did u Smush the bushing?
Discussion in 'Suspension' started by 11B4X4, May 19, 2011.
  1. May 19, 2011 at 5:39 PM
    11B4X4
    11B4X4 [OP] Well-Known Member
    Northern VA
    2006 tacoma 4x4, Black
    Trd intake, Doug Thorley offroad headers, magnaflow exhaust, RBP running boards, 2.5In spacer, URC O2 simulator, 5100's all around
    I installed billies on my truck about 6 months ago. On the rear there is a rubber bushing that goes on top. I tightend the nut down far enough to smush the bushing almost flat. it went easily, i wasn't cranking on it. now it looks like it's starting to dry rot or crack a little. was i suppose to? or leave it un smooshed?
    What did you guys do?
    Do you need pics?
  2. May 19, 2011 at 6:06 PM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    i think you're only suppoded to tighten to 15 ft.lbs. And no, i don't think you were supposed to smush it.
  3. May 20, 2011 at 2:28 PM
    11B4X4
    Northern VA
    might have to find some new bushings for them then
    Any other input from anyone
  4. May 20, 2011 at 2:32 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    i wouldnt worry to much about it. i would just loosen it up alittle bit and call it good.
  5. May 21, 2011 at 12:11 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    From the service manual it says 26 ft-lbs.
    I think your best 'visual' test would be for a stock setup to post a pic for you.
  6. May 21, 2011 at 12:31 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    i was thinking something else when i opened this thread lol
