eibach vs OME
Discussion in 'Suspension' started by uscg2008, Aug 17, 2011.
  1. Aug 17, 2011 at 7:03 AM
    uscg2008
    uscg2008 [OP] Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    hey guys i was wondering if you could all help me out with acouple questions that i have.
    i have eibachs and 5100 billes up front right now set at .85. i was wondering if it is and why its bad to set the eibachs any higher than that? i have the 5100s out back too and a 2in AAL, the ass end of my truck is higher than the front. and its doesnt seem like the rear is going to settle any more, i just want to level it out.
    would it be better to change out to OME 885 coils and either the 10mm or 13mm top plate lift enhancer?
    thanks for the help guys
  2. Aug 17, 2011 at 7:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    The next setting is 1.25 and with the Eibachs that will give well over 3" of lift...............and your truck will hate you. You can do two things; the OME route you spoke of or just put the 10mm top plate on what you have already.
  3. Aug 17, 2011 at 7:28 AM
    uscg2008
    coby
    why would my truck hate me so much?!!?! i have the drivers side lean spacer already so idk if i could? would i just need to take the lean spacer and just put the 10mm on each side? and i think i might have to get the 10mm if it would work
  4. Aug 17, 2011 at 7:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    Your CV angles for one. Alignment issues for another. Shock travel for another. You could put the 10mm on both sides and leave the lean spacer in too.
  5. Aug 17, 2011 at 7:37 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Next setting for a second gen is 1.75, so it's even worse.
    Your truck will hate you because the Eibach's are a stiff coil and that's a lot of preload. You're better off getting a taller coil like the 885's and letting the coil do the lifting rather than preloading a shorter coil. The 885's have a lower spring rate than the Eibachs but they're taller. Toytec also makes a new top plate for the Eibach/5100 combo to give you a full 3" lift without preloading the Eibachs past the .85 setting. You'll also have the same ride you have now with the new top plate set-up. You might want to look into that option.
  6. Aug 17, 2011 at 7:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    Good call Pugga. I've got the first and second gens mixed up setting wise.
    OP ignore my suggestion.
  7. Aug 17, 2011 at 8:09 AM
    Pugga
    Massachusetts
    No, your concerns are 100% valid, you shouldn't go over the .85 setting with Eibach coils for the exact reasons you stated!
  8. Aug 17, 2011 at 8:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    LOL, misread my own post...........:eek:
  9. Aug 17, 2011 at 9:45 AM
    uscg2008
    coby
    Thanks guys for the help. I do have the diff drop already on, so I guess I will have to look imo the top plate spacers. Would i be able to use that in conjunction with the lean spacer?
  10. Aug 17, 2011 at 9:47 AM
    Pugga
    Massachusetts
    If you're refering to the new top plates from the Toytec kit, I don't see why not but I don't have that kit and can't say for sure. You should ask Toytec if you end up ordering that kit.
  11. Aug 17, 2011 at 9:57 AM
    scocar
    scocar hypotenoper
    I can see now whey they made you a mod.
  12. Aug 17, 2011 at 9:58 AM
    98tacoma27
    Ben
    Not Beech Creek
  13. Aug 17, 2011 at 10:02 AM
    soljah111
    soljah111 Well-Known Member
    Jon
    Denver
    11 supah white OR
    None yet
    Get the 1.5 aal and call it a day. It should even out.
  14. Aug 17, 2011 at 10:04 AM
    Pugga
    Massachusetts
    :D
  15. Aug 17, 2011 at 10:06 AM
    uscg2008
    coby
    But I don't want to lower the rear I want to have the front match the rears height
  16. Aug 17, 2011 at 10:10 AM
    Pugga
    Massachusetts
    Do you have aftermarket UCA's? You may have gotten away without them on your current set up but going higher may require you to get them or your alignment and handling could suffer.
  17. Aug 17, 2011 at 11:01 AM
    uscg2008
    coby
    Ya I have light racing UCAs already installed
  18. Aug 17, 2011 at 12:02 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Throw some sandbags in the bed. Lol. Think on the plus side, when u have a load in the bed u wont be nose high. I'm running almost the same setup. See my sig. uploadfromtaptalk1313607726073.jpg
  19. Aug 17, 2011 at 2:22 PM
    uscg2008
    coby
    ya yours is def more level than mine. i think im just gana get the top plate spacer kit from toytec. it says that it adds another 3/4in so i think that will help
  20. Feb 25, 2014 at 7:15 PM
    EmoSlayer
    EmoSlayer METAL!
    Scott
    PA
    TRD Off-Road
    Bilstein 5100s all 4 corners, front set at 0.85 w/ eibach coils metalcast red, driver's side lean spacer, rear tsb leaf pack with tsb aal from toytec, 265/75/16 goodyear wrangler authority, MT Classic III 16x8 4.5bs, LR UCAs
    OP, did you ever put those top plate spacers on? I have same setup as you and looking for more lift in front end. Did they work with the drivers side lean spacer?
