OME 2 Inch 05+tacoma Heavy Kit Questions
Discussion in 'Suspension' started by copenhagen, Aug 4, 2011.
  1. Aug 4, 2011 at 5:40 AM
    copenhagen
    copenhagen [OP] Well-Known Member
    South Carolina
    2011 TRD OFFROAD 4x4 SIX SPEED MANUAL AC
    Hey ya'll, I'm looking at getting one of these from ARB. My goal is to have an ARB bumper and a WARN 8000lb winch. I have a 2011 TRD Offroad Access Cab 6 speed manual, and she's almost paid for, so now is the time for me to look. Here are my questions:
    1.) If I purchase the OME Heavy Suspension lift kit and do an install, how much will it affect my ride if I wait to buy the bumper and winch at a later time (I don't believe in spending money I don't have)? Am I going to bounce all over the place?
    2.) If I install the OME Heavy Suspension lift kit, how much will it actually lift my 2011 TACO? It already has those factory Bilsteins that come with the TRD Offroad package, so I want to know how many inches I can expect to get out of the kit, if any. It purports a 2" lift.
    3.) Is there anything I am missing?
    Thank ya'll, and hope to hear back!
  2. Aug 4, 2011 at 7:22 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    886's will be a stiff ride with no additional weight up front .
    You can expect 3" of lift from them on your AC
    You can't run them with the factory shocks , you need to get OME 90000 Nitrochargers
    Get UCA's
  3. Aug 4, 2011 at 7:50 AM
    copenhagen
    South Carolina
    Here is what the kit includes:
    http://store.arbusa.com/2-Inch-05tacoma-Heavy-Kit-P20932.aspx
    • OME886 x 2
    • N140S x 2
    • CS047R x 2
    • N182 x 2
    • OMEU53A x 4
    • FK29 x 1
    Stated differently (cheapest price I've found):
    http://www.4x4groupbuy.com/store/tacoma-heavy-p-10597.html
    Complete kit include:
    (2) Heavy Load (110-220lbs) Spring (OME886)
    (2) Shocks (N140S) (2) Medium Load (0lbs to GVW) Spring (CS047R)
    (2) Shocks (N182)
    (4) U Bolts (OMEU53A)
    (1) Fitting Kit (FK29)
    I was told by a gentleman from a 4x4 store that I would not need aftermarket upper control arms for this kit. If you think that it needs them, please explain why, or why not. I am looking to hear both sides of this.
  4. Aug 4, 2011 at 8:02 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Without your ARB bumper and winch you'll definitely need them. The 886 coils are tall and stiff. They're made for a truck having 200+ lbs hanging over the front end. After you get the ARB and winch you might end up in the 2" range where you wouldn't need them. If you end up around 2.5" though, you still may need them so it'd be prudent to plan for the extra expense.
  5. Aug 4, 2011 at 8:12 AM
    OZ-T
    Peter North
    British Columbia
    You are gonna get 3" of lift before you add the bumper and it may stay at 2 1/2" after .
    UCA's will allow for a correct alignment .
  6. Aug 4, 2011 at 8:14 AM
    OZ-T
    Peter North
    British Columbia
  7. Aug 4, 2011 at 8:45 AM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    ^^ correct. ARB advertises it as a 2" lift, but it's the same OME lift that everyone sells and gets you closer to 3"
  8. Aug 4, 2011 at 11:50 AM
    copenhagen
    South Carolina
    horwitzs:
    I'm assuming that you did not put the heavy OME lift on your TX Pro? Did you change out your UCA's? On an un-related note, was the supercharger worth it, and how did it impact your mileage?
    OZ-T:
    I was taking a gander at that thread and it looked like some guys needed them and some did not.
  9. Aug 4, 2011 at 11:55 AM
    OZ-T
    Peter North
    British Columbia
    The point is that you won't know if you get vibes from the lift until after it is installed , and therefore you won't know if you need shims until after your lift is installed .
    By adding the $8 worth of collars ahead of time you cover yourself in case you need to use shims . Having the collars in there does not negatively effect anything , but if you need shims later , you can easily slide them in and still be confident you have a good connection at the axle .
  10. Aug 4, 2011 at 11:59 AM
    copenhagen
    South Carolina
    I understand and I appreciate that. I was just outside looking at the stock UCA's and it makes me want to replace them just because they are made out of bent sheet metal. I wrote ARB an email asking them about using their heavy lift without a bumper and rather or not I needed new UCA's, so I'll post their response when they write me back.
  11. Aug 4, 2011 at 12:19 PM
    copenhagen
    South Carolina
    But, to sum things up, it would be the general recommendation that I need to purchase the following items in order to properly execute the OME 2" Heavy Lift:
    (Qty 1 @ $984.95)
    http://www.autoandtrucksprings.com/products/Center_Bolt_Head_Lengthener_2_Pcs-1662-0.html
    (Qty 1 @ $5.99)
    http://www.klmstore.com/total-chaos-96504-upper-control-arms.aspx
    (Qty 1 @ $745.00)
    That adds up to about $1735.94, and that is not including shipping or alignment fee etc. I guess the claim from ARB that the OME suspension kit takes the guess work out of ordering and gives you a single part number is not necessarily correct eh?
  12. Aug 4, 2011 at 12:23 PM
    OZ-T
    Peter North
    British Columbia
    Looks good .
    You also need front bushings for the Dakar pack .
  13. Aug 4, 2011 at 12:38 PM
    copenhagen
    South Carolina
    A Revised list of parts to make an OME HEAVY LIFT WORK RIGHT:
    http://www.4x4groupbuy.com/store/tac...y-p-10597.html
    (Qty 1 @ $984.95)
    http://www.autoandtrucksprings.com/p...cs-1662-0.html
    (Qty 1 @ $5.99)
    http://www.klmstore.com/total-chaos-...trol-arms.aspx
    (Qty 1 @ $745.00)
    http://www.trdparts4u.com/scripts/prodView.asp?idproduct=-8340
    (Qty 1 @ $24.00)
    Total cost less shipping: $1759.94
    That ends up costing about 600 dollars an inch give or take...of course you get the added benefit of being able to healthily support a winch/bumper, and more easily traverse rough terrain.
  14. Aug 4, 2011 at 12:40 PM
    OZ-T
    Peter North
    British Columbia
    Check out Wheeler's Offroad , I think they offer a poly bushing for the Daks
  15. Aug 4, 2011 at 12:56 PM
    OZ-T
    Peter North
    British Columbia
    Also , I noticed that the OME kit shows the older style front shocks FWIW
  16. Aug 4, 2011 at 3:45 PM
    copenhagen
    South Carolina
    Thanks for the pointers. I would not have known about those shocks being the older ones had you not told me.
    Here is the letter and response I got from ARB:
    Me:
    "Finances being an issue, I am unable to purchase all items at the same
    time. If I install your heavy suspension kit on my truck prior to
    installing the bumper, will I require an aftermarket set of upper
    control arms? If so, what brand do ya'll recommend? Thank you."
    ARB:
    "Installing a heavy load set of coils up front with no weight will cause the vehicle to become over lifted, creating issues with alignment, cv angles, ride quality and longevity of the struts. You can get away with it if you're simply street driving for a few weeks before the bumper is installed, but if you're looking at months down the road I would recommend the bumper first and then suspension."
    Of interest, they completely missed giving me an answer about the UCA.
  17. Aug 10, 2011 at 12:33 PM
    copenhagen
    South Carolina
    Here's an email I just got from ARB:
    I guess if you take your truck down to them to get fitted, they are not concerned with UCA's...? I find that odd as it seems from reading here that they are quite necessary.
  18. Mar 10, 2014 at 3:08 PM
    91Godzilla
    91Godzilla Member
    Ann Arbor, MI
    '11 Tacoma Offroad
    Hi guys, sorry to revive an old thread, but this is the only "comprehensive" list of items to do this lift I can find.
    I'm looking to do the same lift on my truck with an ARB bumper w/o a winch. Did this end up being everything you needed? If I have the bumper will the added weight reduce the lift enough to not need the UCA's? Any idea where I can get the poly bushings for the Dakars? I couldn't find the wheeler's offroad ones. Thanks for all the info here.
  19. Aug 23, 2015 at 10:24 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Tag for later - reference
