stiffer springs.
    "Harder" and "softer" are pretty vague terms as well, and they don't list the cases where you would use one over the other. Maybe the seller can offer up more information?
  17. Feb 7, 2011 at 11:15 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    I've used them before. I had them up front on my icon coilovers. They worked really well but got destroyed after three desert trips. They can take mild abuse but nothing crazy.
    I've heard on the rear shocks if you take a big enough hit they will just slide off the same way they were installed. I'd say go for it but not if your concerned about the shock being too long. That will just be a bandaid to a more serious problem.
