Has anyone every installed this lift on their Taco?
Discussion in 'Suspension' started by carolinaboy90, Sep 7, 2011.
  1. Sep 7, 2011 at 8:10 AM
    carolinaboy90
    carolinaboy90 [OP] Member
    South Carolina
    02' Tacoma 2.7 4x4 SR5
    K&N intake system, Hunter brush guard
    I am new to lift kits and really dont know what I am looking for. I dont go mudding or hit the trails very often and when I do it is nothing extreme. I am just looking to level out my front and at the same time be able to run 285/75/r16. Is it possible with this lift and is this lift any good. Any help will be great.
    1995-2004 Toyota Tacoma 2WD/4WD (6 LUG)
    3" Front 1" Rear Complete Suspension Lift Kit
    Kit Contains:
    2x Front Billet Lift Spacers Anodized Black w/ hardware
    3x Front Skid Plate Spacers and hardware
    2x Differential Drop Spacers and hardware
    1x Brake Proportion valve relocation bracket and hardware
    2x Machined Billet Rear Lift Blocks Anodized Black
    4x U-bolts w/ nuts
  2. Sep 7, 2011 at 8:20 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    It's a spacer lift. Not well thought of around here.
  3. Sep 7, 2011 at 2:06 PM
    carolinaboy90
    South Carolina
    I am not looking to drop a whole bunch of money into this simply because I dont go offroading hardly any (and i realize that when dealing with lifts there is no such thing as cheap). I just want something to make the truck level and be able to run a size bigger tire.
  4. Sep 7, 2011 at 2:21 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
  5. Sep 8, 2011 at 4:25 PM
    carolinaboy90
    South Carolina
    The adjustable struts in the front do look nicer. Will shackles do anything in the rear if you dont use a AAL. Thanks for the help JLee.
  6. Sep 8, 2011 at 4:29 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    keep in mind the toytec add-a-leafs give 2 inchs of lift
  7. Sep 8, 2011 at 4:33 PM
    TACOMABOSS
    96 SR5 4x4
    Thats interesting... but the OP said he wants 1 inch in the back.
  8. Sep 8, 2011 at 4:44 PM
    TACOMABOSS
    96 SR5 4x4
  9. Sep 8, 2011 at 6:33 PM
    TACOMABOSS
    96 SR5 4x4
  10. Sep 8, 2011 at 7:16 PM
    TACOMABOSS
    96 SR5 4x4
  11. Sep 11, 2011 at 8:23 AM
    carolinaboy90
    South Carolina
    Tacomaboss and Vacountryboy. I was just looking at the 3 inch lift in the front and 1 inch lift in the rear lift kit because I want the front level with the rear. But anyways what ratio front to back should I go with. Thank yall for the help.
  12. Sep 11, 2011 at 12:25 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    3 in the front and 1 in the rear might leave you a tad nose high.
    I went with 3 in the front 2 in the rear and that leveled me out
  13. Sep 11, 2011 at 12:29 PM
    TACOMABOSS
    96 SR5 4x4
    3 in front and 1 in back would leave your nose high. 3 in front and 2 in back would be probably level.
