-   -   Adding on a brush bumper and Winch. What does this mean for my suspension? (http://www.tacomaworld.com/forum/suspension/162408-adding-brush-bumper-winch-what-does-mean-my-suspension.html)
Simone 06-16-2011 02:25 PM
I am currently in a 2010 Double Cab V6 TRD and have a noob question for you all powerful Taco wizards.
If I want to add on this bumper:
http://www.shrockworks.com/Toyota-Ta...-pr-16174.html
(Hint: 138 Pounds)
And this winch:
http://www.warn.com/truck/winches/src/XD9000.shtml
(Hint: 78 pounds)
For a grand total of 216 pounds added to the front of my truck, (minus the weight of the stock bumper)
My truck is a stock TRD model. Will I have to put on some stiffer suspension? If that is the case, I am a total reject newbie to suspension, so if you could spell out crayola style what exactly I'd have to do I would be eternally grateful.
I did try using the search function and just couldn't find what I am looking for. If this has been hashed through a few times just post the link and belittle me like a standardized whipping boy. Thanks!
nvdeserted 06-17-2011 11:22 PM
Just for the sake of your math: the stock bumper weighs about 5lbs.
As for the front, if you don't want it to sag down and ride worse, you'll need to get some aftermarket springs that are designed to handle a heavier weight.
As far as what springs: there are lots of options. Do you want to keep the stock height? keep stock struts? or just replace it all?
Probably the most common fix I see on here is folks getting Bilstein 1500s with a heavier spring. OLD Man Emu makes a nice front 3" lift with optional heavier springs. Then yo ucan get into the hihperformance/racing coilovers with a higher rate spring.
There is alot of info on here about this subject. Try to find rigs with a similar setup as the one you want, and see what they've done to handle the extra weight.
Either way, you won't be happy if you just stck with the stock front, weight wise.
Simone 06-23-2011 08:09 PM
I looked at Bilstein's website, did you mean 5100s and accidently type 1500s?
MatthewMay1 04-30-2013 08:24 PM
Noticed this thread hasn't been posted in in years, but it goes along with my question. I have a stock 2001 TRD and I have a Warn XD9000i winch that I would like to put on an All Pro APEX front bumper that I'm dreaming of. What would be a good idea to do to my suspension to maintain stock ride height? The winch was my uncle's and he had it on an F-150 and he said that it completely destroyed his front suspension and tires because of the weight. I want to avoid that! Any help is appreciated! Thanks!
KenLyns 04-30-2013 08:31 PM
You want stock height? Use OME 880 springs (e.g. here) or stock springs from 2005+ TRD Off Road models.
MatthewMay1 04-30-2013 08:35 PM
Those would support the added weight without replacing the shocks? That winch is heavvvvvvvvy
KenLyns 04-30-2013 08:57 PM
How much does your truck weigh, about 3500 lb? If 65% of that is on the front wheels, then about 2200 lb is currently being supported by your front shocks. Do you think another 200 lb would make that much of a difference? I think the bumper and winch together will cause the front end to drop maybe 0.7".
Of course, if your current shocks are already dead after 12 years, by all means replace them with OME Nitrochargers.
MatthewMay1 04-30-2013 09:03 PM
Ah I just noticed that the bumper weighs 101 pounds and the winch 85. I just don't want to destroy the suspension and tires like my uncle did with his F-150. I would rather just replace the coils or shocks rather than both if that's possible. Idk which (coil or shock) would be better for handling the extra 200 pounds.
KenLyns 04-30-2013 09:15 PM
In very simplified terms, coils determine ride height; shocks are there for damping (i.e. how much "pogo" action you get after hitting a bump).
You need the coils for sure. Upgraded shocks would be beneficial.
MatthewMay1 04-30-2013 09:41 PM
So is there a set of coils I could get and still use with my stock shocks? Those OME ones say they require new shocks...
KenLyns 04-30-2013 10:03 PM
881 and 883 lift coils need OME shocks. 880 does not. 880 provides about 1" of lift on a stock truck. Your front bumper and winch would weigh it down close to stock height.
MatthewMay1 05-01-2013 06:14 AM
OKay I'll look into some 880's then! Thank you for the advice!
MatthewMay1 05-01-2013 06:19 AM
Will they be strong enough for a double cab?
MadMtnMikey 05-01-2013 06:31 AM
I have a TrailGear Bumper = ~85lbs, plus an Engo 9000 Winch = ~80-90lbs. I run the Toytec Eibach springs and Bilstein 5100 shocks and my front end rides way better than it ever did stock.
You need to lose the mentality of running stock shocks, otherwise you'll feel like you're hopping down the road everytime you hit a bump.
MatthewMay1 05-01-2013 06:40 AM
Won't that set up give you a higher lift? I want to keep stock height
MadMtnMikey 05-01-2013 06:43 AM
They're adjustable, I have mine set to give lift.... Don't know if they give lift at zero or not. Same rule applies though regardless, even if you go with an 880, it'll be a stiffer spring handling more weight than stock.
MatthewMay1 05-01-2013 06:51 AM
I thought the Eibach coils on 5100's set at 0 gave something like 3" lift over stock. Now I know that the bumper and winch will pull it back down, but not 2-3".
MadMtnMikey 05-01-2013 06:54 AM
No, mine are set at 1 or 2, can't remember now, I'd have to look.
MatthewMay1 05-01-2013 06:57 AM
That's just so much money for me! I don't have enough saved up for my bumper yet and I have a winch sitting in the garage with nothing to put it on and it's killing me!
MadMtnMikey 05-01-2013 07:16 AM
The Eibachs are about the bare minimum you could go. They're progressive, but stiff enough when loaded down that they can handle the weight of an additional 180-200lbs, but like any other stiffer spring require additional dampening to prevent bouncing. If you're trying to set yourself up for future upgrades, you'd be wise to go with that setup, it'll save you money in the long run. I did not have my bumper and winch when I first installed my springs and shocks.
Edit: you can go with 880s and a cheaper shock. Think though, if down the road you want to get more lift, or the shocks don't last, you'll be spending money on the same components a second time around.
