HELP: Am I sagging??
Discussion in 'Suspension' started by cdavi060, Mar 22, 2011.
  1. Mar 22, 2011 at 1:09 PM
    cdavi060
    cdavi060 [OP] Well-Known Member
    Virginia Beach, VA
    2016 TRD Sport 4X4 DCSB
    Full OME Lift (887), 275/70/17 BFG KO2
    Hye guys,
    Im getting ready to invest in a lift but want to make sure I'm not lifting on sagging or warn out springs. My truck seems to sit a little lower than the extended cab at my apartment complex so I figured I would post a few photos here and see if anyone can let me know if I should replace my springs, or just throw a AAD in there. It looks like my leafs are sagging, but I still have a little more than an inch left between the bumpstops. Any help is welcome!!
    *Note I have 265/75/16 tires on the truck now and u-bolt clamps in front of the axle on the leafs to get rid of the axle wrap I had.
  2. Mar 22, 2011 at 1:12 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I personally wouldn't put an AAL on those, it may help for a while but won't last long since the springs are so worn. The negative arch on them is not a good sign.
  3. Mar 22, 2011 at 1:14 PM
    tacomarotto
    tacomarotto "Change is inevitable, but growth is optional."
    Jon
    Jacksonville
    Audi S3
    looks pretty shitty to me.
  4. Mar 22, 2011 at 1:20 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Oh wow that new pic you posted is really bad, probably the worst I've seen. Definitely go for the new springs, an AAL wont do much on those.
  5. Mar 22, 2011 at 1:21 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    I was in the same situation about a year ago. My factory leaf pack was shot so I was told to just get an AAL. A year later I am in the same situation I was last year. Save yourself the time/money and just get a whole new leaf pack.
  6. Mar 22, 2011 at 1:23 PM
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
    MAXTacoma (not to hijack the thread), but how many miles on your 06? I'm looking at an AAL to help out when towing, maybe I'm wasting money...
  7. Mar 22, 2011 at 1:23 PM
    dmz1241
    dmz1241 Well-Known Member
    Dan
    SE, Connecticut
    01 Gold DC TRD
    Bilstein 5100's all around, Eibach coils, 2" shackles, Flowmaster 60 Series
    haha, mine are probably worse than that......
  8. Mar 22, 2011 at 1:25 PM
    MAXTacoma
    Lexus GS 350
    PM Sent.
  9. Mar 22, 2011 at 1:26 PM
    MTgirl
    Weesa
    Bob's secret mod lair
  10. Mar 22, 2011 at 1:37 PM
    cdavi060
    Virginia Beach, VA
  11. Mar 22, 2011 at 1:40 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    :eek: those are toast do like the others said buy new leafs a AAL will do noting with those. You have got to hitting the bumps all the time with those things.
  12. Mar 22, 2011 at 1:42 PM
    JLee
    Jerry
    Benicia, CA
    The AllPro 3" pack is good but if you put a lot of weight in the bed you would need the expos and let me tell you there higher then 3" I got about 5" with a camper.
  13. Mar 22, 2011 at 2:00 PM
    cdavi060
    Virginia Beach, VA
    my plan as of now is to get 5100's all the way around, set the stock springs on the front at the 2.5in position and try to equal out the rear. If these leafs from the group buy are higher than that, I think I need another option??
    Is it possible for my front springs to sag? How can I tell?
  14. Mar 22, 2011 at 2:04 PM
    JLee
    Jerry
    Benicia, CA
    I personally think you need all new suspension you are sagging pretty bad and 5100's and your stock coils are not going to give you 2.5" of lift in the front. This was my truck stock and mine was sagging a little and it was sitting a lot higher then yours.
    But this is with 265/70/16's so 1" difference in tire size
    And yours
  15. Mar 22, 2011 at 3:26 PM
    cdavi060
    Virginia Beach, VA
    I see. Guess I should look into some springs as well. What could have caused this bad of sagging?
  16. Mar 22, 2011 at 3:29 PM
    JLee
    Jerry
    Benicia, CA
    10 years man that's a lot on coils and shocks.
  17. Mar 22, 2011 at 4:45 PM
    cdavi060
    Virginia Beach, VA
    since I need to get new springs, can I just replace the rear shocks and keep the stock front?
  18. Mar 22, 2011 at 4:45 PM
    MTgirl
    Weesa
    With the 5packs I have about 2" of lift in the rear - from the ground to the highest point on the fender well is about 38" on my truck. I did 5100's at zero and OME 881's for 2" of lift in the front as well. Personally, I wouldn't go any higher than that. After that point you're getting some harsh angles on the rest of the front end...CV's etc.
    Your front end could be sagging due to the preivous owner having either a bull bar, grillguard, etc mounted for a number of years. All of that added weight on a stock suspension will make things wear and sag dramatically faster.
  19. Mar 22, 2011 at 4:57 PM
    cdavi060
    Virginia Beach, VA
    I was kind of on a budget, so I'll ask this. Does it make sense to put the 5100s on the front just to set them at 0? Could I not keep the stock shock or Rough Country's with new springs?
    So you have this exact 5pack(that the group buy is offering) on your truck and it provided a 2in lift?
  20. Mar 23, 2011 at 9:39 AM
    cdavi060
    Virginia Beach, VA
    Can anyone post stock height in inches from ground to top of fender well for the front? I want to see if I am sagging any in the front.
