-   -   Shop installed spring perches upside down (http://www.tacomaworld.com/forum/suspension/171863-shop-installed-spring-perches-upside-down.html)
BAP_29 08-13-2011 03:56 PM
Well about 5 days ago I had a shop install my 5100s. I noticed I was sitting about an inch nose high, but just didnt think anything of it. Well after peaking under the truck, I noticed they installed the spring perches upside down. Ive already been there 3 times this week because they had to rebalance my tires. This whole ordeal has just been too much trouble and makes me wish I just left the truck alone.
KPT 08-14-2011 07:05 AM
Do NOT drive the truck with the spring perches on the 5100's upside down. The perches are designed to hold the c-clip in place by enveloping it. With them upside down, there is nothing holding the clip in place and the perch could fail at any moment. Have it towed to the shop and make them fix it. Once again, do not drive it like that!
Chris(NJ) 08-14-2011 03:00 PM
I would argue that you shouldnt feel as though you should have left the truck alone, but rather, found a more competent shop to do the work.
Anyway, just have them redo it. Really should not take more than 3 hours, from removal of the assembly, to re-installation.
BAP_29 08-15-2011 03:03 PM
Well I dropped the truck off to let em fix their mistake. They werent happy about it, but neither am I. I just dont know how they messed this up
Chris(NJ) 08-15-2011 06:22 PM
Originally Posted by wolfpack_5150 (Post 3583522)
its more common then u think.......I took detailed instructions along with correct and incorrect pictures with me, and stressed how easy and common the mistake was, and labeled/showed the installer the correct and incorrect installations.
No problems thankfully when I got the truck back.
Yep! Even the shop that did mine called me to clarify the direction of them (I guess they were too call to look at the directions I left the w/ them :( ).
BAP_29 08-16-2011 09:51 PM
Before
http://i99.photobucket.com/albums/l2...-50-23_140.jpg
After
http://i99.photobucket.com/albums/l2...-36-58_872.jpg
Wingman4 02-05-2014 01:57 PM
Just curious... What shop did you use? I know this is an old thread
