Icon AAL problems
Discussion in 'Suspension' started by hedman, Apr 16, 2011.
  1. Apr 16, 2011 at 4:41 PM
    hedman
    hedman [OP] The Ghost
    Canada BC
    18 DBL CAB LB TRD SPORT
    I went to install ICON AAL 3 pack and after getting them in there they are hitting the front factory spring retaining c-clamp thing. I pulled them off and spun them around and they hit the back one. I am wondering if they sent me the wrong part any help would be appreciated.
  2. Apr 16, 2011 at 4:43 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    They have their own retaining clamps. Gotta cut the old ones off. I've got the same thing going on with mine. I'd suggest going at them with an angle grinder.
    Also, I'm pretty sure the long side is supposed to be toward the rear.
  3. Apr 16, 2011 at 4:45 PM
    hedman
    Canada BC
    so why wouldnt they tell you that on the web site
  4. Apr 16, 2011 at 4:49 PM
    Pugga
    Massachusetts
    That'd be way to easy... I was disappointed in the directions that came with the kit. I ended up searching through pictures of other's installs on here, that's how I determined that everyone had cut off their old clamps.
  5. Apr 16, 2011 at 4:52 PM
    hedman
    Canada BC
    Ok thanks for the help I am going to get the grinder out and ya i realized that they go on long side to the back
  6. Apr 16, 2011 at 4:55 PM
    Pugga
    Massachusetts
    Good luck, I ran into the same thing this morning! I tried my luck with a dremel and a hack saw but those rivits are pretty thick. An angle grinder will make short work of it but make sure you pop out the graphite inserts first. I cut one side of the clamps first, slide that leaf out by itself (mark it so you know which side goes toward the rear) then you can pop out the graphite insert and go to town on the rivit.
  7. Apr 19, 2011 at 8:52 AM
    bskin
    bskin Well-Known Member
    Eagle River AK
    2016 DC TRD Off Road MT
    I have this same aal pack but I want to keep the overload leaf, is this pretty doable from what you encountered during install?? Thanks.
  8. Apr 19, 2011 at 9:16 AM
    Pugga
    Massachusetts
    I assembled my leaf pack last weekend (don't have them on the truck yet, doing that this coming weekend) and I kept the overload in place. I have a new(er) TSB pack that I paired with the Icon AAL that will be replacing my stock leaf pack since it's flattened out. They go together fine, the centering pin in long enough. I'll post up some measurements and ride opinions once I get them on the truck but it is possible and some people are running this set-up with the wheeler's 3-leaf progressive AAL.
  9. Apr 19, 2011 at 9:22 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 285 x 70 x 17 Toyo Tires on 17" x 8" ICON Wheels
    Hello everyone,
    I just got off the phone with ICON about this, and although the instructions DO NOT mention it, you're supposed to remove the factory spring clamps as Pugga mentioned.
    They said they will revise the instructions and add this step. I also mentioned that they should include some pictures in the instructions...
  10. Apr 19, 2011 at 9:43 AM
    Pugga
    Massachusetts
    I don't know if I should have done this but I used an angle grinder to smooth the factory leaf where the rivit went through. This left the factory leaf down to bare metal so I hit it with some rustoleum primer then paint before I reassembled everything with the new AAL. I'm assuming this was the correct way to do it but figured it couldn't hurt to ask.
  11. Apr 19, 2011 at 9:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    That way is fine.
  12. Apr 20, 2011 at 8:00 AM
    Pugga
    Massachusetts
    Thanks! Can't wait to get these on the truck and get rid of the flattened out old leaf pack.
  13. Apr 20, 2011 at 9:02 AM
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
  14. Apr 20, 2011 at 9:16 AM
    Bamfs01
    Bamfs01 Well-Known Member
    Magnetic Gray TRD Offroad. Locker, ATrac, DAC
    Stock leaf pack with TSB AAL, Wheelers progressive 3 leaf AAL, and Bilstein 5100's in the rear. Front OME coilovers with 885 coils. Cab mount chop. http://www.tacomaworld.com/forum/wheels-tires/37734-how-tire-rub-cab-mount-mod.html rcbs204 4x4 Illuminated Switch. http://www.tacomaworld.com/forum/lighting/68173-rcbs204-4x4-illuminated-switch.html JBL P963 6x9's and an MTX 10" sub wired inline to the stock HU with a MTX Jackhammer 404 amp. Rear diff breather relocation mod.
    I have a 2011 Access Cab TRD Offroad with the TSB leaf pack.
    I installed the Wheeler's 3-leaf progressive AAL leaving the factory rebound in the pack last night. It all went together very easily and took 3 hours. I'm sure if I did it again I could almost cut that install time in 1/2. It was simple.
  15. Apr 20, 2011 at 10:08 AM
    HB Taco
    Curt
    4x4? How much lift did you end up with that combo? Factory Rebound = Overload spring? I assume you needed extended brake lines? What shocks are you running? sorry for all the ques but I'm soaking all this up. Thx
  16. Apr 20, 2011 at 10:19 AM
    Pugga
    Massachusetts
    I'm curious to how the ride is as well. I'm hoping you didn't need new brake lines because I didn't figure that into the equation... Any before/after measurements (more interested in the after measurement between the center of the hub and the fender if you have it).
  17. Jul 17, 2011 at 5:44 PM
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
  18. Jul 17, 2011 at 7:06 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    You are right on all counts Pugga
    Because alot of distributors sell them but don't know the issues with their own shit. & it is common & it is irritating...
  19. Jul 18, 2011 at 11:25 AM
    hellrazor004
    Rob
    09 DCSB
    Anyone have pictures of this install? I plan on working on mine this coming weekend and it looks to be a PITA.
  20. Jan 23, 2012 at 1:19 AM
    tALOHAma
    tALOHAma Well-Known Member
    Oakland, Ca
    07 4X4
    Anytime fog mod, debadged, drop in k&n, smoked taillights, led inside and out,
    I just picked up the wheelers pack. Hoping I can revive this thread and have someone post some pics of the install.
