Shim Install = Minor Fail
Discussion in 'Suspension' started by sac130e, May 18, 2011.
  1. May 18, 2011 at 10:33 AM
    sac130e
    sac130e [OP] Well-Known Member
    Scott
    Milton, FL.
    11' TRD Off-Road 2wd
    JVC Nav. System and entire Memphis Audio Speakers/Amps
    Was installing the 3* shims today and things were moving well until....
    Reinstalling the U-bolts and they came up short. Never once did I see a mention in my searches of a need for longer bolts. With the torque, the bottom of the bolts came eve with the bottom of the nuts. In my years of aircraft maintenance, I have learned you need at least a couple threads showing to be safe.
    So removed the shims, but finished installing the new center bolts with the spacer, that way it will be ready when I get new bolts.
    Now... Where to get new bolts? Figure at least 7 to 7.5" would work for this.
    Anybody know where to grab a set online? I tries 6 different auto stores and dealers locally and no one has them...so next stop is online.
    Thx
  2. May 18, 2011 at 10:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Do you have a NAPA?
  3. May 18, 2011 at 10:47 AM
    sac130e
    Scott
    Milton, FL.
    Yup, already went there with no luck. Also tried Autozone, Advanced Auto Parts, O'Rielly, Dodge dealer and a boat yard that builds up trailers.
    Scott
  4. May 18, 2011 at 11:06 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I bought mine from a local 4x4 shop.
    Still haven't installed them though..I need to get new center pins with a spacer first.
  5. May 18, 2011 at 1:30 PM
    sac130e
    Scott
    Milton, FL.
    I went ahead and installed the new pins/spacer for the future when I find the bolts and put in the shims.
    But, ti try something else..I installed another thin washer in the CB and now the takeoff vibs are practically gone. Hardly notice unless you are trying to make it happen or looking hard for it. Still have to run it on the highway to check those speeds..but if this works, won't have to rip it apart again.
    Still need to find a place online that sells the correct size U-bolts if I do have to put the shims on.
    Scott
  6. May 18, 2011 at 1:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  7. May 18, 2011 at 1:33 PM
    BigJLarse83
    BigJLarse83 Well-Known Member
    Salt Lake City, UT
    06 DC PreRunner TRD Sport
    Toytec has them
  8. May 18, 2011 at 5:42 PM
    sac130e
    Scott
    Milton, FL.
    Thx...hate dealing with Toytec and their OVERPRICED shipping costs.
    They would be my last choice.
  9. May 19, 2011 at 11:15 AM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    Go to a spring shop, they can make them for you on the spot. They are made out of high tensile steel, and are one time use only. After you remove the tension on them they are only as strong as regular 9/16 ready-rod. Do not ever re-use U-Bolts! Should have looked into this before taking them off.
    Also get grade 8, not grade 5 ones and torque to 130 pounds. If you get 8.5 inch ones you can simply cut them after the install.
  10. May 19, 2011 at 11:21 AM
    TexasTacoma37
    Fastenal has tons of oddly sized bolts. Give them a shot if you have one near you.
  11. May 19, 2011 at 11:25 AM
    sac130e
    Scott
    Milton, FL.
    Aware of the reuse of the bolts...the dealer just put these new ones on during the TSB a couple weeks ago. Will get a new set when I get around to the shims, again.
    Thx
