stupid question 5lug vs. 6lug
Discussion in 'Suspension' started by br217398, Oct 18, 2008.
  1. Oct 18, 2008 at 5:13 PM
    br217398
    br217398 [OP] Crazy Person.....
    Orlando Florida
    06 Tundra Crew Cab 4WD
    Hornblasters horns,Strobe lights,Police Undercover Vehicle, Volent Ram air system, pro comp POS AAL, biltein all around, step bars.
    Alright so as of now i cant find from toyota that there is a difference in any of the 5lug and 6lug suspension parts other than the hardware themselves, ie springs and shocks. Is this correct?? because if so, my 5lug base can have 5100 and ome 884s even though they arent "FOR MY TRUCK".... or am i just horible wrong and retarded... THANKS!!!!
  2. Oct 18, 2008 at 5:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You ARE horribly wrong, but not retarded. :)
  3. Oct 18, 2008 at 5:26 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    5 lug and 6 lug parts are not interchangeable.
  4. Oct 18, 2008 at 6:54 PM
    BioMed80
    BioMed80 Well-Known Member
    Colorado Springs, CO
    09 Regular Cab
    3" ReadyLift Kit, 31x10.5x15 General Grabber AT2s, AFE Drop-In, Bull Bar, Hella 500FF, Secondary Filter Removed
    ReadyLift makes a 3" lift kit specifically for the 5-lugs (I just ordered it after a fair amount of research). It's the 69-5510. It runs about $230 and takes about 2-3 hours to install. Pretty simple install if you have the tools and know-how. There's also a video of the install if you're interested. This lift will allow up to a 31" tire. Good luck!
    PS This seems to be the only kit for the 5-lugs at this point.
  5. Oct 18, 2008 at 9:29 PM
    br217398
    Orlando Florida
    well the problem is that toyota had told me that if i was looking for a suspension upgrade, since my advisor is a real cool guy, he could throw on some trd springs, struts, and shocks "since there really isnt much of a difference" for only $3k...... i kindly declined his offer, but i really dont understand how there is that much of a differance... Thanks yall
