-   -   Alignment, Caster, Clearance, and Driving Report with Light Racing UCAs (http://www.tacomaworld.com/forum/suspension/158795-alignment-caster-clearance-driving-report-light-racing-ucas.html)
bjmoose 05-24-2011 09:47 PM
Summary:
* UCAs improve Caster but reduce clearance at the rear fender.
* You can reduce the amount of space lost by setting the alignment optimally
* Daily driveability is much better after adding UCAs.
So, last October I lifted my 4 cyl std cab Tacoma with OME 885 springs and Dakar Leaf pack. See http://www.tacomaworld.com/forum/sus...ines-pics.html. This gave me a full 3" of lift. I did not install any upper control arms. Here are my final post-lift alignment numbers:
Code:
        Left    Right  Factory Range
Camber:  0.5    0.3    0.2-1.3
Caster:  -0.1    -0.2    1.0-2.5
Toe:      0.05    0.05  0.0-0.11
Not optimal obviously, but I had clearance and no rubbing issues at the back and did not need to do a cab-mount chop.
My wife noticed right away that the truck felt "skittish" and didn't like driving it. After six months, including a long road-trip to Moab, I decided I was ready to get some caster back, so I purchased some Light-Racing Upper Control Arms from wheelers.
I installed them last weekend. I didn't bother with an install thread for them because of the most excellent TW UCA install thread here: http://www.tacomaworld.com/forum/sus...w-install.html and the excellent video produced by SPC, maker of the control arms, here: http://spc-tv.com/install/lt-suv/69-...trol-arms.html :cool:
Using the instructions I pre-set the caster at the "+3" position (+2 is "neutral")
Yesterday, took the truck in to get it aligned at my local shop I've been using for years. Here are the alignment numbers from that. Check out the huge 3.7 caster before they started!
Code:
BEFORE:
Camber:  0.2    0.2    0.2-1.3
Caster:  3.9    3.7    1.0-2.5
Toe:    -1.23  -0.63  0.0-0.11
and AFTER:
Camber:  0.5    0.4    0.2-1.3
Caster:  2.4    2.4    1.0-2.5
Toe:      0.05    0.07  0.0-0.11
But, there was a problem. The instant I tried to back out of my parking place with a bit of turn, the wheels rubbed the back of the wheelwell. brubrubrubrubrubrub. :rant:
I talked to the shop and rang up PRS 2 TiFJ. He gave the following observations and instructions.
* If you increase caster AT THE TOP of the spindle, you decrease clearance, because that moves the spindle hub back.
* If you increase caster AT THE BOTTOM of the spindle, you increase clearance, because that moves the spindle hub forward.
* On the stock truck, caster and camber must be played off against each other, because the combination of eccentric cams on the lower-control-arm affects both caster and camber.
* But the adjustability on the Light-Racings means you can set Camber at the top of the spindle, in addition to setting caster there.
* Toe is adjusted by the tie-rod ends, and is a completely separate adjustment.
So, to maximize clearance:
1. First, Maximize caster using the eccentrics on the lower control arm. Do not worry about camber at this time.
2. Reset the caster cams on the UCAs to the minimum value to bring Caster to an acceptable value. I decided to trade off a little less caster for a little more clearance here, and moved the UCA cams to the "+1" position (One degree LESS than neutral, and two degrees less than I started)
3. Set the camber using the UCA adjustment slide.
4. Finish off toe normally.
So I met with the alignment technician this morning, and stood in the shop while he worked. Pretty much my only contribution to the effort was showing how to turn the caster-adjustment cams on the UCAs. To get maximum "2.5" caster on my truck, the UCAs would have to be set at the neutral "+2" position. I deliberately traded off to get a little more CLEARANCE at the expense of a little less caster and ended up with the following final alignment numbers:
Code:
Camber:  0.5    0.5    0.2-1.3
Caster:  1.7    2.0    1.0-2.5
Toe:      0.05    0.06  0.0-0.11
After the alignment, there was 2.5" of space between the tire and the rear of the fender well. A little less than I originally had before I installed the UCAs, but I'm no longer rubbing in the parking lot. :bananadance:
I'm now on the fence about getting a cab-mount-chop, because I hate tire rub in all its forms, and I like having the option to run chains on all four wheels.
The bonus to having waited this long to install UCAs is that I'm now qualified to talk "before and after" about driving the truck with and without upper-control-arms.
1: As expected, the truck now tracks better. On my short drive to the shop with the 3.7 degrees of caster, the truck was *very* stable and I kinda liked that. But even at 1.7, it's much more directionally stable, self-corrects easily to the zero position after the tiny variances in the road, and takes a lighter hand on the wheel. Truck no longer feels skittish or twitchy. I'm pleased.
2: The factory UCA ball joint, rather than OME shock length, seems to have been the limiting factor in droop. When I jack up the front end I now raise the whole thing two full inches (at the fender) before the tires finally leave the ground.
The amount of droop IS telling as I go over our various highway bridge joints that are a regular feature of my commute. Before, with the lift and the factory UCAs, the front would drop and the truck would lurch forward, forcing the headrest into the back of my head on some of these joints. Now, I glide easily over these small drops. This is an unexpected bonus, and I'm *very* pleased.
bjmoose gives a hearty "ThumbsUp" to Light Racing upper control arms. :thumbsup:
Much later EDIT: - you may find this pic helpful in aligning the SPC control arms:
http://www.tacomaworld.com/gallery/d...djustments.jpg
4RunnerSeth 05-24-2011 09:54 PM
Originally Posted by bjmoose (Post 3219050)
Summary:
Code:
Code:
BEFORE:
and AFTER:
3. Set the camber using the UCA camber adjustment slide.
Code:
1: As expected, the truck now tracks better. On my short drive to the shop with the 3.7 degrees of caster, the truck was *very* stable and I kinda liked that. But even at 1.7, it's much more directionally stable, returns easily to the zero position after the tiny variances in the road, and takes a lighter hand on the wheel. Truck no longer feels skittish or twitchy. I'm pleased.
Awesome dude... glad I was able to explain it in a way that made sense. Great write up. I highlited a couple typos for ya. :D
bjmoose 05-24-2011 09:58 PM
Camter isn't a word? :D
4RunnerSeth 05-24-2011 10:03 PM
So, the only caveat to this is that as you dial in most your caster at the bottom you will end up with positive camber. You are able to compensate for this at the top with the light racing UCAs by pulling the top in. this moves the ball joint closer to the coil, so be aware that the LRs use a very large boot on the ball joint and you may experience contact between the boot and the coils, especially for people using larger 2.5 diameter shocks. So, I recommend you check at some point that at full droop you are not contacting the coil.
Oskie_78 07-01-2011 04:45 PM
good read!... so when you set the LR UCA to +1* (-1*) you don't have any rubbing at all? I might have to try this.
bjmoose 07-01-2011 04:56 PM
I'm unable to detect any rubbing on the street. Have not done any offroading yet where I can check when stuffed.
03DBLCABTACO 07-01-2011 05:03 PM
Great post. Will be using this when I install my lr arms and omen with dakars. Thanks.
Digiratus 07-01-2011 09:00 PM
I love TacomaWorld. :o Thank you bjmoose. :p
OZ-T 08-07-2011 11:19 PM
Great thread as usual Steve
Doc.SS 08-07-2011 11:49 PM
Thanks for taking the time.
DubVtundy 08-14-2011 02:45 AM
subbed
maxamillion2345 08-26-2011 09:35 PM
Seemed like a good thread to add to.
Went wheelin last night, fucked up my door... and knocked my LR UCA out of adjustment in camber (along with my alignment). Went from all of the way out to almost all of the way in. I torqued them to spec with a torque wrench, this time I torqued them much more. Also noticed the boots had fallen down and they were pretty dry and had lot's of dirt inside. I will be needing to lube them.
Not a big deal but... shows you can knock the LRs out of adjustment and keep an eye on the ball joints to see if they have ample grease.
JavaJoe1 02-02-2012 01:46 PM
sub'd
maxamillion2345 02-02-2012 07:38 PM
ball joints and bushings wore out on both sides in under a year. SPC replaced them at no cost to me (not even shipping). I had to install them myself but I had it down the second time, took no time at all. New design looks much better FWIW. I'd buy them again.
bjmoose 02-02-2012 08:08 PM
Thx for the update. Have they changed the torque spec on that big ball joint top nut?
cnew 02-02-2012 10:57 PM
Very good info here as usual. I have been planning my lift for about a year now and have found your posts very very useful. Thanks for taking the time and effort to post all of this great info. Almost had the lift last year but found out at tax time instead of getting money back as we do each year we owed over 8 large. Purchased the LR UCAs for cyber Monday and finally saved enough for the OME lift. Now to find a good shop at a decent price for the install, can't wait!! Thanks again.
jspetrovitsis 02-19-2012 10:29 PM
what are the correct numbers soposed to be on a taco that is lifted 3''
Digiratus 02-19-2012 10:41 PM
I have read that ideal is 0 degrees for camber. 0 or +.01 or +.02 degrees of toe. And more than 2 degrees of caster.
This is achievable on an all stock Tacoma with no lift. However, when you lift the truck, especially when you max it out to 3" of lift, it becomes impossible to adjust the caster high enough. One degree of caster might be attainable but not much more.
Do you have 3" of lift? Have you added aftermarket upper control arms?
maxamillion2345 02-20-2012 02:30 AM
IIRC it's 120. Not sure if they've changed it or not.
Edit: I don't know if it was my memory of if they've changed it but the spec on their PDF from their website says 150 ft-lbs.
http://www.spcalignment.net/instruct...70-INS_WEB.pdf
45 ft-lbs for the castle nut holding the spindle to the ball joint, then whatever more to make the hole for the cotter pin line up.
They only mention this in the tech tips page but the UCA bushing/frame bolts are 87 ft-lbs and remember only torque when vehicle is sitting on it's own weight at ride height.
maxamillion2345 02-20-2012 02:47 AM
Toe ~0* (out of spec toe can cause adverse handling and the scuffing and dragging or pushing of tires across pavement, you want both your tires straight ahead and parallel to each other, lifting should not affect this)
Camber would depend on your application mostly you want 0* this puts the tire as about as close to 90* to the road as possible. Some go fast guys may want a little negative camber to help with cornering. /-----\
Caster you want as much as you can squeeze out of these guys IMO, I think about 3* is a good number. This will dictate how your truck handles, too little caster and your truck will feel like it's 'floating' and following grooves and ruts in the road, wandering etc... too much and it makes it more difficult to turn. I'm of the opinion that you'll never seen enough caster on these trucks to make it an issue.
Since caster and camber are both adjusted via the cams at the LCA and the UCA is fixed there is only so much adjustment possible. When you lift you basically get positive camber and so to bring that camber down you have to take a hit in your caster angles.
If you were looking at your truck after you lifted it you might notice the positive camber which would look like this from the front. \-----/
This gives you decreased contact with the road way and wears your tires on the outside unevenly which severely shortens their life.
So like I said to bring them back down to as close to 0* as possible |-----| you have to take a hit at caster making it lower, this causes your truck to wander and track poorly. I could only get 1* with stock UCAs and 884 coils. With about .5 camber.
So when you add LR UCAs you get much greater adjustability because now we can add or remove both caster and camber at the UCA and LCA.
This means we can get ideal alignment numbers if we know how to set up the UCAs.
The stock specs are as follows: (note that they may not be the most ideal)
Camber -0.3* 1.2*
Caster 1.3* 2.8*
Toe -1/64" 1/32"
Just to re-iterate the ideal specs IMO are:
Camber 0*
Caster 2.5 - 3
Toe 0
and they should be easily attainable with these UCAs, just ask to set them to set camber and toe at 0 and then get caster as close to 3 as possible. Should drive great.
