Um... Did I forget to order somthing?
Discussion in 'Suspension' started by LonghornTaco, Oct 16, 2008.
  1. Oct 16, 2008 at 1:22 PM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Jason
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I just had a thought after looking at the pictures of the parts I ordered...
    The bottom two are what I ordered from ToyTec. I got the 5100s from DownSouth Motorsports. But are the two pieces of the assembled coilover/strut assembly (on top) that are circled included with the 5100s or is that a separate piece I need to order?
    Does this make sense?? :eek:
  2. Oct 16, 2008 at 1:27 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Yeah i believe those are spacers and you do not need them the bottom setup is all you need how much you pick them up for?
  3. Oct 16, 2008 at 1:33 PM
    LonghornTaco
    Jason
    Minnesota
    $429. That and the struts from DownSouth motorsports were about $200 cheaper than buying the assembled ones up top for $799.
    So, if that is just the spacer that I don't need, what piece comprises the other end of the spring to keep it compressed?
  4. Oct 16, 2008 at 1:57 PM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    I think it is just the c clip that goes around the shock body and then you use the pieces from toytec and not the bilstein bottoms.
  5. Oct 16, 2008 at 2:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You use the original top plate that is on the truck.
  6. Oct 16, 2008 at 2:04 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    Chris 4x4 is correct, the disc looking things are the c clips thats what your going to use to put it at the hieght you want you can see on the shock there are 3 lines thats where they would go.
  7. Oct 16, 2008 at 2:05 PM
    LonghornTaco
    Jason
    Minnesota
    Oh, ok. So I'm gonna have to take my struts off first...
    I was really hoping to leave my factory struts/coils intact.
    Can I buy another set of these separate?
  8. Oct 16, 2008 at 2:07 PM
    LonghornTaco
    Jason
    Minnesota
    That's what I thought they were...
  9. Oct 16, 2008 at 2:11 PM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    No the c clip are on the shock in that pic and the round plate are what the spring sit on. If your going to use what toytec sent then you shouldn't need the bilstein plates.
  10. Oct 16, 2008 at 2:35 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    You are correct red taco i thought he was asking whats it for i miss read.
  11. Oct 16, 2008 at 3:59 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    The c-clip goes on the bottom setting.You do use the plate.The ToyTec collars sit on that.In regards to the top pic,it's not a spacer.It just looks better then the stock coil assembly top.(Double check w/Neubes.)
  12. Oct 16, 2008 at 5:17 PM
    LonghornTaco
    Jason
    Minnesota
    So, to be clear, I don't have to use the coil assembly top off my truck to assemble the new strut and coil or do I?
  13. Oct 16, 2008 at 5:22 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    You re-install the top.(I have the same coil over you have)$$ for the install is my hold up.:)
  14. Oct 16, 2008 at 5:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Install it yourself? Take the spring/shock to a place with a spring compressor and have them put it together for ya. SHould cost about $20.00 per side. Then take it home and re install. :D
  15. Oct 16, 2008 at 5:25 PM
    LonghornTaco
    Jason
    Minnesota
    Do you know if I can buy a new "assembly top" for the new coil and strut? I wanted to keep the factory coil and strut together if I could.
    Side note - is "assembly top" the right term for it? :)
  16. Oct 16, 2008 at 5:26 PM
    LonghornTaco
    Jason
    Minnesota
    x2
    I called PepBoys and they will do it for $20 per side. I'm gonna pony up the cash just so I don't have to mess with it.
  17. Oct 16, 2008 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can buy it from the Toyota dealer. Its a Top plate with the studs. From the dealer, its probably $50.00 per side. :eek: Not sure where else you can get them.
  18. Oct 16, 2008 at 5:27 PM
    LonghornTaco
    Jason
    Minnesota
    Wonder if I can buy the "fancier" one from ToyTec... :)
  19. Oct 16, 2008 at 5:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good idea! Give them a call and see. :)
  20. Oct 16, 2008 at 5:32 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    Where i live (condo) the hoa would have my a$$.lol,I'm also waiting on funds to order the uniball for my tc's.:D Have this done all at once.:cool:
