after lift rubbing
Discussion in 'Suspension' started by BMOC, Feb 21, 2011.
  1. Feb 21, 2011 at 9:00 PM
    BMOC
    BMOC [OP] Well-Known Member
    Paden
    Phoenix, AZ
    edit, refer to post #28, i found the rubbing spot on the LCA.
    just installed my toytec ULK about a week ago. I still have stock tires, rims and uca's. i'm pretty sure i read that it was ok to do that since the ULK coil overs come shipped at 2.5 inches in the front, so i opt'd out on the uca's for now (budget). anyways... im getting a little bit of rubbing on the spindle from the tire. i can barely fit my finger through the gap between tire and spindle on a level surface. on uneven surfaces while driving it rubs like hell!! is this normal for stock tires/rims? should i get spidertrax wheel spacers until i can afford new wheels? or did i just fail at my installation? thanks for the help!! :D
    here's a pic of how close things are.
  2. Feb 21, 2011 at 9:17 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Post a pic. You should be easily able to tell where it is rubbing as there will be wear on parts.
  3. Feb 21, 2011 at 9:34 PM
    BMOC
    Paden
    Phoenix, AZ
    i'll try to get pictures tomorrow. the camera's acting kind of funny.
  4. Feb 21, 2011 at 10:15 PM
    nick
    nick MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    if you put half in or so spacers it should help. if you space to much they will rub your fenders. hope this helps can tell a little better with pics
  5. Feb 22, 2011 at 12:30 PM
    black cx
    black cx Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
  6. Feb 22, 2011 at 2:57 PM
    TexasTacoma37
    You shouldn't be rubbing with stock rims and tires with that setup.....something's not right.
  7. Feb 22, 2011 at 3:17 PM
    BMOC
    Paden
    Phoenix, AZ
    that's what im thinking.. do u think it could have something to do with me leaving the swaybar off?
  8. Feb 22, 2011 at 3:22 PM
    08pretaco
    az
  9. Feb 22, 2011 at 3:27 PM
    BMOC
    Paden
    Phoenix, AZ
    what in the world could be the problem?? all i did was replace the coilovers and remove the sway bar.. not sure what i could have done wrong during installation. :(
  10. Feb 22, 2011 at 3:29 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    who did the install? something is def. not right. you shouldnt have any rubbing at all with stock wheels/tires
  11. Feb 22, 2011 at 3:29 PM
    08pretaco
    az
    where eactly do you live? I might be able to swing by to take a quick peek?
  12. Feb 22, 2011 at 4:09 PM
    BMOC
    Paden
    Phoenix, AZ
    i installed myself at school, i followed the steps and did my homework on knowing how to do it, i could have missed a step, though i dont think i did.
  13. Feb 22, 2011 at 4:22 PM
    BMOC
    Paden
    Phoenix, AZ
    Here's the pic i got of it. you can notice how close everything is to the tire...
  14. Feb 22, 2011 at 5:01 PM
    08pretaco
    az
    Thats not close at all lol
    where the spindle attaches to the uca...is that shading there or is that rubber marking?
  15. Feb 22, 2011 at 5:22 PM
    BMOC
    Paden
    Phoenix, AZ
    i wasn't actually sure that it was the spindle there, so i called it the spindle to uca thing, lol.
    but yea, i can barely fit my finger through that gap.. so if thats not close then i just got chunky ass fingers :laugh:
  16. Feb 22, 2011 at 5:56 PM
    08pretaco
    az
    I pm'd you back
  17. Feb 22, 2011 at 10:19 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    find out what's rubbing yet?
  18. Feb 22, 2011 at 10:25 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    I can't really fit my fingers betwen the tire and the UCA on stock TRD trucks with 265/60R16 tires.
    So nothing's really changed there.
    How do you know something's rubbing? Any chance you dropped some debris down between the brake disc and the caliper?
  19. Feb 23, 2011 at 10:45 AM
    BMOC
    Paden
    Phoenix, AZ
    well, i was off roading and i heard a kind of grinding or tire rubbing noise coming from the driver side wheel area. when i got home i looked at how close that spindle is and just figured thats what the noise had to be. and now i know that the distance is normal for our trucks and the noise has to be something else..so
    i cancelled out brake noise. as i've been out there bone stock and never heard the noise before i got the lift. now i have no clue what that noise could be. ill take it back out and see if i can figure the sound out, hopefully its nothing serious though :)
  20. Feb 23, 2011 at 11:16 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    hope you find out whats wrong. are you sure the noise is coming from the front?
