-   -   New with suspension and need Advice (http://www.tacomaworld.com/forum/suspension/155961-new-suspension-need-advice.html)
rmacher 05-08-2011 08:55 PM
I have a 2010 TRD 4 x 4 Tacoma and I will like to change the suspension for Adjustable Bilstein (all around) , the rear has 3 leaf only and I will use 265/75/16 tires with original rims and 1.25 spacer , now what should I do to have a nice look , I do 99.5% city ride.
Thanks you.
rmacher 05-09-2011 06:36 AM
Suspension
If I replace the front shock should I use the same coils ? it will work fine , the rear because I have 3 leaf an extra one will be fine? the high I want is just decent .
brelandt 05-09-2011 08:34 AM
Originally Posted by wolfpack_5150 (Post 3145946)
I don't understand the question.........sounds like u have it all figured out already?
Except the rear. U know the billies are only adjustable on the front right?
Course the hieght u choose on the front is dependent on how much rake u want.
For the rear go with an aal.......blocks are the worst.
LOL did you know while i was trolling the pick n pull last week that every single 1980's square body Ranger had lift blocks from the factory on them! Never knew that...... :eek:
