Help with rubbing, have toytec lift
Discussion in 'Suspension' started by jdhaas3, Aug 24, 2011.
  1. Aug 24, 2011 at 9:42 AM
    jdhaas3
    jdhaas3 [OP] Well-Known Member
    Jimmy
    Virginia
    Jeep Rubicon
    Durango front bumper, Warn Dual Force Powerplant HP winch with synthetic line, 3.5 AE lift, regeared to 4.88, ARB diff cover
    I have a 2011 double cab, long bed 4x4, trd sport. I just recently put a toytec ultimate lift kit on it and BFG KM2's 285/75/16. I am having a little bit of rubbing on the inner back side of the tire and I believe it is rubbing the lower control arm. I was able to scrape a bit of debris off of there and I am pretty sure its tire residue. It isnt major rubbing, just only while I am turning at the max turn radius and usually going up a hill or something. What is the best way to correct this?
    I spoke with toytec about the lift and they told me to measure from the center of the hub to the top of the fender and around 23 inches is supposed to be 3 inches of lift. I am sitting right around 24 inches.
  2. Aug 24, 2011 at 9:45 AM
    mxnborder
    mxnborder Well-Known Member
    Jason
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    does the rubbing sound loud? if it is its probably just hitting the plastic wheel well pieces that everyone with 285s has to trim pretty much. I don't think the tire would hit the lower control arm ever unless your backspace is worse than stock rims. . truck looks sick btw!
  3. Aug 24, 2011 at 9:59 AM
    jdhaas3
    Jimmy
    Virginia
    Jeep Rubicon
    i dont even know what my backspacing is...i just bought my tires...brought the wheels in and had them put on, that was it. i didnt ask anything about backspacing when i had them put on. thanks for the comment on the truck.
  4. Aug 24, 2011 at 10:03 AM
    mxnborder
    Jason
    Santa Barbara
    most of the time when you get a lift and larger tires you want a rim that has a backspace of 4.5" or less to keep the tire away from the suspension components , stock is 5.5 i think.
    Have a friend get in your truck and crank the wheel and you can probly see where it is rubbing. . also if you go in reverse and crank it thats usually when it will rub the most so you can check it out.
  5. Aug 24, 2011 at 10:06 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Have you had an alignment done since lifting ?
  6. Aug 24, 2011 at 10:08 AM
    jdhaas3
    Jimmy
    Virginia
    Jeep Rubicon
    i will try that later on...who do i talk to about backspacing? does that essentially push the tire furhter out from the truck? sorry for my noob question.
    yes they were able to align it no problem
  7. Aug 24, 2011 at 10:13 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    i would put some spidertraxx wheel spacers, thats what i did to fit 285's with a 3 inch lift and ive got no rubbing whatsoever
  8. Aug 24, 2011 at 10:17 AM
    jdhaas3
    Jimmy
    Virginia
    Jeep Rubicon
    1.25 inch? you put them on all 4 correct? sorry for the noob questions once again, new to all of this.
  9. Aug 24, 2011 at 10:26 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    only NEED to do the front, but can do all 4 to keep even.
    i came in here right away to say spacers and see that that has already been covered.
  10. Aug 24, 2011 at 10:26 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    No. Spacers are not needed it will make the rubbing worse.
    The FJ rims have the perfect offset/backspacing for 285's and a 3 " lift. I am willing to bet you are rubbing a little on the fender flare in the back of the wheel well if there has been no trimming done. It is very minimal but it helps a lot.
    Also at full lock I do very slightly rub my lower control arm when articulated. It will not hurt anything.
    Spacers are a waist of money in your case.
  11. Aug 24, 2011 at 10:27 AM
    jdhaas3
    Jimmy
    Virginia
    Jeep Rubicon
    yeah i will just do 4...i am not rubbing the fenders at all now, i guess i will probably be rubbing those after i get these but i can just trim those up
    will this affect my alignment at all?
  12. Aug 24, 2011 at 10:29 AM
    jdhaas3
    Jimmy
    Virginia
    Jeep Rubicon
    how would it make it worse...i am mechanically retarded so i have no idea here...the only real rubbing i can notice is the stuff on the lower control arm, i havent trimmed the fender at all.
  13. Aug 24, 2011 at 10:37 AM
    Dark Knight
    Jeff
    NC/SC
    If you put wheel spacers on there it sets the tire further away from the hub making the the radius of the turn larger. This will make the outside of your tire rub the shit out of your fender flares in front and back. It will also make you rub the body mount.
    get one of these if you plan to get the spacers and keep them on there.
  14. Aug 24, 2011 at 10:52 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    but hes rubbing on the controll arm not the fenderwell, so in this case spacers would help him. he said he would trim the fender well also if it rubs.
    OP you can also get really small wheel spacers like 1/8 inch, and that should correct the controll arm rubbing issue
  15. Aug 24, 2011 at 11:19 AM
    Dark Knight
    Jeff
    NC/SC
    Agreed, the 1/8th" spacer may help a little but the spidertrax spacers will make it rub so bad in other places it is just not worth it.
  16. Aug 24, 2011 at 1:52 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    for that little though wont he have to cut the lugs? dunno if id do that, such a dilema!
  17. Aug 24, 2011 at 1:55 PM
    Dark Knight
    Jeff
    NC/SC
    Cut the lugs???
    WTH?
    No!
    :facepalm:
  18. Aug 24, 2011 at 1:58 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    i guess i dunno how the spacer works then, i thought the original lugs attached to the spacer, and then the spacer had its own to attach the wheel to?
  19. Aug 24, 2011 at 2:07 PM
    mxnborder
    Jason
    Santa Barbara
    the tiny spacer just goes in behind the wheel over the lug bolts so there is still enough lug nut holding the wheel on. The larger spacers mount by themselves and have their own lug bolts to mount the wheel on.
  20. Aug 24, 2011 at 2:20 PM
    neoflex
    neoflex Well-Known Member
    If your rubbing on the LCA I am guessing it's only at full lock.If that's the case just deal with it and move on. As others said pulling the wheel out could create more rubbing issues. I would rather have my tires rub on smooth metal on the LCA at full lock rather than the fender wells and flare at less than full lock. How often do most of us cut the wheel that hard anyway? If your rubbing the LCA before full lock than maybe consider the spacers. Not real sure where your rubbing so I figured I would just throw in my 2 cents.
